Old 05-09-2019, 10:13 AM #61
Roverguy1's Avatar
Roverguy1 Roverguy1 is offline
Roverguy1 will become famous soon enough
Roverguy1's Avatar
Ordered a set of 1" front lift spacers yesterday. May special, $29. Can't go wrong with that!
Roverguy1 is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 07:35 PM #62
kblaine123 kblaine123 is offline
kblaine123 is on a distinguished road
1" front lift
Guys....got a question on the lift.
Assuming one has the 1" cornfed front spacer for leveling.....
Can you run 285x70x17 tires on 17x9 wheels with the above setup ?
I currently have a 2 inch lift and zero problems( no rubbing, no BMC) , but frankly, I'd probably prefer to have ony the front lifted to level it.
Cornfed 1" front spacer to level only...-lifted-jpg
kblaine123 is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 11:10 AM #63
jspagna1's Avatar
jspagna1 jspagna1 is offline
Real Name: Joe
jspagna1 is on a distinguished road
jspagna1's Avatar
Real Name: Joe
Perfect - The stock wheels & Tires are my winter set up. In the summer I run 18 x 8 1/2" wheels with 265/65/18 tire.
Cornfed 1" front spacer to level only...-4runner12-jpg
2012 Nissan Maxima SV Premium/Tech. Package Winter Frost Charcoal Leather
2011 Toyota 4Runner SR5 4x4 Blizzard Pearl Graphite Sport Cloth(4.0 Liter V6)
1966 Mustang Coupe (5.0)
jspagna1 is offline   Reply With QuoteReply With Quote
Old 06-13-2019, 11:36 AM #64
Psylas Psylas is offline
Psylas is on a distinguished road
Just had my 2/1 spacer lift installed. Rides like stock.
Cornfed 1" front spacer to level only...-b62719fe-0638-4d3a-8234-265ee29681f6-jpg
Psylas is offline   Reply With QuoteReply With Quote
Old 08-09-2019, 12:33 PM #65
Silversurfercal's Avatar
Silversurfercal Silversurfercal is offline
Real Name: Stefan
Silversurfercal is on a distinguished road
Real Name: Stefan
Originally Posted by Toy_Yota_x2 View Post
After reading through this thread multiple times, I decided to give the 1” lift from cornfed suspension a try and I’m very glad I did. The lift is quite subtle, but to me makes a big difference in the appearance. We also mounted Stealth Custom Ray 10’s at the same time. Tires are 265/70/17 KO2’s.
Do you have KDSS? really like your lift, nothing crazy
i
Silversurfercal is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 09:59 PM #66
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
Is the Cornfed 1” top plate spacer aluminum or plastic?
Does it come with longer studs? There seems to be mixed answers on this.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 10:12 PM #67
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
It's made of UHMV and is really 3/8", comes with shorter thread nuts but stock ones will still thread and work.
Toytec and HeadStrong make aluminum top hat spacers not sure if longer studs are stardard for those or for additional cost.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 10:17 PM #68
yardsale's Avatar
yardsale yardsale is offline
yardsale will become famous soon enough
yardsale's Avatar
Hard plastic. It does not wear. I removed mine after a year and went another route. Spacer was fine. No signs of damage.
It comes with shorter, lower profile nuts, which also worked fine. No studs with the one inch lift.
yardsale is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 01:11 AM #69
Oh ok that explains why the Cornfed spacers are so much cheaper than the Toytec.
I also found Wheeler black anodized aluminum spacers for $45/ pair which is only $6 more than Cornfed plastic spacers. I might go with them.
1/2" Thick Strut Top Plate Spacer Pair, for 05+ Tacoma, 03+ 4Runner, 07+ FJ Cruiser
TRD Pro wheels
Old 08-13-2019, 01:57 PM #70
DeltaWhiskey's Avatar
DeltaWhiskey DeltaWhiskey is offline
DeltaWhiskey has a spectacular aura about DeltaWhiskey has a spectacular aura about
Talking ordered
I should get mine tomorrow, hoping to get installed soon
2019 SW TRDORP
DeltaWhiskey is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 09:25 PM #71
Toy_Yota_x2 Toy_Yota_x2 is offline
Toy_Yota_x2 is on a distinguished road
i
Thanks, and yes, ours has KDSS. No issues since adding the lift.
Toy_Yota_x2 is offline   Reply With QuoteReply With Quote
Old 08-14-2019, 12:16 AM #72
Bobbyboy Bobbyboy is offline
Bobbyboy is on a distinguished road
Looking at a 2010 limited right now as I am trying to get educated on 4Runners. Was expecting to do a front leveling kit but this one seams very level. I have viewed the lifts from this post and now know what to look for to see what has been done to it. It will be my first Toyota since 1982.
Are all limited 4Runner 5th Gen suspensions the same, or is there one to try and avoid? Reason I ask is the shocks on this 2010 limited seam to have a hydraulic line going to the top of the shock. Good or not?
It's pretty mint, so need to do my homework before it's sold.
I am a new guy so can't make a new post yet so hope for some help!
Bobbyboy is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 01:27 AM #73
JFlo76 JFlo76 is offline
JFlo76 is on a distinguished road
Have any of you that are using the 1" front spacers noticed a change in the ride quality regarding body roll or anything while rolling over small objects?
JFlo76 is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 02:45 AM #74
RusPro17 RusPro17 is offline
Real Name: Don
RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about
Real Name: Don
Are these being added by anyone with a Pro?
RusPro17 is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 02:42 PM #75
tyler2019 tyler2019 is offline
tyler2019 is on a distinguished road
I would also like to add:
Anyone do 1" front spacer on 2020 yet? Wondering if it affects the Toyota safety sense functionality. Can't imagine it would given the system has got to be designed to accommodate a heavy load in the rear....
tyler2019 is offline   Reply With QuoteReply With Quote
All I want to do is get the front level. What would be the best spacer to use? Jeff T 4th Gen T4Rs 49 08-30-2016 11:52 PM
4th gen Supreme suspension 2.5" leveling kit + Cornfed 1" rear spacer black_120 For Sale: Suspension/Wheels/Tires 12 02-09-2013 06:57 PM
FS: Cornfed 1" Front Leveling Spacer bigwebb83 Classifieds - buy & sell (no commercial ads please) 12 04-05-2011 08:42 AM
Cornfed 2" rear Spacer, Ready Lift 2.25" Front Spacer bt216 Classifieds - buy & sell (no commercial ads please) 18 08-08-2009 05:40 PM
Will a 3" cornfed lift level my 06 ? Kirby 4th Gen T4Rs 1 06-29-2006 12:28 PM
