Old 06-13-2013, 01:34 PM #1
sbcsar26 sbcsar26 is offline
sbcsar26 is on a distinguished road
5th Gen Lift Suggestions
I am knew to the off-road world and I need some help in finding a lift kit for a 2013 trail edition.
Any thoughts or pointers would be much appreciated. I am pretty much out in left field with all this.
Thanks!
sbcsar26 is offline   Reply With QuoteReply With Quote
Old 06-13-2013, 01:42 PM #2
Natey's Avatar
Natey Natey is offline
Real Name: Natey
Natey is on a distinguished road
Natey's Avatar
Real Name: Natey
What are your plans for the truck? If you just want to look good and maybe go camping, spacers are most likely fine. Toytec, etc. If you wanna go all-out and jump the thing or somethin, you can spend thousands on Icon stuff or something similar.
2012 Limited...Stock
Natey is offline   Reply With QuoteReply With Quote
Old 06-13-2013, 01:50 PM #3
Okki Okki is offline
Okki will become famous soon enough
Until you provide some more insight into your reasons for wanting a lift, not a whole lot of recommendations can be given. A lift is not a requirement for offroad usage and sliders/skidplates may be a better/sufficient choice for your purpose.
Okki
Okki's Build Thread - 2010 Limited: Shrockworks Rock Rails & Full Skids, Gobi Rack, OPT7 LED Roof LIGHT Bar, Rigid E-Series Bumper Light Bar, Hella Horns, Auxiliary Fuse Box, Cobra ST75, TRD Rims, Discoverer ATP LT265/70R17, Rotopax, ARB Twin Compressor, Cargo Area Pressure Gauge and Chuck, Icon billet trailing- and A-arms, Dobinsons Shocks/Coils, Fumuto Oil Valve, Northstar Group 31M, CBI Front & Rear Bumpers !!!
Any time...Anywhere.. My cat can take you.
Okki is offline   Reply With QuoteReply With Quote
Old 06-13-2013, 04:00 PM #4
I want to add 2 to 3 inches of lift to keep from bottoming out so much. I did a driving school last weekend and the clearance was less then desirable. There was another 4Runner in the course and he didn't have the issues I did because he had put in a lift kit.
I am not real sure what I want to do as this is my first 4x4. So all this is a little new. I had someone reccommend an OME.
I know some of this is driving experience, and maybe I need to start with getting more of that before I put in a lift. I am not interested in jumping rocks. Just being able to get into the backcountry when I want to go exploring.
Does that make sense???
Old 06-13-2013, 04:04 PM #5
cbielat's Avatar
cbielat cbielat is offline
Real Name: Chris
cbielat has a spectacular aura about cbielat has a spectacular aura about
cbielat's Avatar
Real Name: Chris
Search Box works wonders.
http://www.toyota-4runner.org/5th-ge...ld-thread.html
Long Travel Front, Long Travel Rear and everything in between.
cbielat is offline   Reply With QuoteReply With Quote
Old 06-13-2013, 04:07 PM #6
Tengu's Avatar
Tengu Tengu is offline
Tengu is on a distinguished road
Tengu's Avatar
Several choices here without getting crazy.
Complete Lift Kits - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
2010 trail, Icon shift nobs before I left the lot (from previous 2011 sr5), kappa mod, baja rack, Goodyear MT/R 285-70-17s, SCS Stealth 6 Bronze, Icon extended travel front coil overs set at 2.5, rear Icon shocks n Overland springs, Icon tubular uniiball UCAs, Metal Tech Adjustable Rear LCAs, Total Chaos LCA bracket skids, Icon rear shock lower guards, Shrockworks step sliders, advanced cup holder mod (added coozies), full Shrockworks underbelly babaaaay (skid plates), sPod, CBI rear bumper and tire carrier. ARB air compressor, ENGO winch, Shrockworks front bumper, Vision X led pods under, Engo 20 in bar, rear Rigid, and Ditch Lights. Safari Snorkel on the way.
Tengu is offline   Reply With QuoteReply With Quote
Old 06-13-2013, 04:33 PM #7
Instructor Instructor is offline
Instructor is on a distinguished road
I am running front and rear OME coils on stock strut/shocks and I am very happy with the lift height and ride. I acheived 3" lift in the front and about 2" in the rear, giving me a near level stance with increased spring rate in the rear if I need to add additional cargo. I am running the 2884 front coils and 2895E in the rear. If maximum wheels travel is a concern, new OME shocks could be added. Coils were less than $375 shipped.
Instructor is offline   Reply With QuoteReply With Quote
Old 06-13-2013, 04:38 PM #8
Which version 4Runner do you have? on a TE or SR5 you can go fairly easy to a different coil/shock. on a Limited it's a bit more work due to the XREAS. But for most no-rock-jumping back country you do not need a lift.
If you are just planning on taking service roads into national parks and the odd back trail, you will do better with just slightly better skid plates and regardless of lift or plates, a good spotter.
If you are going to do more serious offroading you will end up with both suspension and skid work, so starting with the skids is an easier and cheaper start.
Spacers give you some lift, but they also preload the suspension and that is not necessarily what you want in either your road or offroad handling.
If you are going to do trails, also get sliders .... soon. My sliders saved my ass on my first trip out. plus they help with Walmart parking door dings.
Okki
Old 06-13-2013, 07:07 PM #9
Hellamatic's Avatar
Hellamatic Hellamatic is offline
Hellamatic is on a distinguished road
Hellamatic's Avatar
I would suggest the "search" feature
2012 4Runner Trail Edition....None more black
Hellamatic - Build Thread
Hellamatic is offline   Reply With QuoteReply With Quote
Old 06-13-2013, 08:58 PM #10
thebwlife's Avatar
thebwlife thebwlife is offline
Real Name: Jordan
thebwlife is on a distinguished road
thebwlife's Avatar
Real Name: Jordan
These should all work on your 4Runner
The NEW Complete Lift Listing and Comparison, they're all here! UPDATED! - Toyota FJ Cruiser Forum
thebwlife is offline   Reply With QuoteReply With Quote
Old 06-13-2013, 10:24 PM #11
Thanks everyone for your thoughts. I will do my research and let you know what I end up doing. Thanks for helping out this newbee!
Old 06-14-2013, 10:44 AM #12
2013Trail's Avatar
2013Trail 2013Trail is offline
2013Trail is on a distinguished road
2013Trail's Avatar
So, if spacers are used is a diff drop needed?
2013Trail is offline   Reply With QuoteReply With Quote
Old 06-14-2013, 10:47 AM #13
2013Trail's Avatar
2013Trail's Avatar
Did you install the coils yourself? If so, how long did it take? Did you need a diff drop?
Old 06-14-2013, 10:49 AM #14
2013Trail's Avatar
2013Trail's Avatar
Also, do you have to have the alignment adjusted after installing the coils? Any issues like front wheel vibration, pulling, wandering, etc. since it's been lifted?
Old 06-14-2013, 12:06 PM #15
When you lift, you will want to get UCA's (upper control arms) to correct the camber; especially when you are pushing 3 inches. and of course a proper alignment. There have been numerous threads on this subject that a search will pull up for you.
You may also want to call some vendors (Brandon @ Metal Tech 4x4, Bobby at High Tech Auto, Etc) as they can provide you a lot of insight as well and help with sourcing parts/installation.
Okki
lift suggestions jhowell 3rd gen T4Rs 1 06-12-2012 06:36 PM
Lift Suggestions 4running96 3rd gen T4Rs 2 08-01-2011 04:35 PM
suggestions for a lift 6starbucks 4th Gen T4Rs 20 02-13-2011 11:19 AM
Lift suggestions 99yota4 3rd gen T4Rs 10 01-17-2010 12:53 AM
Lift suggestions Gottsox 3rd gen T4Rs 2 03-15-2008 06:43 PM
