06-15-2013, 03:53 PM
Brakepad check at 32,000 Miles, 80,000+ Miles,101,000 Miles, 135,000 miles
Look good to me.
Didn't bother measuring.
I'll probably check them again at 100k.
07-08-2017, 12:54 PM
Update: 80,000+ miles.
Brake pads and rotors look great. I pulled the pins, wiped, and applied 3M silicone paste.
Looks like I need new shocks though.
Brake Parts
Front Rotor 4351260191
Front Brake Pads 0446560320
Front Shim Kit: 0494560090
Front Caliper Pins: 4773560300
Front Caliper Pin hold (Spring): 4774360280
Front Caliper Springs (fitting kit): 0494735050
Front Anti-Rattle Spring: 4774835010 (not needed if using fitting kit?)
Rear Rotor 4243160311
Rear Brake Pads 0446660140
Rear Shim Kit: 0494660141 / 0494660140
Rear Caliper Fitting kit: 0494722050
Do Not Use
- these kits are economy quality -
Front Brake kit: 04465-AZ001-TM
Rear Brake kit: 04466-AZ004-TM
Torque specs:
Front brake caliper mounting bolts: 91 lb-ft (17mm) note: 137 lb-ft if you have 19mm bolts.
Rear brake caliper mounting bolts: 77 lb-ft (17mm)
Rear brake caliper slide pins: 65 lb-ft (17mm)
07-05-2019, 02:44 PM
101,000 and still looking good.
07-05-2019, 02:53 PM
Real Name: Chris
Real Name: Chris
Still the original pads?
When I had the tires replaced last week on my 2015 4Runner TRD I inspected the brake pads and at 34K miles the original Toyota brake pads look like they have about another at least 35K miles left on them. I drive Houston city stop-and-go and freeway. Pleasantly surprised at the longevity of the brake components.
My old 2002 Toyota Sequoia was a lot harder on the front pads for sure.
07-05-2019, 03:02 PM
Seriously, 100k on original pads and rotors. That's impressive.
Sent from my SM-N960U using Tapatalk
07-05-2019, 03:51 PM
What material are the stock pads? I'm guessing semi metalic?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
07-05-2019, 04:11 PM
Banned
Real Name: Tobias Fünke
Banned
Dark matter apparently. 100k is pretty impressive.
07-05-2019, 04:15 PM
Trick is... Don't use the brakes. Lol
07-05-2019, 11:10 PM
This! Yes original pads. I added a pic of the rears to the previous post. I’ve cleaned and lubed the pins a couple times. I’m probably going to do a fluid change this summer if I can find the time. Rotors are still really nice. Can’t seem to get a good pic of those. I pulled the wheels to finally plasti-dip them. The clear coat on the machined edge of the rims is half peeled off. Going to try this. If it doesn’t work I’ve got another set in new condition.
07-06-2019, 10:26 PM
Fronts were gone at 27K....rears were on the squeeler! replaced with Akebono's (oem) Rears hit the Squeeler again at 45K............Wife is a Racecar Driver apparently!
07-06-2019, 10:32 PM
44K and mine look like your 101K... I do a "lot" of canyon/mountain driving though so no coasty stoppies for me
Still impressed how long they've lasted. I have a set+shims on the shelf. I checked them last month and rotors and pads are still well in spec
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
04-25-2020, 01:48 PM
110K original miles with 2mm left on front and rears. Just replaced pads and rotors look good!
1996 Limited - OME 881/906 w/comfort shox | Deckplate | Hayden 1678 | 265/75R16 Revos | Koyo A1998 bypassed | Husky liners | Optima R34 Red Top | '99 Cupholders | Rear diff breather mod | (Totaled)
2012 Limited - Husky liners | OPOR sliders | 30% Ceramic Huper Optik | AVS seamless | Odyssey 34R-1500T
04-28-2020, 11:30 AM
I’m getting closer to changing mine. I took advantage of the free shipping this month from Toyota Parts and Accessories - Official Online Store and bought front and rear pads and shims. I bought aftermarket springs and pins as well as brake lube and silicone paste on amazon a year or so ago.
08-01-2020, 10:10 PM
After 111,000 miles and 10 years my brake pads still look very good.
So I decided to replace the brake fluid.
I bought 2 qts (one for backup) of Prestone DOT 3 from Walmart for about $7 ea.
Made a gravity bleed bottle from an old plastic OJ bottle, a few feet of 1/4” id clear vinyl tubing, and a couple of zip ties.
Remember to keep the bottle and tubing above the bleeder and you shouldn’t have any issues with air bubbles.
The ABS motor makes the rears go quickly. I did two 20 second sessions of 4 motor runs while checking both the master cylinder res and my drain tubing/bottle setup in between.
The fronts I simply let gravity do it’s thing, about half hour on each.
The last pic is before and after. I really can’t tell the difference.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
