Originally Posted by screeves
As
Antman
said you can do it,no problem.
Here's some of the stumbling blocks though...
1. the connectors for lights will not line up..two different specs.
2. You'll need a pintle to go into the receiver, preferably an adjustable one, and chances are to get the right height you'll have flip it upside down.
3. The trailer has surge brakes, which work...but not as much control as an electric braking system. You can overcome this by putting a new electric brake axle on..a 3" dia., which is for the most part a direct bolt up, will run about $350 from Redneck trailer supply......a electric brake controller is another $100
I've converted 2 trailers so far..both M116A2's (flatbed)
Started with this...
Ended with this..
and his little brother...
