After much anticipation, I finally installed the LR UCAs and found a reputable shop to give me a proper alignment. Dummy me did not get a print out or write down the exact specs that were achieved, but the tech told me I ended up with +5 caster on both sides. I very much love the stability with the new alignment and clear the body mounts now by at least an inch. However, in trying to get my tires away from the body mount, I have created a new problem rubbing the front bumper cover (not the fender liner). I didn't remember reading about anyone having this issue...of course I could have missed it. Only rubs in reverse at about 3/4 turn...
The question I am getting to is do I trim the small section of the bumper cover that I am hitting with a dremel...or ask the tech to dial me back down a bit on the caster? The knobs on the tire are just grabbing the part of the front bumper cover that rolls underneath at the corner. Since I did the fender liner mod, this piece of the cover sticks out about an inch or so further...so if I trimmed it off, the rubbing issue will be solved.
Just wanted to ask before I go cutting plastic off....
Snapped a quick pic of what I am talking about
