Originally Posted by 1engineer
It does get confusing. It all starts with base stock. Difference between full and blend is simply additive packages. Mobil1 is fine.
Actually, from my understanding the base stock is the difference. Depending on who you ask fully synthetic oils start out from a group III, group IV or group V base stock. Some oil snobs would only consider a fully synthetic oil to come from a PAO base stock of group IV or V. Group III is similar to Group II but has higher viscosity indexes. Nothing wrong with a oil from a group III base stock
Semi Synthetic oils are a blend of Group I, II or III base stock with some group IV or V mixed in but you never really know how much.
Semi synthetic oils are fine, hell, conventional oil is fine if you keep it changed. I have researched the hell out of oils to figure out what would be best for my 4Runner and decided to go with the Toyota branded full synthetic. I am an Amsoil loyalist but decided to go with Toyota this time
Since I am sure somebody will I will just come out and say correct me if I'm wrong
