Originally Posted by Antman
You tapped into an ignition source that stays hot after the key is out. Need to find a source that is only hot in accessory or run key position. Im at work but if you don't fund a wire I can help you find one later today!
Jeff, are you thinking OP tapped in to an ignition source that stay on for a little bit after you turn the key to off, like the window/sunroof control? If so, wouldn't that turn off once you open the door? I think he's having problems after he opens the door and get out of the vehicle so I still feel like he might possibly getting some kind of power feedback from the remote turn on wire, but it's hard to say w/o looking at it physically.
HI88SR5, I would do what Jeff said and try to move the remote turn on wire to something that powers on when the key is in the accessory position. The easiest one I can think of is the cigarette lighter socket, and if you are getting any power feedback from the amp to the cigarette lighter socket it shouldn't be such a big deal and shouldn't affect the ignition not powering down after you turn off the car. What do you think Jeff, Antman approved?
