Old 08-19-2013, 09:01 PM #1
Jesse1983's Avatar
Jesse1983 Jesse1983 is offline
5th Gen Moderator
Jesse1983 has a spectacular aura about Jesse1983 has a spectacular aura about Jesse1983 has a spectacular aura about
5th Gen Moderator
Jesse1983's Avatar
DIY: TE Headlights, Black Headlights (BHLM)
It always bothers me a little when I see people on here buy TE headlights for their Limited or SR5. Blacking them out yourself is relatively easy, and far less expensive. Last time I had a headlight apart I decided to take some pics and put a how-to together so people can feel confident doing this on their own.
This can easily be completed in a weekend. I would recommend doing the entire mod on day one, let the headlight sit overnight, and put back on the truck day two.
What you need before you begin:
  • A household oven
  • Piece of cardboard that will fit in the oven
  • Phillips head screw driver
  • Gloves
  • Spray paint of choice (Krylon fusion for plastic is my go-to)
  • Clear window/door silicone
  • Clamps
To begin remove the headlights from your truck. Unless you have an aftermarket bumper you will have to remove, or at least pull forward your bumper cover. See here for a detailed write-up on removing the bumper cover and headlights courtesy of @Shogun .
You can get the headlights off without removing the entire bumper cover, see here courtesy of @Ducmonsta . Then refer to previous link for location of headlight bolts.
Once your headlights are off you are ready to begin.
Preheat your oven to 300 degrees. Don't worry, even though this sounds scary nothing is going to happen to the lights.
Remove anything from the lights that could melt in the oven. The red arrows show plastic pieces which should be removed. Be sure to remove any light bulbs, don't forget the marker light bulb. Also remove all the screws around the light (green circles). The star indicates where a pice is (not pictured) that screws into those two holes which your bumper cover clips to. this piece should be removed as well.
Once everything is removed from the light, and the oven is preheated to 300, turn the oven OFF. Put your piece of cardboard in the oven and place your light on top of it. Make sure no pieces of your light are touching the oven, or the oven rack, they will melt. You are only using the heat in the oven to soften the glue, not baking them as you would if the oven were on.
Leave the headlight in there for ten minutes. You can use this time to prep the second light.
After ten minutes put your gloves on and take the light out. You want to work quickly as the glue is very strong and is easiest to work with when it's fresh out of the oven. Begin pulling to separate the clear lens from the black, back part of the housing. I find it easiest to start at the side closest to the high beam. Getting it started is the hardest part. Once you get a finger or two in there (no dirty jokes please) it'll loosen up. Don't try to pull using the tabs, they will be soft from being in the oven and can break. if they break you may not be able to bolt the light back on the truck. As you pry the lens from the housing take it slow and break the black glue apart with your fingers (I've usually removed my gloves by this point). You do not want this glue to attach to your lens or reflector bowl.
After the headlight is apart you'll have the back and the reflector bowl as one piece
And the lens and bezel as a second piece
flip the lens over and remove three screws holding the bezel in
now you just have this
remove the marker lens. this can be a bit tricky and it's very possible you will break one of these tabs. take your time.
now you have this
this is where your marker bulb comes through, and you could tape it off before painting, or just paint it. It'll be brighter if you tape it off.
Spray paint the entire bezel. Once it's dry put it back in the lens. make sure it is on the three tabs in the lens. Here are 2 of them, the other is in the corner
screw in the bezel with the 3 screws you removed.
Place the lens back on top of the housing and make sure all the screw holes are lined up. Put in as many of the screws as you can.
Preheat the oven back to 300. Once it reaches 300 turn it OFF and put the headlight in for 10 minutes. After 10 minutes remove the light and tighten all the screws you started before you put it in. If you have some clamps you can put them around the housing to press tight the lens and the back. After everything is cooled down i like to go around the entire light with clear window/door silicone just to be sure.
Let it sit overnight and reinstall the next day. and just like that you have black (or blue, or red, or purple, or whatever color paint you buy) headlights! And it cost you time and a few bucks!
Originally Posted by 7harper View Post
First 5th with real CO's
2017 White TRD OR, Icons, BFG Mud-Terrains, Konig Countersteer, Retro Headlights, Gobi stuff
Jesse1983 is offline   Reply With QuoteReply With Quote
Old 08-19-2013, 09:16 PM #2
philsey's Avatar
philsey philsey is offline
Real Name: Um, Phil?
philsey has a spectacular aura about philsey has a spectacular aura about
philsey's Avatar
Nice.
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
philsey is offline   Reply With QuoteReply With Quote
Old 08-19-2013, 09:27 PM #3
hrod79's Avatar
hrod79 hrod79 is offline
Real Name: Rod
hrod79 is on a distinguished road
hrod79's Avatar
Real Name: Rod
Lol, 2 days after I order TE lights..... I'll give it a try and return new ones if I don't mess it up. Thanks for the info!
2010 4Runner SR5 4X4 with 3rd Row. Icon 2.5" extended Travel Front and OME 898 spring w/2.0" Icon Rear/ TE headlights and Tail Lights/ GOBI roof rack with (2)Rigid SL 6" spots front and (1)Rigid SL 10" combo / SCS Ray 10 Wheels with Duratrac 285-70-17 for playing off the road/ husky liners/ Pioneer Avic-X850BT with NAVI. / FIAMM Horn / Sotashi Grille / CB Cobra 75wXST with 2' Firestick Antena / Shrockworks Rear bumper with tire swing / Demello triple hoop front bumper Domello sliders, RCI aluminum skids.
hrod79 is offline   Reply With QuoteReply With Quote
Old 08-19-2013, 11:25 PM #4
Hellamatic's Avatar
Hellamatic Hellamatic is offline
Hellamatic is on a distinguished road
Hellamatic's Avatar
Good write-up! I did this mod on my Tundra 5+ years ago and it still looks great, so longevity isn't an issue if that is causing trepidation for someone considering the mod. It's definitely TERRIFYING the first time you stick a very expensive headlight in the oven, but I think it would be very difficult to actually melt them down.
Another suggestion for anyone that tries this: I would shoot the orange marker lens with some Niteshades while you're in there.
2012 4Runner Trail Edition....None more black
Hellamatic - Build Thread
Hellamatic is offline   Reply With QuoteReply With Quote
Old 08-20-2013, 06:11 PM #5
Alex T4R's Avatar
Alex T4R Alex T4R is offline
Alex T4R is on a distinguished road
Alex T4R's Avatar
  • A household oven
  • Gloves
  • Clamps
To begin remove the headlights from your truck. Unless you have an aftermarket bumper you will have to remove, or at least pull forward your bumper cover. for a detailed write-up on removing the bumper cover and headlights courtesy of @Shogun .
You can get the headlights off without removing the entire bumper cover, see courtesy of @Ducmonsta . Then refer to previous link for location of headlight bolts.
now you
Thank you Jesse for posting DIY on this, for me this is not so scary as doing a retrofit frighten me a lot. I would love me so retrofit but doing it through someone is so expensive and doing it by myself is scare.
2013 Sr5 Premium Package Build Thread Dearly missed
2014 Limited-short lived, but 4ever remebered
Alex T4R is offline   Reply With QuoteReply With Quote
Old 08-20-2013, 07:45 PM #6
Snooperstyle's Avatar
Snooperstyle Snooperstyle is offline
Snooperstyle is on a distinguished road
Awesome!
2010 LTD 4x4, blk/sbl, nav, remote start MODS/ADDS: TE Conversion; ICON Stage 2 w/ LRUCAs; 285/70/17 DuraTracs; Baja Rack; SW Sliders, ARB CKMA12 onboard air; Fiamm horns; Tan Huskys; 30% tint; 5" mangowalk; LED lights in interior, puddle lights, license plate, engine compartment, and cargo area; small tool box under the hood; removed cargo tray stopper; reverse cam switch; 4-pin trailer light hookup relocation; K&N air filter; AVS bug deflector; 3m carbonfiber chrome coverup (except door handles); midland CB; Firestik 2' hood-mounted CB antenna.
Snooperstyle is offline   Reply With QuoteReply With Quote
Old 05-30-2014, 05:55 PM #7
GP4R GP4R is offline
GP4R is on a distinguished road
What happened to the pictures? (Other than the obvious)
GP4R is offline   Reply With QuoteReply With Quote
Old 05-31-2014, 08:55 AM #8
Jesse1983's Avatar
5th Gen Moderator
5th Gen Moderator
Jesse1983's Avatar
sorry, fixed.
Old 05-31-2014, 11:51 PM #9
grifter grifter is offline
grifter is on a distinguished road
Great write up! At some point when I've saved up enough coin for an hid retrofit I'll refer back to this and paint the chrome black too. Should I expect any trouble just using krylon black for plastics on top of the chrome without prep or sanding?
grifter is offline   Reply With QuoteReply With Quote
Old 06-01-2014, 08:05 AM #10
Jesse1983's Avatar
5th Gen Moderator
5th Gen Moderator
Jesse1983's Avatar
krylon fusion for plastic will work just fine. no prep needed.
Old 06-01-2014, 11:57 AM #11
Sweet. Thanks again!
2012 SR5 4Runner. Plasti-dipped emblems. Toytec 3/2" TTHA Lift. Light Racing UCA. 285/70/17 BFG TA KO. Method Racing NV 17 x 8.5" matte black. Stubby antenna. Running Boards removed. Weather tech mats.
Old 10-29-2014, 10:29 AM #12
rockja rockja is offline
Real Name: Jason
rockja is on a distinguished road
Real Name: Jason
My apologies if this was hidden somewhere in the thread, but I've been reading through this now for a while and didn't see if the trail lights used gloss, satin, or flat finish. Do you have any advice on what is used by the factory and/or what looks best in your opinion?
Thanks!
rockja is offline   Reply With QuoteReply With Quote
Old 10-29-2014, 10:37 AM #13
Jesse1983's Avatar
5th Gen Moderator
5th Gen Moderator
Jesse1983's Avatar
Thanks!
the stock trail lights are like a glossy smoke black (if that makes sense). In my opinion a flat black would look best, but it's a personal preference.
Old 10-29-2014, 10:56 AM #14
macgyver_ga macgyver_ga is offline
macgyver_ga is on a distinguished road
I've done the black housing job on every vehicle I've ever owned and done many friends' vehicles. I just did my Tundra last weekend. I'll be doing my wife's 4runner soon. You don't need to sand anything. Just make sure you wear latex or nitrile gloves to keep the finger prints off. The key to proper paint adhesion is to do it on a relatively dry day, don't rush things, and spray a couple very light mist coats to begin with. After that, 2 more medium to heavy coats from different directions should suffice. I've always used gloss black spray paint. I've also used everything from krylon fusion to cheap $0.99 paint with equal results.
-Brad
-'14 Tundra Crewmax Limited 4x4 (mine): 6112's, 275/65/20 Hankook Dynapro ATM, Leer 100XR cap, dual battery setup for fridge power.
-'12 T4R Limited 4x4 Blizzard Pearl (wife's): weather-techs for now. Will upgrade the suspension & tires when the tires wear out.
-'06 T4R SE 4x4: Traded for the '12
macgyver_ga is offline   Reply With QuoteReply With Quote
Old 10-30-2014, 02:30 PM #15
Real Name: Jason
Real Name: Jason
@Jesse1983 , @macgyver_ga , thanks for the replies, much appreciated. I'll hopefully be able to get to this mod in the coming weeks and I'll be sure to post pics
FS: "JDM" black housing corner lights and headlights, OEM 97 headlights WILL PARTOUT! spitvenom For Sale: T4R Items 15 07-02-2012 02:08 AM
**SOLD** 96-02 Black Retrofitted Projector HID Headlights and Black Corner Lights PhdNPrerunners Classifieds - buy & sell (no commercial ads please) 4 12-19-2010 10:08 PM
black headlights av8or 4th Gen T4Rs 6 04-10-2009 01:39 AM
WTB: 4th gen JDM black headlights Trik444 Want to Buy/Trade 4 07-07-2005 05:57 PM
