08-28-2013, 09:06 PM
'11 5th Gen 30K Svc - Do's/Don't
Ok, let me start saying that yes, I searched the Forum for about an HR for the answer b4 I posted this. I found nothing specific to the 5th Gen, hence the post.
Went to my local Stealership and got the print out for the 30K Service and this is what I was quoted for roughly $260 bucks. Obviously some of this is DIY but I'd like a 2nd/3rd/4th/Umpteenth opinion on the matter/service so I can save some $$$. I'm a baller on a budget.
Included Service - Per Stealer
BOLD TYPE = DIY
- 00TS1M: ROTATE TIRES
- 00TS1R: REPLACE ENGINE OIL & OIL FILTER
- 00TS2R: REPLACE ENGINE AIR FILTER
- 00TS3L: LUBERICATE PROPELLER SHAFT
- 00TS3R: REPLACE CABIN AIR FILTER
- 00TS6M: RE-TORQUE PROPELLER SHAFT BOLT
- OOTS8M: RESET OIL REPLACEMENT REMINDER
- 0TS4IN: INSPECT FUEL TANK CAP GASKET WTF DOES THIS MEANS???
- 0TS5IN: INSPECT FUEL LINES & CONNECTIONS, FUEL TANK VAPOR VENT SYSTEM HOSES, FUEL TANK BAND
- TS10IN: INSPECT BRAKE LININGS/DRUMS & BRAKE PADS/DISCS
- TS11IN: INSPECT BRAKE LINES & HOESES
- TS12: INSPECT BALL JOINTS & DUST COVERS
- TS16IN: INSPECT EXHAUST PIPES & MOUNTINGS
- TS19IN: INSPECT STERRING LINKAGE & BOOTS
- TS22IN: INSPECT STEERING GEAR BOX
- TS23IN: INSPECT AUTOMATIC TRANSMISSION FLUID
- TS27IN: INSPECT REAR DIFF OIL
- TS37IN: INSPECT ENGINE COOLANT
- TS43IN: INSPECT RADIATOR & CONDENSER
- TS44IN: CHECK DRVR FLOOR MAT
- TS45IN: INSPECT/ADJUST ALL FLUID LEVELS
- TS46IN: INSPECT THICKNESS MEASUREMENT & DISC RUNOUT
- (DD) DBRAKE: CLEAN/ADJUST & LUBE THE FRONT & REAR BRAKS….SPLG?
- (DD) DBUNDLE: BUNDLE DISCOUNT
If anyone can chime in on w/e I don't need, that'd be helpful. TIA guys!!!
08-28-2013, 09:19 PM
Knock out an oil change, replace your air filter if it needs it. Replace the cabin filter - should be simple - 4th gens were stupid easy. Rotate your own tires. You should be able to do it for less than $100. Paypal me $50 gift to feel better about parting with your money, [email protected] Wait for dealer to send you "free 21 point inspection" coupon or similar. They'll check the same stuff as they would in the service. Don't get me wrong - if I had the money, I'd have a dealer do everything to my truck but I don't so I do it all myself.
08-28-2013, 11:38 PM
Do what ever you know how and have the proper tools to do at home. I replaced all of my own air filters, lubed my joints, rotated and balanced my tires (free for me at Discount Tire) etc. I could have changed my own oil, but just didn't have the time. I also purchased my own fluids and provided them for the service as I figured it was going to cost me either way, might as well provide them with the good stuff to do it right (and probably for less money)
'01 SR5 Sport. 2nd gen TRD S/C, URD plugs (URD 7th and 2.2 on the way), B&M Tranny cooler, full length 5"height BajaRack, toytec ultimate front coilovers, ome 891/bilstein 5150 rear, toytec dif drop, SS panhard, shrockworks front with piaa 510 and IPF 900 (converted HID), 265/75r16 duratracs, 55w 4300k HID's, smoked LED tails, 20% film on all windows (except windshield), bluetooth/android obd2 reader/gauges.--- SOLD
2010 Shoreline Blue TE. KDSS, ARB, Warn 9.5xp, OME, Duratracs. TONS more to come on this one
08-28-2013, 11:53 PM
I just did my 30k service last week. It involved a $60 oil change at the dealer and $25 off Amazon for both the air and cabin air filter which took all of three minutes to change out. I just had new tires installed 2k miles ago so no need for rotation, but I'm like you and couldn't justify wasting money that could have been easily saved.
08-29-2013, 12:21 AM
When the dealer says "inspect" they mean the tech might look for stuff falling off the truck or dripping out when it's up on the lift. I guarantee they spend more time filling out their checklist than actually doing those "inspections". I do my maintenance myself because I simply don't trust the service techs. My dealer charges $70 for an OC and I've told him I would gladly pay them $100 for an oil change and lube if I was confident the work was being performed and the correct fluids/parts were being used.
2010 Trail - 156k mi - KDSS - Classic Silver Metallic - Bilstein 5100s - Tires: Michelin X-LT A/S 36psi - Oil: M1 EP 5W/30 - Diffs and T/C: Delvac 75W-90 Synthetic - Toyota WS ATF - ScanGauge - Viofo dashcam - Husky Weatherbeaters - Plasti Dip wheels and chrome delete - Wheel Center Caps delete - Roof Rack Cross Bars delete - Cargo Tray divider delete
08-29-2013, 06:15 AM
Valid point about the Fluids but here's a two-part question....other than the replacement oil (synthetic), what other fluids may I need to be concerned w/? Whats some recommendation for good Oil Brands/ManFctr?
Also, thanks guy for chiming in. My first YOTA and just trying to make sure I do her right.
Reason: Appreciation Notes
08-29-2013, 09:19 AM
Real Name: Um, Phil?
The two air filters are stupid simple to change. I was surprised at how dirty my cabin filter was. There was a thread about where to buy filters.
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
Reason: clarify
08-29-2013, 09:35 AM
Real Name: Sparky
Real Name: Sparky
Dealers don't "inspect" shit.
I had an "all green" inspection chart come back on a truck that had no washer fluid and ragged wipers.
08-29-2013, 10:47 AM
That's unfortunate truth sometime.
2011 4Runner SR5 4x4, Black, Sand Beige Leather, 3rd row.
AVS Bugflector II, OEM Mudguards, SPAREBUMPER SP424 - Black, Infinity Kappa 32.9cf Dash Speakers,
GY Wrangler Silent Armor, 265/70R17, Load C, Weathertech side visors, Husky WeatherBeaters, ~16.5 MPG
08-29-2013, 11:05 AM
Even if you do get a dealer tech that "inspects fluids" most of it is just seeing if the fluid is between the min and max. If you look up the procedure for inspecting your transmission fluid, it is basically just making there isn't ATF dripping from your transmission.....
The techs make their money by job, so it is within their best interest to complete your service as quickly as possible, which means skipping steps, and not really inspecting anything. They just do the bare minimum necessary to get you out the door.
08-29-2013, 05:09 PM
As far as brands, its all personal preference. I typically use Royal Purple and/or Mobile 1. They do engine oil, transfer case, differentials and maybe A/T (I don't recall. I supplied them with engine, transfer case and diffs.
08-29-2013, 06:28 PM
Unfortunately this is how it is in general... the "techs" that "inspect" the vehicle are mainly underpaid, overworked, and under educated "lube techs" who are paid hourly, but often over worked that they have to rush vehicles regularly (as is the case at our dealership and other dealerships.) Lube techs in general (and I mean no offense by this, its just what it is) are lowest paid, lowest educated technicans at the dealership. Many lube techs don't know much about cars at all (though many are often trying and/or training at the same time) but are for the most part not really "qualified" to properly inspect the vehicle.
What I mean by that is, that many lube techs wouldn't be able to tell the difference between a cracked/worn drivebelt, worn brake fluid, leaking timing chain tensioner, ect ect. That combined by the fact that many are forced to rush the oil changes and minor services and often skip large portions of the inspection sheets leads to very poor quality control... which is ridiculous since many technicans depend on the upsells from those inspections to make money.
Its just another example of corporate mis-management and backwards thinking; sort of stepping over a dollar to save a dime mentality that large corporations have gotten into.
