Originally Posted by LandCruiser
My wife is small and most days it reads "passenger airbag off."
Happens for both of my 4Runners, the dealer seemed stumped as to why--I'm guessing it's her weight (88-89 pounds).
Is this safe for her? I can't imagine a 100 pound person needing an airbag that much more than someone 10 pounds lighter. Should I just take her to Red Robin 2-3 nights a week?
The limitation is height as much as weight. They are assuming (rightly so) that short people like kids weigh less than average height people. Easier to do a weight sensor than a height sensor. Position of airbag deployment in relationship to the head and shoulders is very important. Not too high, not too low, etc. 90 lbs though should be enough to satisfy conditions. 66lbs comes to mind...
It's not as safe as having the airbag activated but rewiring to disable the weight sensor or bypassing ANYTHING in the airbag circuit is not a good option. Remember a few short years ago we had no airbags or even shoulder belts. The only time we used seatbelts was when 4 wheeling at a high rate of speed and that was only to keep from smashing our heads against the roof.
Easy enough to test though:
Have her get in and sit in her normal seating position, with vehicle started and her belted in.
Start adding weight (small 5lb barbells etc) until the light goes off. If it does not after a few barbells then there is a problem.
