09-10-2013, 02:25 PM
Help: Battery Suddenly Died
Anyone know the average lifespan of a battery in a 2010 5th Gen Trail? I don't have anything extra hooked up to it. The issue starting occuring after I had to leave my rear hatch open to load in some wood flooring I was moving to another place. Probably open for 30 minutes. No issues when I was moving or for a couple of days after, but I started noticing the other day a hesitation in the starting process. This morning was the same way but it started...drove into the office (45 minutes) pulled in and turned it off. Tried to start it again and nothing, lights come on, it's in park, foot on brake, just no juice to turnover.
Any ideas?
09-10-2013, 02:41 PM
Location: Mall Crawlin @ 36.1911° N, 44.0092° E,37.7460° N, 119.5329° W
Any ideas?
Bad Batt I'm guessing. Test it and if you need to replace it get the Die Hard Plt. It has been very solid for me.
Blue
0369
“Be polite, be professional, but have a plan to kill everybody you meet.”
Gen. James Mattis USMC
"AKA Mad Dog Mattis"
09-10-2013, 02:45 PM
Real Name: Gary
Real Name: Gary
Any ideas?
Lifespan.....Car batteries last an average of two thirds as long in hot climates as cold ones. Heat kills car batteries, especially sealed wet lead acid batteries like the one in the 4Runner.
Car batteries have memories......
Deep discharges or running it down while not charging can damage car batteries and will shorten their lives unless they were made for it as in a deep cycle battery.
Have it checked at Autozone or the like to make sure it's bad or just needs a full recharge.
2022 4Runner TRD ORP Army Green
2010 4Runner Limited -SOLDhttp://www.toyota-4runner.org/galler...m-harper7.html
. ...........Rest in Peace Seattle Mike................
2000 Black 4Runner Highlander Edition
2001 Tacoma TRD 5sp
09-10-2013, 03:27 PM
Real Name: Danny
Real Name: Danny
Just replaced mine at 45K. I was shocked as well when it happened, I had the stereo on for about an hour and completely drained.
I replaced it with a Kirkland (costco) battery and haven't had a problem since.
I also purchased my truck used, so who knows what the previous owner did.
Anyhow, just get it tested at autozon, if it's a good batt - have them charge it, if it's bad. $90 at Costco with 8 year warranty!!!! That's incredible if you ask me.
Good luck!
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
09-10-2013, 04:27 PM
Real Name: Matias
Real Name: Matias
Dual Battery time?
2013 Trail Edition - Magnetic Gray // KDSS // Nav // Pilot Stubby // Husky Liners // Canvasback // 5k Interior LEDs
09-10-2013, 05:36 PM
Originally Posted by Madiusmax
Dual Battery time?
If you need it. Otherwise just replace it with a deep cycle battery for half the price of a good dual battery setup.
2011 Trail Edition mostly stock, never wheeled
Instagram
Untitled Offroad
http://sittingbyariver.blogspot.ca/
09-10-2013, 06:06 PM
Yup, that's what I've experienced.
Since i moved to TX almost 9 years ago, all of my car's batteries have died in 3 years or less (usually less); Corrolla, Saab 9-3, & BMW 335. I bought my TE new in 10/2010 so I'm expecting it to go anytime.
It seemed weird the first time, but I'm used to it now.
2010 Silver Trail Edition KDSS, Nav
Dueler A/T Revo 2 LT265/70R17--Blaze Recaro Proride, forward-facing...Boom
09-10-2013, 06:36 PM
Did Toyota stop using the Panasonic batteries they used in the 4th gens? Original 4th gen batteries lasted many years, some members had 7 or more years on them. I live in the desert in Arizona (12 years) and I can not really say my batteries last any less longer than any cooler place I lived. The Optima in my 4runner is 6 years old and my Jeep Optima just died after 7.5 years. Just put an optima in it and be done with it. No more acid eating up the terminals with them as they age either and they take all the off road bouncing around with out failure.
09-10-2013, 06:51 PM
Real Name: Gary
Real Name: Gary
Same Panasonic batteries which in general are good batteries and the one in my 06 only lasted 4 years/80k miles.Many down south over on the FJ forum had them go out in 3-4 years too and a bunch of threads on it.
2001 Tacoma TRD 5sp
09-10-2013, 08:17 PM
Ok, just a battery, it was time I guess. Got in the car after a jump and saw the meter bouncing back and forth so I figured that was it. Had it all checked out and it was just gone. Just odd, my experience has been a noticeable issue coming, this just came out of nowhere.
09-10-2013, 09:33 PM
my 06 still has the OE panasonic battery.
i'll be replacing it in the spring with an Interstate...if it makes it through the winter.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
09-11-2013, 12:42 AM
Real Name: Joe Bloomstone
Grape Ape,
Dude....replace that battery now. I went thru 3 batts on my '97. The second one went dead and burned up my alternator...$350 for a re-furbished alt. Alternators don't do well carrying all the load to run your truck, and die fairly fast. A Battery will probly only cost you a little over $100. Better than getting a tow, and replacing Alternator and Battery.
2012 Trail Edition, Magnetic Grey, NAV, EnTunes, KDSS, Factory Running Boards, Stainless Exhaust Tip, HuskyLiner Weather Beaters, CravenSpeed Stubby, Toyota Emblem Black-Out, Ifinity Kappas throughout, LED Upgrade for Interior, LED Exterior: Tail/Brake, Reverse, Rear Turn, Front Turn/DRL, & Front Parking. Built-In Compressor (AntMan Style), Painless Fuse-Box, Cup Holders (AntMan Style), LED Under Hood Lights, NAV Override, Hella Horns x 4!!!
I've been a T4R owner since 1997....
08-24-2014, 02:24 AM
Good luck!
Resurrecting an older thread here. Came back from 10 day trip after driving down to Oakland from Seattle the precious Sunday. Truck worked fine for the whole trip down and didn't notice any issues. Came back today and the truck didn't beep with the unlock on the fob. Tried to jump it and the lights came on, starter clicked twice and the lights on the dash wouldn't even come on. Took it out, managed to get a ride to O'Reilly auto and it has a charge of 2.3v. I didn't bother with the load test as I had a million things to get done today and this was a major inconvenience. Replaced it with an optima yellow top. Hopefully no issues for at least the next 3-5 years. Just wanted to pass along. Oh and I passed 44k miles on the drive down from Seattle.
2012 Black SR5 4x4, Convenience Package, Auto Dimming/Backup Camera - AVS Vent Visors - Yakima Whispbar Through Bar cross bars - Custom Low Profile Cargo Drawer - Extendable Stubby Antenna - GrillCraft Grille with FJ Toyota Emblem and Matching Lower - 10% rear tint 24% front tint - Tekonsha Prodigy P3 Brake Controller -MetalTech Sliders - Wet Okole Seat Covers - LT265/70/17 Cooper AT3 Load C - Toytec BOSS lift - SOLD
2018 Ford Expedition Max Platinum (current mall crawler) My Custom Dog Crate/Drawer Setup
08-24-2014, 10:32 AM
Anyone with a 2010 is probably getting close. I replaced mine a couple months ago at around 45K miles. Wife left the vanity light on overnight and it needed a jump. had to leave it at the airport shortly there after and it was dead when I got back 3 days later (knew this would happen so i brought a jumper).
Rolling with a Group 31M diehard platinum now.
Okki
Okki's Build Thread - 2010 Limited: Shrockworks Rock Rails & Full Skids, Gobi Rack, OPT7 LED Roof LIGHT Bar, Rigid E-Series Bumper Light Bar, Hella Horns, Auxiliary Fuse Box, Cobra ST75, TRD Rims, Discoverer ATP LT265/70R17, Rotopax, ARB Twin Compressor, Cargo Area Pressure Gauge and Chuck, Icon billet trailing- and A-arms, Dobinsons Shocks/Coils, Fumuto Oil Valve, Northstar Group 31M, CBI Front & Rear Bumpers !!!
Any time...Anywhere.. My cat can take you.
08-24-2014, 10:38 AM
Very common in hot weather. The wife unit went to the store and came back. Car was sitting in driveway for 5 minutes. She had to go out again. No start. Took it to autozone. 2 Dead cells. The battery was the second I have put in her 2007 Maxima both last 3 years 2 months.
