04-30-2020, 05:41 PM
#676
I'll play...
OEM TRD Pro Wheels
Yokohama Geolandar G003 MT 285/75r17
2.5"/2" Burtman lift
1.25" Wheel spacers
BMC, trimmed bumper, liner pushed forward
No rub
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
05-03-2020, 11:11 AM
#677
Originally Posted by vegas4runners
Saw this thread and had to chime in.
Everyone knows the 5th gens don't do well with big heavy tires but everyone wants to be an overlander!
I have done it so many ways with so many sets of tires. 265/70/17's, 285's 33x12.5x17's, street ply, 8 ply, 10 ply.
The set up I have is hands down my favorite and I don't have to sacrifice almost anything.
Current set up:
Wheels: Gear Alloy Manifold 17 inch with a -12 backspacing (key for the look)
Tires: Falken Wildpeak AT P285/70/17
Only running a 2.5 inch front lift with a 1.5 in the rear. Zero issues with rubbing.
Love the because they are lite but still off road capable! Keeps the truck from being a tank!
My 4Runner is with the dealership. The 4Runner was already lifted and the tires that are installed are Toyo R/T Open Country 33x12.50R20LT. I have been having issues with the steering wheel shaking badly, and the dealership was informed by the company who did the lift, etc. that the 10 ply tires are the cause. The dealership is going to switch out the tires and gave examples of styles: Falken Wildpeak AT, Falken Wildpeak MT, or Nitto Trail Grappler AT.
Have you had any issues with the steering wheel shacking on the Falken?
05-04-2020, 03:04 PM
#678
Originally Posted by Motory
hey, I see you have the 9"/-38 wheels and 295's. what did you have to do to get that all to fit? Are the -38 wheels harder to fit than the -10s?
05-04-2020, 05:08 PM
#679
I had 1.25" spacers on my 17x8.5 -10s and the fitment of 17x8.5 -10 with 1.25" spacers is almost the same as 17x9 -38 so I didn't need to do a whole lot. If I didn't upsize to a 295 M/T tire and stayed with my 285 KO2s, I probably couldve gotten away with no additional cutting or trimming at all.
17x9 -38 and 295 M/Ts aren't that hard to fit as long as you have aftermarket UCAs and a good amount of caster.
What I've done so far:
- Lots of front bumper trimming and fender liner relocation
- Very aggressive BMC
- Trimmed black fender end cap and bent the metal tab behind it
What I still need to do:
- Upgrade bump stops: Found out after my last trip my tire is hitting the top of my fender at full articulation
- Upgrade to aftermarket UCAs: Only have 2 degrees caster, need more because the tire is rubbing the inside of my fender. You might not need to trim the black fender cap or bend the metal tab if you already have UCAs and lots of caster
Honestly, if you do all this, you could probably go even bigger than 295s and get away with it.
2016 4Runner
Aesthetic: Prinsu + JOE SLAPS, C4 Ladder, Shrockworks Sliders, Rago MSP + Shelf
Suspension: King 2.5 650lb w/ Adjusters, Dobinsons C59-327
Wheels: SCS Ray10 17x9 -38, 35x12.50r17 Yokohama Geolander M/T
Other: Custom Detours of Main Spare Tire Carrier, Freespirit Odyssey 49"
05-04-2020, 05:35 PM
#680
Originally Posted by mstein66
...and the dealership was informed by the company who did the lift, etc. that the 10 ply tires are the cause.
10 ply tires have nothing to do with the shaking. Balancing is usually the issue on any tire. Occasionally I think it is a wheel problem. 4Runners are very finicky when it comes to balancing. They have to be done almost perfect. Get a road force balance and make sure the people balancing them know what they are doing.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
05-04-2020, 07:27 PM
#681
cool thanks. how much lift do you have?
05-04-2020, 08:02 PM
#682
cool thanks. How much lift do you have?
3"/2"
2016 4Runner
05-06-2020, 04:39 PM
#683
Fuel D689 17x9 -12
Wildpeak AT3W 285/70/17
Bilstein 1.75" up front, 1" spacer rear
Got a little bit of rubbing I'll have to take care of
05-06-2020, 11:44 PM
#684
Real Name: Don
Real Name: Don
I’m having issue with my Pro after adding new Falkens 10ply. My tire guy said it should not matter being a 10ply. No issue before I removed my Pro wheels and tires. I’m taking it back in to my tire guy. I stayed with stock size tires but he is going to put another new set of tires on the front. When I hit about 50 or 55 wheel shakes just a little bit it will not go straight. Soon as I leave go of the wheel it want to pull to the right. I deal with the same tire place for years. Not worried he will get it corrected. Just not sure if it is the wheel and tire is not balanced or if I have a bad tire on the front. My other Pro wheels and tires no issue.
05-07-2020, 11:50 PM
#685
I’m having the rubbing issue here as well. Just put 1.25” spacers on and have 285’s. Are you saying to get an alignment with max caster (I have aftermarket ucas) and a little trimming up front and I should be good?
05-08-2020, 02:34 AM
#686
You should be good. I ran 1.25" spacers on 17x8.5 -10 with 285s on stock UCAs and only 2 degrees of caster and did not have any issues with the tire rubbing the plastic fender, only the body mount. How much caster are you currently running?
2016 4Runner
05-08-2020, 01:22 PM
#687
anyone have experience with Summit Offroad?
21 pounds and $175.
for the record, I haven't been able to get a single response from this company via their website, email, or instagram in over a week. Just asking about basic fitment before I purchase. They are very active on their instagram, posting marketing photos constantly, but have yet to respond to either comments or messages asking basic questions. Doesn't exactly instill confidence about buying their product. Also, one of their main "influencers" (guy that owns the above white 4runner) posted a video today showing that he runs spacers to get the stance width I wanted, for whatever that's worth.
05-08-2020, 03:30 PM
#688
Any 5th gens on here running the new(ish) Kenda Klever 35x10.5x17? Good reviews so far, plus Walmart has them for like $750 out the door after tax and some Tacoma guys seem to like them.
Would love to see some pictures if anyone has them.
05-08-2020, 04:36 PM
#689
Here's mine on 295/65/18's, Volk Racing 18x9.5 wheel.
2018 TRD Pro - Cavalry Blue
05-08-2020, 06:50 PM
#690
2015 Nautical Blue Trail Premium 4WD w/KDSS
2016 Magnetic Gray Limited 4WD
2000 Land Cruiser
