Old 02-01-2023, 02:27 PM #1
Lexington's Avatar
Lexington Lexington is offline
Lexington is a jewel in the rough Lexington is a jewel in the rough Lexington is a jewel in the rough
Lexington's Avatar
Another Rotor Question
Out of curiosity, does anyone know how much a new pair of brake pads will shave off the rotors during the life time of the pad, .02mm, .05mm, 1mm?
Thanks
Darrell
Lexington is offline   Reply With QuoteReply With Quote
Old 02-01-2023, 05:01 PM #2
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
That is impossible to answer. You can narrow down to some answers if you control variables such as duty cycle, rotor material, pad material, some others and then run empirical tests…
How many licks to the center of a tootsie pop?
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 02-01-2023, 05:23 PM #3
Lexington's Avatar
Lexington's Avatar
Yeah I know there are a lot of variables such as driving habits and break pad types and so on. I should have mentioned that I’m asking about the stock OEM rotors and break pads. Anyway I was hoping someone might have measured wear on their own rotors. It would be at least give me a ballpark figure on how long my current rotors are good for. I have a little more than 18mm and the replacement minimum is 16mm. I figured they are good for at least one more set of pads, maybe two.
Old 02-01-2023, 09:14 PM #4
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
I have a 2014 LE with 58K on the clock with original rotors and pads, I probably have close to 5 mm left on the pad and the rotors barely look worn. These are probably 90% hwy with light towing maybe 2X a year.
Ezlife45 is offline   Reply With QuoteReply With Quote
.02mm , .05mm , 1mm , pad , time
Rotor size question HomerJay 4th Gen T4Rs 43 02-20-2021 01:20 PM
OEM Tundra Rotor Question... Scramble 3rd gen T4Rs 3 07-17-2016 11:52 AM
5th gen T4R brake rotor question 10ac 5th gen T4Rs 3 06-08-2016 08:20 AM
Brake rotor question wader 5th gen T4Rs 5 02-03-2015 10:56 AM
front rotor question??? jamesek9 3rd gen T4Rs 4 03-22-2006 08:42 PM
