11-15-2014, 11:58 AM
Air outlet noise
'14 SR5 Prm
20 degrees. This morning as my vehicle was warming up I changed the air outlet from blowing heat to the main area to blowing down to the floor. When I did this I heard some buzzing which lasted 4-5 seconds and it was coming from behind the dash. So I tested it out. I kept switching it from one to another, back and forth...same noise was heard.
After 5-10 minutes of driving the noise finally went away. Is this normal?
'14 4Runner SR5 Premium
11-15-2014, 12:33 PM
Real Name: Um, Phil?
Check your cabin air filter.
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
11-15-2014, 12:51 PM
sounds like the servo has an issue.. usually this only tends to happen on high mileage cars. have the dealer check it out.
2011 TE KDSS NAV- K&N drop-in, Toytec/Eibach, Bilstein 5100's, Diff Drop, 295 Cooper STT Pro, OPOR Sliders, 17X9 XD Addicts, Sonoran Steel Panhard Bar, SPC UCA, RCI Skids
'97 Corolla, 90 Alltrac Celica, 94 Camry, 99 Solara 5spd, 98 GS400, 93 Accord, 97 Avalon(current daily), 2010 T4R LE sold, 2011 T4R TE
11-15-2014, 12:52 PM
Air outlet noise
I only have 3k miles. I just don't want to make an unnecessary trip to the dealer if it's normal.
11-15-2014, 01:57 PM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
Sounds like a piece of dried leaf in the cage.
11-15-2014, 02:15 PM
Real Name: Greg
Real Name: Greg
Originally Posted by 4Run14
"After 5-10 minutes of driving the noise finally went away. Is this normal?..."
Hi 4Run14,
There may be a pneumatic servo (w/linkage, blend doors...etc) in the dash that is noisy due to lack of use and radical temp changes. Continue to exercise the climate control system and allow the control modules to 'break-in'; the sound should become less noticeable across time. rgds!
rigtec, cheers
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
11-15-2014, 03:51 PM
Real Name: Jeff
Real Name: Jeff
My bet is on a leaf as well.
HERE FISHY FISHY FISHY!
11-15-2014, 05:09 PM
So far I haven't heard it come back and it did get really cold here recently.
11-15-2014, 06:54 PM
when they do start to go bad, it starts in the real cold weather then a yr or so down the road it'll do it all the time.. mine had went out in my lexus.. sounded like mice scratchin' back there.. if it goes away and never comes back, it was probably a leaf
11-15-2014, 07:11 PM
Thanks
11-15-2014, 09:58 PM
Real Name: CJ
Real Name: CJ
Make a note and have them check it during your 5k service.
2014 Trail Edition -
Build Thread
2015 Epic in my own mind trip
11-15-2014, 10:45 PM
I'm pretty sure you meant 10k.
11-15-2014, 11:09 PM
Real Name: Swartwood
You're wasting OPs time telling the dealer to check it. If he can't make it happen for them they won't do anything.
10 TE - KDSS - Icon Suspension - 285/70/17 Hankook MTs - 4.56 nitro Gears - URD equal length headers
Shrockworks front bumper and sliders - MT Rear bumper- RCI aluminum skids - Dif breather mod - K9 Rack - Warn 10S Winch
Come ride with me: PDX 4X4
11-15-2014, 11:16 PM
Real Name: Karl
Real Name: Karl
Your Toyota care service intervals are at 5k. They change oil at 10k but do a general service on the 5k intervals.
2016 Barcelona Red Trail
Its 5:00 somewhere.
WARNING: T4R.ORG IS HAZARDOUS TO YOUR WEALTH
