Originally Posted by Bloody14KDSS
Hello 4Runner gods,
I have a 2014 Trail KDSS. I'm running SCS Stealth 6 wheels and yes, they are beautiful. Lol. I'll b adding a Toytec 3" lift BOSS system. The great guys at Red Line Landcruisers down in Colorado Springs will perform the lift install (Great guys).
Considering my wheel size (17x8.5). Which size of Duratracs Ican be safely install without rubbing? I won't cut or do any sort of lining mod. If I touch it, I'll brake it. I'm a gorilla. Plz keep in mind I've been using the search button.
Best regards,
Thanks in advance.
*I believe the size chart below was made for stock wheel sizes*
If you want to run DuraTracs without rubbing on a 17" wheel regardless of width you need to keep stock size (265/70/17). They only come in stock size and 285/70/17. If you go with 285s they will rub without any fender mod.
There are several people here who run 265/70/17 DTs with a 3" lift and IMO it looks great since the DT is a pretty aggressive AT tire (@Antman is the only one that comes to mind right away - see his build thread for pics). Pics can be found in the lifted pics thread. I don't remember the pages though you'll just have go through it.
Truck looks good BTW
