Old 01-20-2014, 06:25 PM #1
Antman's Avatar
Antman Antman is offline
Real Name: Jeff
Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all
Antman's Avatar
Real Name: Jeff
**How To Change 5th Gen Factory Wiper Blade Inserts - Pictorial
My factory wiper blades bit the dust today after almost 60k miles. Impressive! I cannot ever remember having wipers that worked this well for this long. As many of you know, I change just about everything on my vehicles, LOL, so it may come as a surprise that I am using factory replacements. They work!!
I figured I would throw this quick how-to up for those that aren't aware of how easy this is. Lord knows what the dealer is charging to replace the inserts. Do it yourself and same some dough. I paid $23 for both inserts, but I'm sure you could order them online cheaper. I needed replacements ASAP with snow on the way!
These are the part #'s for the wiper inserts. The driver's side (6140) is a little longer.
The easiest way to change these is to remove the wiper from the wiper arm. Both sides remove and install exactly the same, but do one side at a time so you don't mix them up (remember driver's side is longer).
The following shows the passenger side wiper...
Pull up on this hinged tab with your finger.
Lift up slightly on the arm and slide the wiper down the arm a little bit.
The wiper will slide off the hook of the arm.
This is the worn out blade.
Locate this end of the wiper. The rubber is wider and you can see where the frame is holding the rubber in place.
Squeeze the rubber and pull the blade out. (DO NOT squeeze the metal rods, or any part of the frame!), just the rubber blade. It doesn't matter if you rip the rubber, it's trash anyway.
Take a good look at the old blade and the new blade. Situate them so they are facing the same direction.
Remove the metal rods from the wiper blade and insert them into the new blade.
This is the new blade before and after the metal rods are installed.
Start to slide the new assembly back into the frame. The thinner end goes in first.
This picture shows the blade NOT fully seated.
This is the fully seated (done!) wiper blade.
Time to re-install the assembly.
Line the wiper up with the arm like this.
Slide the wiper down the arm and then back up the arm so the hook falls into the hole on the wiper .
Close the tab by pressing firmly into place.
Now do the same thing for the other side. All done!
Wasn't that easy? 10 minutes at most!
HERE FISHY FISHY FISHY!
Antman is offline   Reply With QuoteReply With Quote
Old 01-20-2014, 06:45 PM #2
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light
Moderator
1engineer's Avatar
Real Name: Greg
I do agree. Light bulbs, wiper blades and brake pads that are OEM Toyota are also the most reliable and durable replacement.
1engineer is offline   Reply With QuoteReply With Quote
Old 01-20-2014, 06:46 PM #3
Go JayBee's Avatar
Go JayBee Go JayBee is offline
Real Name: Joe Bloomstone
Go JayBee is on a distinguished road
Go JayBee's Avatar
Very nice write-up. I've been doing this for years. Most folks think the whole arm needs replacing. I usually replace the inserts each year at the end of summer, getting ready for the wet winter and spring here in the PNW.
2012 Trail Edition, Magnetic Grey, NAV, EnTunes, KDSS, Factory Running Boards, Stainless Exhaust Tip, HuskyLiner Weather Beaters, CravenSpeed Stubby, Toyota Emblem Black-Out, Ifinity Kappas throughout, LED Upgrade for Interior, LED Exterior: Tail/Brake, Reverse, Rear Turn, Front Turn/DRL, & Front Parking. Built-In Compressor (AntMan Style), Painless Fuse-Box, Cup Holders (AntMan Style), LED Under Hood Lights, NAV Override, Hella Horns x 4!!!
I've been a T4R owner since 1997....
Go JayBee is offline   Reply With QuoteReply With Quote
Old 01-20-2014, 07:26 PM #4
mace.'s Avatar
mace. mace. is offline
mace. is on a distinguished road
mace.'s Avatar
I go with the OEM refills also. Some may come across dealers like mine that don't stock every length and just give you longer ones which need cut to length. Plan for and additional 7secs for install time.
mace. is offline   Reply With QuoteReply With Quote
Old 01-20-2014, 10:17 PM #5
G8RB8_12SR5 G8RB8_12SR5 is offline
G8RB8_12SR5 is on a distinguished road
Just went with these today during my 40k service. They replaced them for $7 a piece and did it for me and at no charge since it was through the course of the service. They went through 3 PNW winters and springs plus lots of bugs in Cali and were just starting to streak, so when they said hey do you want to do this, I had no problem.
2012 Black SR5 4x4, Convenience Package, Auto Dimming/Backup Camera - AVS Vent Visors - Yakima Whispbar Through Bar cross bars - Custom Low Profile Cargo Drawer - Extendable Stubby Antenna - GrillCraft Grille with FJ Toyota Emblem and Matching Lower - 10% rear tint 24% front tint - Tekonsha Prodigy P3 Brake Controller -MetalTech Sliders - Wet Okole Seat Covers - LT265/70/17 Cooper AT3 Load C - Toytec BOSS lift - SOLD
2018 Ford Expedition Max Platinum (current mall crawler)
My Custom Dog Crate/Drawer Setup
G8RB8_12SR5 is offline   Reply With QuoteReply With Quote
Old 01-20-2014, 10:31 PM #6
JayceeP's Avatar
JayceeP JayceeP is offline
JayceeP is on a distinguished road
JayceeP's Avatar
Awesome! Thanks.
Not sure if I'll keep the OEM wipers or not though. My passenger blade always seems to ice up in winter weather causing lots of smearing on the passenger side... even with the de-icer on and the wipers bumped up over the windshield vent. Not a big deal, just more of a nuisance having to get out in crap weather to snap the blade/wiper.
2012 Shoreline Blue LE 4WD w/ 3rd Row.
JayceeP is offline   Reply With QuoteReply With Quote
Old 01-20-2014, 10:53 PM #7
ShAwTWiN ShAwTWiN is offline
ShAwTWiN is on a distinguished road
Talking
Originally Posted by JayceeP View Post
Awesome! Thanks.
You're not alone!! The only thing I found that help... is to "crack"/flex the wiper before I go.
Hello from Québec City (Canada)!
2010 Toyota 4runner Trail Edition magnetic grey
ShAwTWiN is offline   Reply With QuoteReply With Quote
Old 01-21-2014, 01:25 PM #8
eddiebx's Avatar
eddiebx eddiebx is offline
eddiebx will become famous soon enough eddiebx will become famous soon enough
eddiebx's Avatar
Originally Posted by Antman View Post
No excuse for wearing it this far!
Thanks for taking the time to document this, very simple, yet way overlooked maintenance procedure. I pains me to see people toss the ENTIRE wiper arm in the trash for a new one when you can just replace the rubber insert!
eddiebx is offline   Reply With QuoteReply With Quote
Old 01-21-2014, 01:43 PM #9
Intruder's Avatar
Intruder Intruder is offline
Intruder will become famous soon enough
Intruder's Avatar
Heh, I've done this so many times now that I don't even take the wiper off the arm. I just stand with one foot on a slider and the other on the front tire and slide the blades out.
I tried some different aftermarket wipers for this same reason and found they were no better. Plus, since the aftermarket ones have different adapters to attach to different styles of arms there was some additional wind noise at highway speed - I think the RainX ones were the worst for this with an actual whistling sound. Luckily I kept my OEM ones and went back to them.
2011 Trail Edition mostly stock, never wheeled
Instagram
Untitled Offroad
http://sittingbyariver.blogspot.ca/
Intruder is offline   Reply With QuoteReply With Quote
Old 01-21-2014, 02:11 PM #10
nashman69g's Avatar
nashman69g nashman69g is offline
Real Name: Marshall
nashman69g is on a distinguished road
nashman69g's Avatar
Real Name: Marshall
The front ones are easy to replace...I had a PITA time trying to install the rear wiper. Keeping the arm in the proper grove was a challenge.
Current cars: 2010 4Runner Shoreline Blue Limited 4X4 3rd row & Nav, 1994 RX7, 1978 F-150 4-WD (this is the work/mud ridin truck-needs some work though)
Cars owned: 1994 Integra, 1988 RX7 TII, 1987 RX7 base, 1990 RX7 GTU, 1985 Ford LTD (first car-biggest piece of crap). FSM+EWD here
nashman69g is offline   Reply With QuoteReply With Quote
Old 01-21-2014, 06:11 PM #11
Jpm1609 Jpm1609 is offline
Real Name: Jim
Jpm1609 is on a distinguished road
Real Name: Jim
This was very timely. I did mine yesterday. The guy at the dealer did the switch for the refills as I said I didn't have faith in them. Took him all of 30 seconds. Took a lot longer for me to put them back on.
Jpm1609 is offline   Reply With QuoteReply With Quote
Old 01-21-2014, 08:00 PM #12
Hawaiian4runner Hawaiian4runner is offline
Hawaiian4runner is on a distinguished road
Great post! Who'd have thought that wiper blades could generate such interest. I agree. The OEM blades last forever. I was about to buy new blade/arm combo cause of all the marketing hype saying you should change the arms cause the spring wears out etc. Was even researching this crap on the internet and you would not believe the hype companies can create for stupid wiper blades. Thanks.
Hawaiian4runner is offline   Reply With QuoteReply With Quote
Old 01-22-2014, 07:30 PM #13
Go JayBee's Avatar
Go JayBee's Avatar
I just did the rear blade recently. As I remember, just had to wait till the arm was straight up & down, turn ignition off, and just flop the arm backwards almost all the way. Then it was cake to slide out the insert and replace with new.
Oops, my bad, there is no way to flop the arm backwards. I must have just struggled with the new insert, cuz I don't recall taking the arm off.
Last edited by Go JayBee; 01-23-2014 at 12:32 PM. Reason: Should always look before I leap.
Old 01-28-2014, 07:48 PM #14
Mtn.Rush Mtn.Rush is offline
Mtn.Rush is on a distinguished road
Perfect instructions Jeff. Just changed the fronts and back on the cruiser within 5 min. Thank you sir.
2011 Land Crusier - Black
2010 Limited - Blizzard Pearl
2008 Limited V8 - Shadow Mica
1996 SR5 - Natural White
1994 SR5 - Garnet Pearl
Mtn.Rush is offline   Reply With QuoteReply With Quote
Old 03-27-2015, 09:38 PM #15
young young is offline
young is on a distinguished road
what is the part number of the rear wiper blade?
would be great if you add instruction on rear wiper replacement with alot of pics!!
young is offline   Reply With QuoteReply With Quote
Wiper Blade Change westwind77 5th gen T4Rs 23 10-02-2012 09:44 PM
WTB Wiper-Blade End Caps 4Running Daily Want to Buy/Trade 0 12-28-2011 03:42 PM
OEM wiper inserts are the wrong size Mabuse 4th Gen T4Rs 4 11-12-2009 07:33 PM
OEM Wiper Inserts TitaniumToy Maintenance/Detailing 2 07-16-2008 02:49 PM
Wiper Blade Changes mav75 Maintenance/Detailing 17 03-13-2006 04:46 PM
