04-01-2019, 08:57 PM
#316
Originally Posted by chrissurfr
Rig looks awesome man quick question did you have any fitting issue with swaybar against TRD front skid, after moving swaybar forward and down to install king bracket? Thanks in advance
04-16-2019, 10:39 PM
#317
Just ordered king front extended travel coilovers with adjusters and 600# springs, dirt king boxed uca's icon 2" coils and rear king extended shocks with adjusters from @totalautomotiveperformance !!! Hope they get here in less than 4 weeks! Although my FN FX wheels wont be until the end of may.... maybe it will all be perfect timing!
05-27-2019, 11:15 AM
#318
Clearance issue uca and reservoir bracket
I got my suspension installed and it is fantastic.
However my dirt king boxed uca is touching the reservoir bracket on the drivers side.
I am thinking I can just ream out the mounting holes of the bracket unless someone has another idea.
05-28-2019, 01:29 PM
#319
Finally got my kings, just need to install them. Curious to seeing what people are paying for install?
05-28-2019, 01:44 PM
#320
Real Name: Josh
Real Name: Josh
Where in socal are you? I paid $660 here in san diego.
2017 TRD Off-Road -- Dobinsons 3/2 Lift w/ Camburg UCAs, Method 701s, Falken Wildpeaks AT3W, SSO Roof Rack, Xenon HID Low / LED High, Cali Raised LED, N-Fab Nerfs, Pro Grill
05-28-2019, 02:17 PM
#321
I'm near the Corona area, not too far from SD. hmm...that seems to be the going rate.
05-28-2019, 03:01 PM
#322
Real Name: Josh
Real Name: Josh
yeah it is, i touched base with all the shops out here to include ORW and 4WP. Most were in the $1100 range with alignment. The shop i went to is "The Truck Shop"
The Truck Shop
07-10-2019, 05:16 PM
#323
Guys do any of you know how much does it cost to refurbish Kings? I have an opportunity to purchase a set of Kings w/o compression adjusters with about 20k miles on them and Total Chaos UCAs for $2k OBO. I was just trying to figure out if that's a good deal given the mileage or if buying them new would be the better route.
07-10-2019, 05:49 PM
#324
I got my set from @totalautomotiveperformance for $2700 brand new...
07-10-2019, 06:34 PM
#325
Depends how they were used, but 20k isn't much. Unless they are leaking, they are probably good for at least another 30k.
shock rebuild kits run ~$20 a shock
shock shaft ~$60 each
shock lower bearing ~$20 each
shock oil $35 a gallon (probably good for 4 OEM size shocks)
UCA Bushing kit ~$60
UCA uniball kit ~$180
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
07-10-2019, 07:16 PM
#326
Check out YOta masters, 88 Rotors, or RPM Garage too!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
07-15-2019, 10:54 AM
#327
Thanks man, I actually installed them a few days after that post.
08-17-2019, 12:35 AM
#328
Originally Posted by eccentricGTSdvr
top three vendors where i can purchase King Shocks?
old thread; but i went with Accutune when i purchased my King shocks. great customer service and they will tune your shocks to your specific needs for free if you purchase through them. They still tune shocks for a fee if purchased outside.
08-17-2019, 12:39 AM
#329
check out Accutune off road, they service shocks; if you purchase shocks through them they will tune it to your specific needs for free.
08-18-2019, 01:41 AM
#330
Is anyone running 600lb springs at zero preload? How much lift would that get? I would like to keep the lift to a minimum but wouldn't want the 550 spring in their OEM series.
Currently have 6112/5160 set to ~1.6" in the front and a 10mm spacer in the rear giving a 1.25" rake. I'd like to keep it close to that if possible - not looking to run a 3" lift, but I want to keep the 600lb spring I am familiar with in the 6112 setup. If the King setup gave a 2" lift that would be perfect, but I have a feeling the 600lb spring will give more than that even at zero preload.
