Old 02-18-2014, 07:03 PM #1
Helix26404 Helix26404 is offline
Real Name: Preston
Helix26404 is on a distinguished road
Real Name: Preston
JBL Amp Wiring Diagram
I'm looking to install a new amplifier inline with the JBL amplifier, but need a wiring diagram to see which lines to tap for the high-to-low level converter. Does anyone have a diagram or know where I can find one?
2010 Toyota 4Runner Limited 4WD
285/55/20 BFG ATs (stock wheels) | Bilstein 5100s
ARB Deluxe Bar | Warn M8000 | Lightforce 170s
Yakima Megawarrior
Helix26404 is offline   Reply With QuoteReply With Quote
Old 02-18-2014, 09:21 PM #2
Hawaiian4runner Hawaiian4runner is offline
Hawaiian4runner is on a distinguished road
See if this helps
Hawaiian4runner is offline   Reply With QuoteReply With Quote
Old 02-21-2014, 04:01 PM #3
Real Name: Preston
Real Name: Preston
This is fantastic! Are there any notes available for what the abbreviations mean? See picture.
JBL Amp Wiring Diagram-unnamed-jpg
Yakima Megawarrior
Old 02-21-2014, 04:41 PM #4
OldSchool1959's Avatar
OldSchool1959 OldSchool1959 is offline
OldSchool1959 is on a distinguished road
I'm going to hazard a guess informed by looking the image in the context of your post.
TWL+ = Tweeter left positive
LH = Left hand side
RH = Right hand side
I would caution against wiring a second amp inline with your existing amp especially if stereo schematic abbreviations are foreign to you.
OldSchool1959 is offline   Reply With QuoteReply With Quote
Old 02-21-2014, 08:40 PM #5
It's pretty straight forward. F = front. These are the front door speakers. TW = tweeter. These are on the dash. R = Rear and/or Right but it's pretty clear which one. The only area that is a little confusing is the Front Right speaker. I did not have this diagram when I did mine but now I think either I screwed mines up a bit but it doesn't matter or i got lucky and spliced before any of the other lines that run to the Telematics Transceiver (what the hell is that anyway?). Everything works perfectly fine so I probably preserved the wiring to the Telematics crap when I spliced.
Old 02-23-2014, 11:41 PM #6
Real Name: Preston
Real Name: Preston
Thanks for all of this. I *think* the telematics receiver connected to that speaker is the Bluetooth cell phone speaker interrupt when you get or place a call? In my vehicle I get audio only from the front left dash speaker. I am assuming this is what the telematics controller is doing.
I am assuming I cannot get a line-level signal from the HU here, completely bypassing the amp? I'm afraid it would affect my Bluetooth, etc. With the equipment I'm using (JL Signal Summer and DSP), I can take the high-level, shape it, and output it correctly, but it would be nice to have it coming as a low-level signal...
Yakima Megawarrior
Old 02-23-2014, 11:42 PM #7
Real Name: Preston
Real Name: Preston
Also one more thing. I see other posts that reference the front speakers being connected in parallel. This diagram doesn't reflect this, UNLESS those connections are being handled internally in the amp??
Yakima Megawarrior
Old 02-24-2014, 01:49 AM #8
The non premium systems speakers are in parallel.
Old 02-24-2014, 04:34 PM #9
Real Name: Preston
Real Name: Preston
Thanks. Do you know if the front dash speakers get full-range signals? I didn't think they would be full-range until I saw the bass blockers on them, which confused me since the signals are coming on discreet wiring from the amp...
Yakima Megawarrior
Old 02-24-2014, 04:49 PM #10
Real Name: Preston
Real Name: Preston
LH = Left hand side
With respect, I know exactly what I'm doing. In order to keep the factory HU and all associated factory features (AUX inputs, steering wheel controls, Bluetooth audio), I am taking the amplified signals from the JBL amp and placing a JL CleanSweep Signal Summer inline to achieve summed F&R stereo outputs.
From there, I am routing the summed signals to the JL CleanSweep DSP, which will normalize the EQ and provide me with true full-range outputs to send to a JL amplifier. The JL amplifier will output back into the factory wiring where passive crossovers will ensure the right output frequency range to the right speakers.
Thanks for your help on the abbreviations. I should have caught those myself, but as it turns out was staring at the wiring diagram for too long too late into the night.
Yakima Megawarrior
Old 02-24-2014, 06:26 PM #11
Dash speaker receives high pass signal only. Bass blocker on speaker is for the tweeter. Is that what you were referring to?
Old 02-24-2014, 06:46 PM #12
Real Name: Preston
Real Name: Preston
Yes, thanks. I think what I will have to do then is sum the front 4 speakers into one unified stereo front to ensure I get the full frequency spectrum.
The only negative I can think from this approach is that I will have the phone calls in BOTH driver-side front speakers, rather than just the dash speaker currently. I'm not sure this is even a negative.
Thanks for your help here. I am planning on writing up a full, detailed how-to on this for those who want to keep their factory nav HU, but want the added flexibility of an external amplifier and full-range outputs so that component system users can have exactly what they need to get the sound they want.
Yakima Megawarrior
Old 02-24-2014, 07:48 PM #13
I sure didn't mean to offend. Sounds like you have it handled. Good luck with the process and enjoy the new sounds!
Old 02-25-2014, 12:50 AM #14
Real Name: Preston
Real Name: Preston
No worries! Thanks!
Yakima Megawarrior
Old 02-25-2014, 09:58 AM #15
sandcrawler's Avatar
sandcrawler sandcrawler is offline
sandcrawler has a spectacular aura about sandcrawler has a spectacular aura about
that would be a really nice addition to the forum knowledge-base. looking forward to your writeup.
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
sandcrawler is offline   Reply With QuoteReply With Quote
wiring diagram zoohome18 4th Gen T4Rs 0 09-21-2011 07:53 PM
Wiring Diagram? bmwm3owner General Discussions 0 08-13-2008 02:24 PM
JDM WIRING DIAGRAM 94 3vz K_Labs Classic T4Rs 0 06-20-2007 04:46 PM
Wiring Diagram chiraz111 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 05-27-2006 05:46 PM
Looking for a wiring diagram (4th gen) Hitman 4th Gen T4Rs 4 02-08-2005 10:28 AM
