Originally Posted by N/A
in hindsight it was a pretty vague question
I assume when they list independant upper and dependant lower that means the top part of the switch if always lit and the bottom is only lit when on?
You are correct. Independent LED's can be wired however you like, with the dash lights, or ignition only for instance.
Some of our switches have green indicator lights when they are "on", so you could go with amber independent, green dependent for a more factory appearance.
They are nice switches- they make custom switches too if you ask them, and for really cheap.
