Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 07-24-2018, 11:48 PM #286
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Originally Posted by Phil Frames View Post
Sure enough I swapped my green and red wires and the illumination is working properly (and so are the lights).
Takeaway is that the Saker diagram most importantly shows the correct pin position top to bottom of the AOB switch and the wire color is secondary thanks to some suspect qc by AOB. I obviously did not realize the diagram was also showing actual wire positions not just color.
Thanks for taking the time to respond.
No worries, glad you got it sorted out.
Originally Posted by Yinzer View Post
I can also confirm AOB switched the colors. My switch came with an updated wiring diagram reflecting the change. Does not seem to be a QAQC issue.
So you have documents showing red & green switched in the pins and red connecting to 12V and the green connecting to the #86 on the relay?
Hope I am understanding that correctly....
Best Regards,
Saker
Old 07-25-2018, 07:30 PM #287
Yinzer Yinzer is offline
Yinzer is on a distinguished road
Exactly correct. It seems AOB made an intentional change.
Yinzer is offline   Reply With QuoteReply With Quote
Old 07-31-2018, 01:26 PM #288
jasonaaron480's Avatar
jasonaaron480 jasonaaron480 is offline
jasonaaron480 is on a distinguished road
My install Video
Hey there, I just wanted to share the video I made doing this hidden LED bumper bar using the Rago Fabrication brackets.
Check it out.
Hidden LED bumper light bar installation video
LED LIGHT BAR INSTALL on a 2014 T4R-backgrounder-1-jpg
jasonaaron480 is offline   Reply With QuoteReply With Quote
Old 07-31-2018, 02:35 PM #289
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Originally Posted by The Waco Kid View Post
I didn't use Saker's diagram, but I can confirm that the latest round of AOB switches coming out have the wire colors reversed (Green and Red) from those that were produced when this write up was written.
I had the same issue with mine, I wired my second switch up the same as my first and ended up having to reverse those 2 wires to get the switch to work properly
Old 07-31-2018, 02:36 PM #290
Real Name: Chris
Real Name: Chris
Check it out.
Love your videos bro, I watched the bumper removal probably 5 or 6 times before taking my bumper off. Thanks!
Old 07-31-2018, 03:45 PM #291
Thanks man, I really apreciate that! I'm glad they are useful videos and hope they help many people on here! thank you for the comment!
Old 07-31-2018, 03:56 PM #292
Real Name: Chris
Real Name: Chris
Thanks for making them. I've watched them all, you really make me want to get a switch pro!
Old 07-31-2018, 04:15 PM #293
NCArcher NCArcher is offline
NCArcher is on a distinguished road
Check it out.
To bad Rago has gone up so much on these brackets. 60 was a stretch, but 85 is. . . to much. Cali Raised still has theirs at 60. I prefer to the Rago mounting point but not worth the extra to me. Great video!
NCArcher is offline   Reply With QuoteReply With Quote
Old 12-25-2018, 11:51 AM #294
MMK21's Avatar
MMK21 MMK21 is offline
MMK21 is on a distinguished road
MMK21's Avatar
The purpose of this write-up is to help people that are interested in installing a light bar behind the grill of their 2014 Toyota 4Runner. I will list the parts used as well as pictures.
For the cleanest install, I'd recommend a full relay harness. TRS makes a nice one, and it's actually got two relays which might be nice if you want to add another light in the future.
HD Relay: H1/H3 - Wire Harnesses - Components
To make things easy, I'd also get these and I'll explain why later:
9006 Extension Cords - Accessories from The Retrofit Source
If you go with a relay harness like the one above, you'll simply connect the power connector to the battery, connect the ground connector to a ground, run the light plugs towards the light in the grill and connect the switch wire to the signal wire in the relay harness. The first three are very easy, the last one takes a bit more work.
In this case, the relay harness has an H1/H3 and you won't need that, so you can cut that connector off. When you cut that connector off, the wire left (orange insulated wire) is where you'll connect the switch wire to. Of course, you'll need to extend that wire from the switch to wherever you mount the relay harness. The other wire (black insulated wire) is a ground wire that will need a terminal.
Now, you'll need to connect a wire from the high beam or fuse to the trigger wire on the switch to provide it with power. This is the questionable part. By connecting to a fuse, you'll have to hit the switch every time you want to turn the lights on. Honestly, it's a pain in the butt if you plan on using your lights on back roads at night. Connecting to the high beam is much more convenient since you can leave the switch on and every time you turn the high beams on, the eBay bar will light up without having to hit the switch. Very handy. If you choose to connect the eBay bar to a fuse and not the high beams, you have two choices. One, you connect it to a fuse that's always hot. Two, you connect to a fuse that is only on when the ignition is on. The advantage of the first option is that you can turn the light on any time, whether the truck is on or off. That's also the disadvantage because it's easy to accidentally leave on. I'm going to suggest you run the trigger wire on the switch to the driver's side headlight and connect it to the high beam wire. (Don't forget to install a Mini Waterproof 3 or 5 Amp In Line Standard Blade Type Fuse Holder on this circuit!) This should work whether you have the DRL or not.
This should give you an operational switch, an operation harness and the only thing left is to connect the light to the relay harness. This is where those 9006 extension cords come in. Plug those extensions into the end of the relay harness at the light, cutoff the part you don't need and splice your light's wires into that extension cord. Basically, it'll leave you with a nice clean plug so it's easy to remove the light in the future.
I'd do all of this in a few stages. You'll need two provide two wires of your own, so you can simply use a speaker wire or something like that that already has two wires in it. They're both going to the switch on one end, and close to the headlight on the other. Run that wire first, through an existing rubber grommet on the firewall near the master cylinder. Do the switch next. Relay harness after that. Attach the lights. Fire it up and make sure everything works. Finally, clean up the wiring, make it pretty, attach the relay where you want it and enjoy the lighting.
Things you'll need:
The switch. Mine came from AirOnBoard USA
TOYOTA 4RUNNER Replacement Switches -Air On Board
The relay harness I linked to, or something like it.
A length of wire as discussed. I used 18-2 gauge stranded speaker wire.
At least three 18-22 gauge t-taps (one at headlight, one at illumination wire on existing switch in dash) A few extra won't hurt since those things are temperamental at best.
Butt connectors, at least 5 for the new switch ( (1)ground, (2)power and (2)trigger wire (solder and heat shrink tubing is preferred if you're capable)
Mini Waterproof Amp In Line Standard Blade Type Fuse Holder (comes with a 10 or 20 amp fuse change to a 3 or 5 amp) This goes on the trigger circuit!
I hope this help someone wanting to install something similar!
Simple Aux Light Wiring Dia for 4Runner
Upper Access Cover - Removed
Lower Access Cover - Removed
Aluminum Brackets Fabricated
eBay 22inch 120 Watt LED Light Bar
Positioning Brackets
Bumper Drilled and Tapped for Brackets
LED Light Bar Mounted
LED Light Bar Mounted Underside View
LED Light Bar Mounted Grill View
Wiring Harness and Relays Installed
LED Light Bar Trigger Wire Connected to High Beam Wire
LED Light Bar Switch Wired Up
(Obviously, the blue/white wire will be run thru the switch hole and connected back to the T-tap)
LED Light Bar_1
LED Light Bar_2
As requested, Light Output Pics Added
Low Beams
Low and High Beams
Full Beams with LED Light Bar
(Keep in mind, output is partially blocked by grill, haven't decided whether to cut it or not!)
Picture after the grill opened up!
Huge Difference!
Huge thanks to Saker, he answered all my questions and my install was super easy once I had the basic idea of what is going on. I can't recommend using the linking wiring harness, it made things 1000x easier.
LED LIGHT BAR INSTALL on a 2014 T4R-img_3894-jpg  LED LIGHT BAR INSTALL on a 2014 T4R-thumbnail_img_7355-jpg
MMK21 is offline   Reply With QuoteReply With Quote
Old 10-11-2020, 01:47 AM #295
derekr1 derekr1 is offline
derekr1 is on a distinguished road
Nice install and you answered my question about drilling into the bumper! We just picked up a 21' ltd and I noticed that the bumper looks like a primo spot for the light bar brackets!!
derekr1 is offline   Reply With QuoteReply With Quote
Old 01-05-2023, 11:07 PM #296
Johnnyg182 Johnnyg182 is offline
Johnnyg182 will become famous soon enough
Not sure if this is the right place to post this but I’m struggling to figure out simple wiring for DD SS3 driving lights. I bought a harness with a relay which has three wires going to a switch with 3 positions on it: 1white/2blue/3black. I’m trying to connect these wires to an AOB switch that has red/green/blue/black. I want to use the wiper heater switch wires to provide dash lighting. I also want to wire the lights so they only have power when key is in ACC position. Any tips on what connects to what?
Johnnyg182 is offline   Reply With QuoteReply With Quote
Old 01-06-2023, 12:26 AM #297
Saker's Avatar
Saker's Avatar
I can't help you as I'm not familiar with the harness you have or how its set up.
Best Regards,
Saker
led , led light bar , led lightbar
2014 Tail Light Condensation 2014Runner 5th gen T4Rs 31 04-13-2015 04:52 PM
2014 Head Light Replacement quaser182 5th gen T4Rs 0 02-20-2014 01:05 AM
2014 CB Install LowTek 5th gen T4Rs 10 02-14-2014 05:56 PM
2014 Trail light bar help irishmjm 5th gen T4Rs 6 11-02-2013 08:09 PM
2014 tail light on 2013?? 808limitedrtr 5th gen T4Rs 0 10-28-2013 12:57 PM
