03-28-2019, 06:24 PM
#31
I recently got a dometic 50 fridge. I found an old agm battery that I used for fishing that I placed in the back. It is a 12 volt, 55 amp hour battery.
I have been plugging in both the fridge and a noco battery charger (g7200) at night so that the fridge gets power from the DC while the noco charged up the battery.
Before that, I was using the stock inverter to power the Noco charger to charge the battery while it runs the fridge. If I drove it for an 30 mins, it would charge the battery from 50 percent to 70 percent. ( I used a wireless battery monitor)
At any rate, I was thinking what if I ran a separate inverter plugged into the cig port in the back to run the Fridge while I use the stock inverter for the NOCO so when I notice the battery need to be charge, I can activate the stock inverter.
do you think that this will be too much draining on the alternator?
side note, I can run the fridge for 3 days on the 55 amp hour which is good to know
05-20-2020, 02:59 PM
#32
Has anyone confirmed that this modification works? Id like 400W all the time as well. I have a laptop with 150W PS and I cant charge it while driving around. I hate buying another inverter since the factory one is capable and already there.
Originally Posted by Josh_357
I know this is an old thread, but I did the mod this weekend and wanted to share my experience.
On my 2018, I took the black wire from the connector into the inverter, the NSW wire, and cut it from the harness and grounded the end going into the connector. In otherwords grounding the NSW line into the inverter, leaving the harness NSW wire open. I did not cut the speed wire, and everything works as expected. Can drive all day with 400W setting.
05-21-2020, 11:14 AM
#33
Real Name: Ted A Hamilton
I found powering an inverter from a 12v outlet generally tripped off because as someone said, too much voltage drop to the outlet.
This thread, last pic, shows what I did to get reliable power.
Using Oxygen (O2) Concentrator in T4R
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
06-04-2020, 02:26 PM
#34
Hi Josh,
Thanks for adding your update as I am researching this issue too for my 2017 SR5
hungryhawk
09-25-2020, 11:54 AM
#35
Originally Posted by marshal
Probably has to do with fuel consumption. Alternators at full generation are not easy to turn
are you sure? i was doing the math at 110 volts and 400 watts, that is about 3.3 amps and the alternator has to put out at least 75 amps wouldn't it? doesn't seem like much,,and on top of that,, that is at a full 400 watts,, most things you plug into it don't take that many watts. laptops and stuff,,, ( i am assuming
2016 4runner trail KDSS, 3" icon lift w/ uca's, Icon rims, Falkens E rated, 10k smitty winch, heftyfab alum front bumper, heftyfab sliders, frontrunner roof rack, ARQ awning, LED lights everywhere, home made magnetic paint protectors, bunch of recovery gear i never use, a mentally disabled driver, big stupid tires and a million gallon gas tank cause it's a 4runner
09-25-2020, 02:50 PM
#36
110V at 400W is 3.6A
BUT
12V at 400W is 33.3A
The invertor probably draws more than that at full output due to inefficencies in the conversion. IOW it may take 500W of actual power to crank out 400W of useable power.
That is why the invertor fuse is 80A
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
09-25-2020, 04:48 PM
#37
BUT
Good post. We can assume 10% loss for conversation efficiency, so it's likely closer to 37 amps on the DC side to make 400 AC watts.
Inverter fusing at near double is likely to help combat losses from line resistance and surge currents.
02-11-2021, 07:15 PM
#38
Has anyone seen a mod where they changed the 400w/100w switch on the dash to On/Off switch? So when you turn the car on it automatically comes on and turns off automatically when you shut the car off.
I have searched for about a week and have been unable to find anything on this.
02-11-2021, 07:27 PM
#39
2015 Magnetic Gray SR5P
02-11-2021, 08:57 PM
#40
Real Name: Dave
Real Name: Dave
Interesting thread. I have no reason to change the outlet on my ‘18 SR5 because I don’t use the inverter while driving.
I do use the inverter mainly for routine vacuuming of my rig. I use a medium size Shop Vac. Beats having to run approximately 75’ of extension cord; I just keep a 10’ outdoor cord with the vac so I have enough to run around both sides of the truck.
I don’t know the amperage of my vac, but it does kick off at least once per session, sometimes more. It only requires switching the dash switch off then on to reset and I continue, but it’s a pain as it seems to always do this when I’m on the opposite side of the switch. Probably caused by the motor straining when vacuuming tight places that cause blockage to the hose, thus exceeding 400W.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
02-15-2021, 12:58 PM
#41
this is what my dual battery setup is like. my battery and dc-dc charger is in one box as shown here on my setup. all i have to do is connect my fridge to the box and it's always on all the time whether i use the car or not.
https://www.youtube.com/watch?v=ZbVtZvK-f9s
Originally Posted by ozon8r
I installed a lithium 100ah battery charged by a Redarc bcdc supplying power to a few things such as the fridge from a newly installed DC plug when engine is off.
The thought process is that I can use the alternator to power the fridge thru the inverter when the engine is running using the ARB 120v plug. Simultaneously, I would have the ARB plugged into a DC outlet with power supplied by an aux battery when the engine is off. The ARB will automatically switch to 120v when available then back over to DC when engine/alternator is off. And I don't have to unplug and replug every time I start the engine. And the ARB fridge has one DC power plug and one 120v power plug.
But I am wide open to ideas and suggestions.
Edit: I expect the alternator to adjust to accommodate the additional load on the system from the fridge.
04-19-2021, 11:05 AM
#42
Originally Posted by emmantik
I can't tell what i'd need from that site to just use my original outlets at 400w. I emailed them. I'm thinking i just need the 2 wiring harnesses and no outlets.. but do i need a longer cable for the rear outlet?
2011 TE KDSS NAV- K&N drop-in, Toytec/Eibach, Bilstein 5100's, Diff Drop, 295 Cooper STT Pro, OPOR Sliders, 17X9 XD Addicts, Sonoran Steel Panhard Bar, SPC UCA, RCI Skids
'97 Corolla, 90 Alltrac Celica, 94 Camry, 99 Solara 5spd, 98 GS400, 93 Accord, 97 Avalon(current daily), 2010 T4R LE sold, 2011 T4R TE
04-21-2021, 01:17 PM
#43
After I saw this post i started to research their 400w harness also. But i stumbled across this site. Apparently they're banned on the Tacoma site due to seller issues.
BUYER BEWARE: 2nd & 3rd Gen Tacoma In-Cab 120vAC 400W Anytime Power Outlet | Tacoma World
05-25-2021, 08:09 PM
#44
Worked on my 2016 Trail
Thanks Josh_357 this worked. I found the writing a little hard to visualize, if anyone else does also here is my take:
1. To start you only need to remove the ac/dc panel in the rear. Use a plastic pry tool and pry from the bottom. rest it out of the way
2. there are two white connector plugs in the inverter. unplug the right one or the one with all the wires in it. I found unplugging it gave me more room to solder.
3. Find the black wire in the plug. for me it was in the bottom right. cut the black wire leaving as much of the wire dangling out of the back of the white connector. I did not undo the wire loom. I just cut it at the tape.
4. strip and crimp or solder to another wire, I soldered and shrink wrapped a 7" piece of wire to it. on the other end I crimped it with a ring heat shrink wire connector.
5. Remove the 10mm bold under the inverter, add ring end and replace bolt. Not a lot of room to work here, I used a little ratchet and an extender.
All done.
05-25-2021, 09:47 PM
#45
I ordered the KTJO4x4 harness to make my outlets 400w all the time and it was shipped no problem. And, the install went smooth.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
