04-17-2014, 10:29 PM
#16
Also if you're dropping over a grand anyways, call up Safari Ltd. in Grand Junction and see if they can make a stronger than OEM rack...they do for the Tacos...
2010 Trail Edition | Not Stock
Scratching the itch for off-road adventure one weekend, one vacation at a time, taking our Toyota trucks well off the beaten path one day and driving them to work the next! Covering the trucks, the trips, the gear, and the lifestyle.
www.dirtroadtrip.com
04-18-2014, 08:14 AM
#17
Real Name: Tony
Real Name: Tony
Originally Posted by toyslug
LOL Joke's on me! Should have figured it out if I had looked closely at your avatar, Intruder.
Hey 1Engineer, Especially after I saw your response I had to make another correction edit to my "offroading".
Also wanted to make the point that I destroyed my tire not during light offroading that day but it happened soon AFTER I returned back to the PAVED highway at the end of the day!
That's how it always happens, bajaing through rough terrain, bruising the tires then heating them up at high speeds. Pressure leaks just slowly enough to get your attention then it fails and it's all over. Sorry to hear that.
Big KM2's, SCS Stealth 6s, Shrockworks Front Bumper, Warn 9.5XP, OME HD Rear Susp, Icon Front extended travel struts/coils, CBI & Shrockworks full skids, ARB Fridge/Freezer, Rigid this that and the other, BB Sliders, CBI rear bumper/tire carrier and aux fuel.
05-11-2014, 12:18 AM
#18
Real Name: Tony
Real Name: Tony
Originally Posted by NorthWest 4R
Hate to say it but they didn't work for me. Bushing were too small. They may work on non KDSS models, not sure. Apparently they have beefed up steering racks that still go out early when they leave the easy street and pizza cutter life...
Oh well, every action has a consequence. Replaced the whole rack.
12-21-2017, 12:45 AM
#19
Originally Posted by Intruder
That's just the price of the rack, right? It's something like a 16 hour job to replace the full rack since on the 5th gens the engine has to be lifted a bit.
Do I really need to lift the engine? Oh man I hope not. I need to replace my bushings but I think i'm just going to do the whole rack. Please tell me this is not true haha.
01-21-2018, 05:20 PM
#20
It's absolutely true. Sorry.
2011 Trail Edition mostly stock, never wheeled
Instagram
Untitled Offroad
http://sittingbyariver.blogspot.ca/
05-18-2019, 11:52 PM
#21
Real Name: Bryan
Real Name: Bryan
Follow up on 5th gen rack bushings
Hello,
I just wanted to see if anyone has successfully replaced worn bushings with the whiteline rack bushings for their 5th gen. I've tried searching for information on the 5th gen but always seem to get info on the 4th gen bushings. I do not believe that the actual rack itself is bad due to no symptoms of failure such as dead spots or odd noises. My only issue is the steering feels loose over bumps and the tires seem follow the road excessively. Ive replaced my CV axels, inner tie rods, outer tie rod ends, lower control arms (new cam bolt kit) with new bushings and ball joints, a long with new wheel hub assembly. I took my 4runner in for an alignment and they told me that the rack bushings are shot so I'm really hoping to get some information on who has done this. Thank you in advance for your help.
07-04-2019, 01:10 AM
#22
Real Name: Bryan
Real Name: Bryan
Hello,
07-04-2019, 06:32 AM
#23
I speak from experience. Already had mine replaced and it came in somewhere around 3k total.
Yikes. For that price I would trade mine in and upgrade to a newer model with much less mileage.
07-04-2019, 10:08 AM
#24
Banned
Real Name: Tobias Fünke
Banned
Does it tho? Seemed like a simple enough job on the TSB for rack vibrations from improper spring tension. Although that might have been a GX.
07-04-2019, 10:12 AM
#25
Banned
Banned
Originally Posted by WarnerD9
So my steering rack bushings are going bad and no replacements are available. Only way to replace them at this point is to replace the whole rack ($975), Toyota states on the parts diagram that they are too difficult to replace. No reman options. Has anyone else dealt with this and found a solution? If so, please share. Thanks!
There are DIY pour in poly bushing kits. IDK if they work or not. You might still have to drop the rack. You could get lucky and be able to pour it from the top while it's still in. Zero experience with this stuff but it is out there.
02-25-2021, 04:04 PM
#26
Rack bushings
Originally Posted by OkieRider
Hello,
I just went through this and the correct part number for Gen 5 2010- 4Runner is Whiteline W13208. Hope this helps other owners.
12-02-2021, 11:28 PM
#27
Real Name: Justin
Real Name: Justin
My steering rack is hurt. And Im going to get it replaced but have them cut the hex heads on the bolts so they can drop the bolts down; instead of up and having to remove the motor.
I will most likely replace it with just an oem unit and try to see if I can replace the factory bushings with the whitelines bushing.
Seriously trying my best to fight the urge to do RCLT and MarRack.
My Build Thread
My kids call it ROCKY
2014 Raptor Liner White TEP w/ some mods.
12-02-2021, 11:43 PM
#28
It's not that horrible of a job, and you only have to cut (and replace) 1 of the bolts. Make sure to replace the oil cooler gasket - I tried to reuse and it didn't go well.
02-14-2023, 05:13 PM
#29
THANK YOU! I don't know how you figured this out but I'm glad you did. I can't be replacing the entire rack every 2 years when I wear out the rubber OEM bushings. For other owners, W13208 is discontinued. The direct replacement comes from Whiteline's sister company Nolathane.
Part# REV190.0042
I am having them installed as I type this post. The shop did have to remove the rack though. They weren't able to replace the bushings while it was in place.
UPDATE: After the bushing replacement the steering was very bad. Almost dangerously bad. I took it to the dealer and they confirmed the rack was moving around a lot. I'm assuming the bushings were not a proper fit and now I'm getting the whole rack replaced. Bummer.
