05-10-2014, 07:42 PM
Trailer Wiring... where is the harness hookup?
I am in the market for an expedition trailer whether I do a build or buy one. I went outside today to look at my hitch and all looks good... but I can't find the wiring harness for the lights!?
I have a factory installed hitch and it even came with the factory, in-the-box, ball mount.
Is this normal?
2014 Super White Toyota 4Runner SR5 Premium 4x4, 3rd Row, Entune/NAV
Gobi Stealth w/ Ladder, 265/70/17 Duratracs, Bilsteins @ 2.5 in front, Bilsteins Rear, 1.5" Daystars rear
05-10-2014, 07:52 PM
Real Name: Joel
Real Name: Joel
If you lay down to take a look under the rear of your 4R, it'll be on the opposite side as your exhaust. Here's what you're looking for:
The regular 4-pin is on the side closest to your spare tire.
-Joel
Save an Athlete. Adopt a Greyhound!
2010 4Runner Limited
05-10-2014, 09:23 PM
Found it! I crawled under there earlier... wow, can't believe I missed it. Thanks for the quick response.
05-11-2014, 01:06 AM
Real Name: Jonathan
Real Name: Jonathan
@ GreyhoundGuy
, yours looks parallel to the ground. Has it always been like that? Mine is at a bit of an angle.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
05-11-2014, 02:06 AM
Wow! Thats how they're mounting them now? Thats even more ridiculous than the 2010. Mine is in the same spot, but at least its on an angle so its not totally vertical.
SOLD!99 SR5 V6 - SS 1.2 Lift, 1" BL, 231mm TBU, LTX M/S2s, Savage Sliders, Skids and Bumpers, Lots of LEDs, 70266 ATF Cooler with 5757 Gauge, Homemade Roof Rack, VHF & CBs, Various Off-Road Goodies '10 Trail Edition - WeatherBeaters, VentShades, Prodigy P3, TruCool 4589 ATF Cooler, E Rated LTX M/S2s, Booster Seats with a hint of kid puke '16 Tundra TRD SR5 - ATC Cap, AirLift Bags and WirelessAir Controller, Prodigy P3, LineX, E Rated Defender LTXs
05-11-2014, 08:04 AM
Real Name: Joel
Real Name: Joel
Originally Posted by STX4Runner
@ GreyhoundGuy
Yes, it's always been that way.
Can you catch a picture of yours? I'm curious to see it.
-Joel
05-11-2014, 08:31 AM
Real Name: Jonathan
Real Name: Jonathan
I kinda like your as it looks completely protected for off roading. Tough to get to, but protected. I'll post a pic later when I have a chance.
05-11-2014, 09:17 AM
Real Name: Jonathan
Real Name: Jonathan
As promised.
05-11-2014, 11:19 AM
Real Name: Joel
Real Name: Joel
@ STX4Runner
- Well that's weird. I would think that the LE would have the wiring harness at 45 degrees and the TE would be flat. I wonder why they're the way they are.
Anybody know anything about the differences... or care to just make crazy speculations?
-Joel
05-11-2014, 12:45 PM
My wifes SR5 is angled down too...I think yours either got moved from off roading or someone moved it on purpose. Either way it makes more sense to have it out the way so it doesnt catch on anything. I hate that I had to buy an extention cord to attach to my trailer....
05-11-2014, 03:17 PM
Real Name: Joel
Real Name: Joel
Does anyone else have the same setup as mine? Or am I alone on this "Why the he** did they do that" ship?
-Joel
05-11-2014, 03:52 PM
Real Name: Jeffrey
Real Name: Jeffrey
I have a 14 LE and it's flat.
2014 Toyota 4Runner Limitless
Blizzard Pearl :: Black Rhino 17" Sidewinders :: 285/75-17 Nitto Ridge Grapplers :: Baja Lighting :: Camelback Metal Gear Rack :: Gobi Ladder :: King 2.5 Long Travel Coilovers :: Dirt King UCA :: OME Rear :: Pelfreybuilt Aluminum Front Bumper :: Expedition One Dual Swing Rear Bumper :: RCI Armor :: Shrockworks Sliders/TE Rockers :: Warn Zeon 10S Winch
05-11-2014, 08:31 PM
Real Name: Jonathan
Real Name: Jonathan
This may a case of whatever box was on the assembly line on the day yours was made is what you ended up with.
05-12-2014, 08:11 AM
Has anyone had any luck moving these connections so that an extension cord is unnecessary? I tow often and hate having to dive under my truck every time I hook up my boat or flatbed trailer. I tried just leaving the extension zip-tied in place, but the plug stock plug would get so nasty from being open all of the time I removed it except when towing.
Show me some ingenuity on this one, or at least castigate me because I didn't search old threads diligently enough.
05-12-2014, 09:57 AM
My SR5 has the angled setup…I grabbed the bracket and pulled towards the back of the truck to gain the inch or two needed. The bracket is soft metal and bent easily enough. There is extra wire harness for this option.
Problem is it looks like sh!t and I still have to lay on the ground to make the connection.
When or if the plug fails I hope to do something better.
Anyone made an improvement yet?
2012 SR5 _ Trans cooler _ Spin on trans filter _ NOT FOR SALE
