08-16-2019, 10:59 AM
#226
Originally Posted by babston
What Load range are you running?
275's are E rated.
08-16-2019, 12:55 PM
#227
Real Name: BLACK TRD PRO
Originally Posted by Tejas
1.5" up front and 1" out back with 275 KO2's on the stock Pro wheels and 1.25" wheel spacers. No issues.
How do you like your spacers? Looks good. Any different driving qualities? I.e.; stability, cornering, etc.
08-16-2019, 01:03 PM
#228
I like the more aggressive stance, feels more stable at speed and in turns. Pretty much eliminate the wandering on the highway and when in a high crosswind. Brought a shimmy to the steering and tires from 50-60mph, threw off the alignment and started wearing the tires funny. I removed them and sold them in under two months. I have aftermarket wheels and tires coming now.
08-16-2019, 01:23 PM
#229
Thanks for that info.
08-16-2019, 01:40 PM
#230
yes, here.......
Originally Posted by Johns381
Has anybody put on the Cooper Discoverer AT3 LT in the 275/70R17? I’ve seen some posts about the AT3 4S but I’m thinking about the 275/70 which is only offered in the LT load range E now. Would love to see pics and hear opinions on this option.
275/70/17 E-load AT3 LT's. The spare fits. Quiet so far, a TAD more sluggish off the line compared to the BFG AT's I replaced, or that could also be in my head.
Suspension is a TRD Pro take off.
Good off road in the limited time I've had them off road (in the sierras, wet and dry).
Digging them so far.
2021 TRD Off Road
2008 GX470 (sold!)
2018 TRD Off Road (sold!)
08-16-2019, 11:44 PM
#231
I have a TRD Pro, which, has the fender liner mod and is 1” higher up front than the other 4Runners from the factory. I added Burtman Industries Cornfed 1.5” split spacers to the front and 1” spacers to the rear. I like the setup. No removal of the mud flaps, no rubbing at full articulation or frame cutting required. 275 BFG KO2’s.
Thanks... So your total lift compared to a SR5, Trail or limited is 2.5 front and 1 in the rear?
08-17-2019, 12:25 AM
#232
Looks really good, but based on your approach to lift- isn't your rear .5 inches shorter than the front.
08-17-2019, 01:36 AM
#233
The vehicle naturally has a rake with the rear sitting 1-1.5" higher than the front. Even with the 1/2"differential out back, the rear still sits 1" or more higher than the front. The fronts also settle more due to the weight of the motor. It doesn't take much weight inside or up top for these trucks to sag in the rear. No extra height/lift can account for that, only a heavier rate spring can make up for it.
08-17-2019, 02:10 AM
#234
Correct.
08-17-2019, 08:57 AM
#235
I had the Coopers in a load class C. Went to get them again and didn't like that they only come in E now, so I went with Falken Wildpeaks in a C. Too new to really comment on the Falkens, other than they seem much quieter than I remember the Coopers being when I got them.
Sent from my Pixel 3 using Tapatalk
'17 4Runner TRD Off-Road KDSS | Super White
SSO Slimline Hybrid Bumper|SmittyBilt X20 w/ synthetic line|Bilstein Coilover w/ SPC Upper Control Arms|
Cooper AT3 275/70R17|Eezi-Awn K9 Roof Rack|ARB Fridge|ARB Extended Fridge Slide|Goose Gear Plate
09-16-2019, 07:40 PM
#236
Real Name: Stephen
Real Name: Stephen
How are you liking the Wildpeaks a month in? I'm strongly considering these as most 275 are E load and just can't see running E load on a 4R. However, the 275/70R17 Wildpeaks outweigh many 275 tires in the E load range. Have you experienced any sluggishness compared to the Coopers?
2016 TEP w/KDSS
2000 Limited, 2wd Sold
2000 SR5 5spd, 4wd
10-08-2019, 01:49 AM
#237
Interested in this as well. I worry about going with too heavy of a tire.
10-08-2019, 08:38 AM
#238
I'm planning on installing Falken Wildpeaks tomorrow but am surprised to see posts about them rubbing, I thought they were supposed to fit without issues.
Is the rubbing just from people running spacers or non-stick offset wheels?
10-08-2019, 02:12 PM
#239
No rubbing on the Pro models as they sit 1” higher up front and have the fender liner mod done at the port compared to all the other 4Runners. Also, the Pro wheel is 17 x 7 and the Off Road is 17 x 7.5. I think the biggest issue for those that rub is the fender liner.
10-08-2019, 02:53 PM
#240
higher shouldn't make a difference, everything still travels through the same arc. i wouldn't think a narrower wheel would make a difference considering the tires are the same.
it's marked green on the going bigger table so i thought i was good, guess i'll just plan on checking if i need to push the fender liner in
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
