06-01-2014, 06:06 PM
Fix-A-Flat
Sorry if this is a dumb question, but I'm curious if anyone has had any bad experiences from using fix-a-flat tire filler. I love the idea of being able to fill a flat tire up with this can of stuff and having it fill in any air leaks.
My issue that concerns me is that it will add unnecessary weight to the tire and throw the balance off long term? Especially if applied to the same tire more than once. If anybody has any thoughts on this, your opinions would be greatly appreciated! thanks - kurt
2011 blizzard pearl LE ~ OEM bells & whistles ~ tint ~ Satoshi grill ~ WeatherTechs ~ Camelback Metal Gear roof rack
Front Suspension: MetalTech 2.5" lift Icon coilovers & shocks /Rear Suspension: Icon shocks w/ 3''
OME coils ~ Front & Rear CBI steel bumpers ~ Rigid LED light bar
Fuel Trophy 17x8.5 rims ~ 285/70r17 Mickey Thompson MTZ's ~ LR UCA's ~ Rocker panel chop ~ N-fab steps
06-01-2014, 06:20 PM
Real Name: Patrick
Real Name: Patrick
Learn how to plug a tire properly (YouTube) and stay away from that crap
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
06-01-2014, 06:31 PM
Banned
Real Name: Joe Gomez Jr.
Banned
06-01-2014, 07:22 PM
Real Name: Jeff
Real Name: Jeff
Plugs are super cheap and easy to use. A lot of time even being able to be used with the tire/wheel still on the vehicle.
No personal experience but I've always heard the old line of how when the tire with fix-a-flat in it is finally broken down from the rim, the resulting cleanup of that goo is passed on to you.
I've had great results with plug kits on everything from lawn mower and golf cart tires up to 19.5" commercials.
Good luck and hope you won't have to use either any time soon!
- Jeff
2014 Mag. Gray Trail Edition, SouthernSS Slimline Front Bumper w/ ENGO e9000 and flush mount LED bar, Toytec /Bilstein 5100 Coilovers, Rear Bilstein 5100's, Rear SAW coil's, 265 Nitto G2's on FN Six Shooters, Husky Liners, TRD exhaust tip, Midland 75-822 w/Wilson 5000 mag. mount, AVS low-profile ventvisors, Lamin-X fog covers
06-01-2014, 08:06 PM
If it's an emergency, use it.
If you can use your spare, use your spare. Otherwise, that stuff will damage the TPMS sensor. If you use too much of it, it will throw the balance off until you drive for a little bit. But it's for emergency situations.
06-01-2014, 08:29 PM
Most tire places charge extra to properly repair a tire that has been temporarily fixed with fix a flat. Its messy stuff.
Plugs are also are a temp and easy fix.
Either way, I would take the tire to get properly fixed (plug & patch) after using one of these temp solutions
-Travis
2014 4Runner TE: 285/70/17 M/T ATZP3, 5100's 2.5" front/1.5" DS rear, Spidertrax spacers, RCI Sliders, FrontRunner Slimline II, Gobi Ladder, TRD Intake, Borla Catback, Pedal Commander, TRD Pro: Wheels, Skid, Grille
2018 Audi S5 Sportback, 2017 Toyota 86
06-01-2014, 09:25 PM
Not sure on Toyota TPMS, but on my BMW the 'OEM flat tire fixer' which is similar to fix a flat caused me to have to replace my TPMS sensor with a new one.
2012 4Runner TE
06-01-2014, 09:31 PM
Real Name: Patrick
Real Name: Patrick
Please elaborate on "temp" in that statement
06-02-2014, 05:39 PM
A plug by itself isn't a perminant fix. The correct way to fix it is a patch plug combo. Unless it's changed from when I managed a firestone while putting myself through college 10 yrs ago.
-Travis
06-02-2014, 05:50 PM
Real Name: Patrick
Real Name: Patrick
I have a feeling there's a lot more plugs (running around, unpatched) and that's based on almost 40 years of driving and plugging tires. I was plugging my own tires when you were still crapping green, kid.. But all kidding aside, there's has to be tons of tires sporting plugs only.
Having owned a construction business for quite a few years forced me to get trucks (and men) back on the road as quick as possible...so if I could roll up, plug a tire, fill it with air and be ready to roll, that's how it went. I can't honestly remember a plug failing...
hope you patched tiares betar than you speeled college boy....lol..."permanent"
06-02-2014, 06:16 PM
Wow you are old. That's cool. I guess.
I didn't say it wasn't a fix, it is a cheap on the fly way to fix. Just like fix-a-flat. Hope you don't build things half assed like you fix your tires construction geezer.
-Travis
06-02-2014, 06:53 PM
Real Name: Patrick
Real Name: Patrick
Just callin' like I see it kid....
Did I mention that the manager of the Firestone up the road was also the manager at the McD's about two weeks earlier??
I guess once you know and understand retail it just stays in your blood...
06-02-2014, 08:47 PM
Real Name: Josh
Real Name: Josh
I knew a guy who was fixing a tire that had this fix-a-flat in the tire and nobody told him, when he got the tire off it exploded because of that stuff and took most the skin from his hand/forearm. This info is from texastriallawyer.com
While trying to fix a flat, many tire workers and others can be blinded, maimed, or even decapitated when the tire explodes. Most of these tires had been previously filled with a can of tire sealant to fix a leak in the tire. The propellant in the tire sealant often times contains the butane & propane. When an ignition source is present a massive explosion is possible.
99 4runner limited 4wd Stock, 202xxx, factory e-locker. Family Adventure Mobile!
06-02-2014, 09:19 PM
Real Name: Dave
Real Name: Dave
I carry a can along with plugs, etc. just because you never know but it's there only when I'm too drunk to get the spare or plugs.
My car came with no spare but has this stuff and a small compressor.
Them Be Me Mods - 2011 Black Limited / Trail Mutt
06-02-2014, 10:42 PM
Man that escalated quickly... I usually just patch. Unless it is on a ford excursion on a knarly trail, then I just give up and limp it down on the rim because it is the third flat in a day...
2010 Trail Edition | Not Stock
Scratching the itch for off-road adventure one weekend, one vacation at a time, taking our Toyota trucks well off the beaten path one day and driving them to work the next! Covering the trucks, the trips, the gear, and the lifestyle.
www.dirtroadtrip.com
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
