Old 07-31-2016, 03:11 PM #61
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
Originally Posted by Mowgli View Post
Do any of you all have this issue after braking.
Once at a full stop with the pedal down if you release any pressure at all you start moving forward. And I don't mean letting off the brake I mean very slight pressure. I've almost rear ended someone multiple times at red lights
just checked the idle with scan tool. in park/neutral 750-775 RPM
in gear 650-675RPM . with AC on slightly higher 50 RPM.
this is 125-175RPM more than the GM vehicles I own so more creeping in gear when stopped . most times GM vehicles 550 RPM..in drive or park idle on GM returns to 550 RPM. toyota idle control not as good as my GM vehicles.
catrains is offline   Reply With QuoteReply With Quote
Old 07-31-2016, 04:03 PM #62
Madhunter77's Avatar
Madhunter77 Madhunter77 is offline
Real Name: Jeremy
Madhunter77 is on a distinguished road
Real Name: Jeremy
I have had 2 4runners and both have done the sound but only the 2016 trail i have pulses in the steering wheel, but it is not that bad
Madhunter77 is offline   Reply With QuoteReply With Quote
Old 08-02-2016, 09:15 AM #63
keph13 keph13 is offline
keph13 is on a distinguished road
I've noticed that when the AC compressor kicks in, the idle increases enough to sometimes start the truck moving forward a bit. I've now managed to train myself to increase brake pressure when I hear it.
2010 4Runner SR5 4x4
keph13 is offline   Reply With QuoteReply With Quote
Old 08-02-2016, 11:45 AM #64
cryption1's Avatar
cryption1 cryption1 is offline
cryption1 is on a distinguished road
cryption1's Avatar
Originally Posted by Arkangel View Post
My 2014 SR5 does it as well and did it from brand new. What mine also does that is super annoying and in 1200 miles cannot get used to is pulsating when braking. Happens i would say 90% of the time. Took it in and the tech said he felt no pulsation. 2 others I drove did not do it.
This is what drives me crazy. The pulsation. The "wet shoe" sound to me is no big deal, but the pulsation feels to me like when ABS kicks on ... but it happens even when sitting at a stop light. It ruined the 4runner for me the first few weeks I owned it, and talked to the dealer about a return - and even considered trading it I hated it so much.
I've gotten used to it now after about 2k miles. It's still there - but only annoys me if I've driven a different car between 4runner drives. I do still truly hate the feel of the brake pedal on the 4unner - but after a time you get used it.
cryption1 is offline   Reply With QuoteReply With Quote
Old 11-02-2016, 02:24 PM #65
msk2u msk2u is offline
msk2u is on a distinguished road
Whats going on with the spongy brakes..
OK, am having the exact same issue now. Didn't happen for the first 100 miles but now same symptoms displaying. Noticed that when put on 4Hi this improved how the brakes felt - maybe this was the placebo effect?!
Not sure if the design of the brakes is geared towards stopping a 2 tonne car effectively depending on what the wheels are doing.
Does anyone know the ratios of power distribution on the 4runner ? e.g. 2HI is it 80% rear and 20% front and then roughly 50% split in 4HI. (currently riding a TEP)
I'll also note that the SR5 (2) that I test drove did not display the spongy brakes..
msk2u is offline   Reply With QuoteReply With Quote
Old 11-02-2016, 02:42 PM #66
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light
Moderator
1engineer's Avatar
Real Name: Greg
The brakes are the same no matter which drive mode you engage.
If you have part time 4WD, it is 100% rear in 2HI and 50/50 in 4HI or 4LO.
If you have full time 4WD the power distribution is variable from front to rear in 4WD. If you lock the center diff it becomes 50/50.
1engineer is offline   Reply With QuoteReply With Quote
Old 11-03-2016, 11:10 PM #67
Hmmm...
OK, studied this one more and 1engineer is right - the squishyness is till present but seems to "behave" differently in 2HI vs 4HI though I can not quiet characterize it.
Also with respect to 2HI being all rear wheel drive - the manual seems to suggest otherwise -front wheel drive in 2HI. Don't have a ramp unfortunately to test.. Has anyone conducted any tests to see the power distribution matches the above? I'd have thought 80/20 split would be more sensible if it was not front wheel drive?
Old 11-03-2016, 11:30 PM #68
shahsmerdis shahsmerdis is offline
shahsmerdis is on a distinguished road
My forester was like that, I told subaru to do a brake flush. Fixed the issue. Called up Subaru of america, they sent me a check for the service.
2004 limited V8
2002 SR5 V6
shahsmerdis is offline   Reply With QuoteReply With Quote
Old 11-03-2016, 11:31 PM #69
Brakes are totally seperate. it might feel different but its affect is the same.
edit, tire ratings on oem 5th gens seem like crap on tirerack, are everyone running oem tires?
2004 limited V8
2002 SR5 V6
Old 11-04-2016, 12:13 AM #70
1engineer's Avatar
Moderator
Real Name: Greg
Moderator
1engineer's Avatar
Real Name: Greg
Which model do you have? If you have a Limited you are always in 4WD with a torque split until you lock the center diff then it's 50/50. If you have a SR5 or a TE or a TRD Pro it is definitely 2WD with 100% power to the rear wheels until you put it in 4HI. Then it becomes 50/50. There is an article on this in the sticky thread "Are you a new or prospective owner."
This is not even a topic for debate.
Old 01-17-2017, 09:26 PM #71
BlueRidge77's Avatar
BlueRidge77 BlueRidge77 is offline
Real Name: Michael
BlueRidge77 will become famous soon enough
Real Name: Michael
*Edit* Created my own thread regarding this comment... Buzzing/Vibrating Brake Pedal
2016 MGM TEP w/KDSS - P285/70-17 Toyo Open Country AT3 on Stock Trail wheels, no spacers - Dobinsons IMS Lift 2.75”/2” (302/505 Springs) - Freedom Off-road UCAs - TRDP Grill - Redarc Trailer Brake Controller - SumoSprings Helper Spring Bumpstops (black)
Last edited by BlueRidge77; 01-18-2017 at 08:55 AM. Reason: Created my own thread.
BlueRidge77 is offline   Reply With QuoteReply With Quote
Old 09-08-2017, 02:57 AM #72
LiveLifeOnWeekend's Avatar
LiveLifeOnWeekend LiveLifeOnWeekend is offline
LiveLifeOnWeekend is on a distinguished road
Originally Posted by Sublimize23 View Post
Is it the noise or the feeling you don't like? I really doubt anything can be done about it. Someone posted previously that the noise is related to the system that assists in braking in emergency situations. Turn the music up and forget about it.
hahah that's literally what I said to my wife when she pointed out my brakes were squishing!
LiveLifeOnWeekend is offline   Reply With QuoteReply With Quote
Old 09-08-2017, 03:09 AM #73
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
That's an odd statement, hard to really qualify "good or bad" idle control over various engine/drivetrain configurations and software programming.
If the vehicle is maintaining a steady, stable RPM when the computer asks it; I'd say it's doing good idle control. If the computer is programmed to bump up 50rpm when the A/C is on, that's not "bad" or "good" idle control that's just spec; now if it struggled/can't maintain a relatively stable 50rpm increase when commanded that could be an indication of "bad" or "good."
Post Note-
I just saw that's from over a year ago... Damn it.. I'm going to bed.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 09-08-2017, 08:26 AM #74
Post Note-
I am no vehicle design engineer but if the brake pedal is on and the vehicle is stopped the PCM should not screw with the engine idle because the ac compressor kicks in.
many have had this sudden vehicle movement in traffic brakes on ..
so if you have NON toyota vehicles also , this is an issue.. with all your vehicles toyota or just this one then you automatically use a heavy foot on the brake ...this summer it happened again a few times to me ...
vehicle creep ..
Old 12-23-2019, 02:13 PM #75
weezykid weezykid is offline
weezykid is on a distinguished road
So I was going to start a new thread, but found this one. Sorry for reviving an old thread.
I have an '18 Off-Road (9800 miles) and the pedal makes the squish sound. Haven't noticed it much, but a friend of mine does when she rides with me.
The concern I had is that my pedal will feel squishy at times. Some traffic lights if I apply a little more pressure, I can make it go to the floor. After doing this the pedal will feel fairly stiff for a while (few weeks maybe) and then start feeling squishy again. The Service Writer said their master tech looked it over and found no issues stating it is the way the "hydraulic assist" works.
Mike
weezykid is offline   Reply With QuoteReply With Quote
brake , brake pedal , brakes , noise
Spongy/Long travel Brake Pedal w/ Tundra brake upgrade 2002_thundercloud 3rd gen T4Rs 9 07-23-2023 10:07 PM
low brake pedal billkmiami 3rd gen T4Rs 13 10-10-2017 06:00 PM
soft brake pedal Bacon 4th Gen T4Rs 6 04-06-2015 10:00 AM
"squishy" break pedal? tperkerson 5th gen T4Rs 2 05-06-2011 10:38 AM
does your brake pedal go to the floor? gonzo 4th Gen T4Rs 34 08-03-2006 01:26 PM
