Old 12-23-2019, 02:42 PM #76
SkidPalace's Avatar
SkidPalace SkidPalace is offline
SkidPalace is on a distinguished road
SkidPalace's Avatar
Originally Posted by weezykid View Post
So I was going to start a new thread, but found this one. Sorry for reviving an old thread.
I have an '18 Off-Road (9800 miles) and the pedal makes the squish sound. Haven't noticed it much, but a friend of mine does when she rides with me.
The concern I had is that my pedal will feel squishy at times. Some traffic lights if I apply a little more pressure, I can make it go to the floor. After doing this the pedal will feel fairly stiff for a while (few weeks maybe) and then start feeling squishy again. The Service Writer said their master tech looked it over and found no issues stating it is the way the "hydraulic assist" works.
Absolutely NOT OK. A brake pedal going to the floor is a potentially fatal issue. You need to elevate this with your dealer. You need to be clear you are not talking about the whoosh sound at a the front o f the pedal press, but a pedal going to the floor. It should not do that ever, unless you are bleeding the brakes.
2015 Magnetic Grey Limited with Redwood interior. 275/55r20 Michelin Defender LTX on stock wheels. Daystar 2.5/1.5 puck lift.
Gone but not forgotten: Black 2000 SR5 "Highlander", Supercharged, Black pearl emblems, Factory e-Locker.
SkidPalace is offline   Reply With QuoteReply With Quote
Old 12-23-2019, 02:48 PM #77
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
+1. You either have a brake line leak or a faulty master cylinder. Scotty Kilmer video on sinking breaks
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 12-23-2019, 03:39 PM #78
cbreze's Avatar
cbreze cbreze is offline
Real Name: Jim
cbreze is on a distinguished road
cbreze's Avatar
Real Name: Jim
If it actually touches the floor then something is definitely wrong and needs immediate attention. My pedal is “squishy” but I’ve grown so used to it I don’t notice it and find my brakes are really quite excellent. I had a panic stop at 65 mph once and was quite impressed as to how fast and straight I was able to come to a complete stop and no tire squeal. If I jammed my foot down as hard as I could I suppose I may get the pedal closer to the floor but doubtful it would touch. In a worse case scenario I would not see a need to push that hard.
Lovin' my 4R
cbreze is offline   Reply With QuoteReply With Quote
Old 12-23-2019, 09:00 PM #79
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
I don't notice it as much on mine now after switching to Brembo pads. Far better pedal feel and less pedal travel too. I mean it still makes the sound but it stops actually stopping before I hear it. I can't say the truck actually stops better but it sure feels better.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
Old 02-01-2020, 01:04 PM #80
weezykid weezykid is offline
weezykid is on a distinguished road
I tried the multi quote function, but it doesnt seem to be working for me.
Well after dealing with Toyota and going back the a different dealer, they still say nothing is wrong at it is working as it should. Yet at a stop light I can still get the pedal to the floor with extra force. Between this and my jacked up oil change on the last service, as well as my 2018 Tacoma issues, I am really loosing faith in Toyota service and quality.
Mike
weezykid is offline   Reply With QuoteReply With Quote
Old 02-01-2020, 01:13 PM #81
euser euser is offline
euser will become famous soon enough euser will become famous soon enough
I have multiple vehicles where I can push the pedal to the stop if I press on it harder than I ever would to brake while not in motion. My 4Runner does the same thing. If you use up all the travel while actively trying to stop that’s an issue, while at a stop with higher than normal pressure is a non issue. Your ABS would be kicking in long before you get there, which I’ve tested on mine lol.
euser is offline   Reply With QuoteReply With Quote
brake , brake pedal , brakes , noise
Spongy/Long travel Brake Pedal w/ Tundra brake upgrade 2002_thundercloud 3rd gen T4Rs 9 07-23-2023 10:07 PM
low brake pedal billkmiami 3rd gen T4Rs 13 10-10-2017 06:00 PM
soft brake pedal Bacon 4th Gen T4Rs 6 04-06-2015 10:00 AM
"squishy" break pedal? tperkerson 5th gen T4Rs 2 05-06-2011 10:38 AM
does your brake pedal go to the floor? gonzo 4th Gen T4Rs 34 08-03-2006 01:26 PM
