06-19-2014, 02:04 PM
ARB 50 qt refrigerator powered from stock 12v cargo?
I've read as much as I can find with a search and also on expeditional portal, but I haven't found a clear confirmation of this, even though I think it is possible.
Will the stock 12v outlet in the cargo area power a 50qt ARB refrigerator while driving? I will plug the refrigerator into an alternate source when not driving, so I don't need the ability to run with the ignition off.
I'm curious because i'm considering a yeti400 battery pack that will be used until if/when I do the dual battery setup (i just don't want to do it before i understand if i like the refrigerator).
Thanks for any insight.
2014 TE
BFG KO2 285/70 17, Icon Stage 2, Shrockworks front bumper, sliders, engine skid, 9.5 winch, FN counter steer type X
06-19-2014, 05:19 PM
Yes.
2011 Trail Edition mostly stock, never wheeled
Instagram
Untitled Offroad
http://sittingbyariver.blogspot.ca/
06-19-2014, 05:25 PM
Real Name: Joe Bloomstone
The 12v (DC) outlet in Cargo Space is rated for 120 Watts. It is only energized while key is in Accessory position (or driving). It is protected by a 15 Amp fuse.
Looks like the 50qt ARB Fridge consumes 7.0 Amps @ 12VDC (in other words: 84 Watts).
2012 Trail Edition, Magnetic Grey, NAV, EnTunes, KDSS, Factory Running Boards, Stainless Exhaust Tip, HuskyLiner Weather Beaters, CravenSpeed Stubby, Toyota Emblem Black-Out, Ifinity Kappas throughout, LED Upgrade for Interior, LED Exterior: Tail/Brake, Reverse, Rear Turn, Front Turn/DRL, & Front Parking. Built-In Compressor (AntMan Style), Painless Fuse-Box, Cup Holders (AntMan Style), LED Under Hood Lights, NAV Override, Hella Horns x 4!!!
I've been a T4R owner since 1997....
06-19-2014, 05:28 PM
So in other words... Yes.
Instagram
Untitled Offroad
06-19-2014, 05:37 PM
Thanks guys, I appreciate the confirmation!
2014 TE
06-19-2014, 06:13 PM
Real Name: Dave
Real Name: Dave
Yes, I had to do so this weekend. It stayed at temp during stops while the engine was off. But I 'think' I remember reading that arb recommends their wiring, which I also think is 8G, directly connected to the battery for max performance and the least use of power.
Them Be Me Mods - 2011 Black Limited / Trail Mutt
06-19-2014, 08:31 PM
Real Name: Patrick
Real Name: Patrick
I ran an 8 guage from the engine bay to the the rear jack area to a Blue Sea 6 circuit panel....and then ran additional "always on" outlets( on either side, including some USB ports)...run it with confidence.
If you look at the wires to rear OEM outlets it looks like 22#....maybe in an emergency it work...but I'd hate to burn up an 800$ cooler for some simple mods.
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
07-30-2015, 05:23 PM
Real Name: Danny
Real Name: Danny
@ apollo
how did that work out for you, to run it off the stock power?
Has anyone been successful in purchasing an ARB fridge at a black Friday sale or another sale? Looking for one but have some reservations to run a separate wire, for now I would like the option to put in and out, nothing permanent.
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
07-30-2015, 05:25 PM
Real Name: Jeff
Real Name: Jeff
Originally Posted by DannyLlama
@ apollo
I got mine at Autoanything when they were offering a 30% off coupon with free shipping- best deal I could find anywhere...
HERE FISHY FISHY FISHY!
07-30-2015, 05:30 PM
Real Name: Danny
Real Name: Danny
Do you have the coupon code? Do you mind sharing?
Dual Battery Thread
07-30-2015, 05:31 PM
Real Name: Jeff
Real Name: Jeff
They don't always offer it- gotta catch it at the right time or I woulda already attached it.
07-30-2015, 05:36 PM
Real Name: Danny
Real Name: Danny
Sucks, wanted it for an upcoming trip.. so your got it for about 700 total?
Dual Battery Thread
07-30-2015, 05:41 PM
Real Name: Jeff
Real Name: Jeff
Nope. Right around $600, I think a little under...
07-30-2015, 06:12 PM
@ apollo
I elected to stick with a cooler for the time being, didn't try it out, sorry
2014 TE
07-30-2015, 06:57 PM
We just got a Coleman Iceless cooler for an upcoming road trip. It is not a refrigerator, but it does run off 12 VDC or 120 VAC. We tested it and it works well; however, it (like the instructions say) takes quite a while for it to cool down - approx 3 hours. You can shorten this time by placing cooled items inside. It was just under $100.
