07-17-2014, 11:12 AM
Real Name: John
Real Name: John
LED Cargo Lamp DIY w/Pics
I've recently done the LED conversion on my vehicle and had a hard time figuring out the rear cargo lamps. I did some searching on here and found a simple explanation, but I wanted to provide pictures to help others do this mod as it's much simpler once you know what you're looking for.
The first image shows the lamp when you pull it out. As mentioned on another thread, the lamp has a metal tab on the drivers side of each lamp. Stick your flathead screw driver into the drivers side gap and push the tab towards the lamp. This will loosen it up and it should pop right out. Then take the plastic cover off and replace your bulb with the LED and you're done. There's a plastic tab on the passenger side of each of them that hinges out towards you when you remove the lamp. Just place that end in first and pop the lamp back in.
Finished product.
2014 SR5 Premium White on Black -Blacked out emblems, LED conversion, Stealth mount Radar detector... lift and TRD PRO Appearance to come
07-17-2014, 11:28 AM
Real Name: Owen
Real Name: Owen
I have a similar setup. I have more LEDs in the pod, but it is basically the same thing.
07-17-2014, 01:16 PM
Real Name: Tom
Real Name: Tom
Is this for the lights on the interior of the rear hatch door? I have had a very difficult time figuring out how to remove the light to swap the bulb. I had no issue on any other light in the vehicle, or on any lamp on different cars in the past, but I am worried about breaking them, or damaging the surrounding material.
2014 Trail Edition - Black - 18x9 FN BFD in Graphite, 275/65/18 Duratracs, Interior LEDs, Husky Liners, Custom Rear Storage Box, Rigid 20"/D2s
07-17-2014, 01:33 PM
Real Name: Um, Phil?
Mine's a 2010, assume they're the same.
LED replacements, Rear Hatch, photos
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
07-17-2014, 02:50 PM
Real Name: Tom
Real Name: Tom
Originally Posted by philsey
Perfect,
Thank you - I figured the construction was essentially what was detailed, but with as difficult as it was trying to get it out, I didnt know if I was doing something wrong.
07-17-2014, 04:59 PM
Real Name: JR
Real Name: JR
here is another thread I used to document my interior LED replacement, where I used philsey's thread as a baseline for doing the 2014 model year.
Part Numbers For Interior Light Mod....PLEASE
80 PhoenixLJ/84 CelicaGT/84 & 87 Cressida/89 Toy Truck 2wd/91 Cressida x 2/93 Paseo/96 Protege/98 4Rv6/04 4R Sport v8/06 Taco AC v6/07 Sonata SE v6/09 Rav4 v6/10 Legacy 3.6R/12 Taco DC v6/09 Avenger SXT/09 Corolla XLE/14 4R LE/14 Rav4 XLE/15 Camry XSE/16 Taco DC v6 Sport/16 Highlander XLE/18 Tundra Plat/18 Santa Fe Ult
2014 4R LE Classic Silver Build Thread
E5-Exhaust Tip / MF-Mudflaps / R6-Running Boards / 2Q-All Weather Mats / 3P-Paint Protection Film
07-17-2014, 07:06 PM
Real Name: John
Real Name: John
Yes I had a hard time finding one for the 2014 and wasn't sure until I read another thread just verbally describing them so I figured Id throw up some pics so it up on the forum next time someone searches
10-26-2014, 02:58 PM
4RunninHog;
philsey;
Found this using search, thanks guys for posting
10-12-2017, 10:05 AM
Real Name: Kevin
Real Name: Kevin
Just did same with
I just did the same thing with SiriusLED Extremely Bright 400 Lumens 3020 bulbs from Amazon. The stock DC3175 put out about 120 Lumens. These have 400 so its way brighter.
10-12-2017, 11:31 AM
Real Name: Q
Real Name: Q
Heres a video on how to remove all the lights so you can replace them.
https://www.youtube.com/watch?v=6O30-rctTDA
2016 BLACK Trail Premium - KDSS Toytec BOSS | 275/70/r17 BF KO2s | Custom roof rack | SCS Ray 10s | Relentless Front Bumper | 4300k HID Xenon Depot low beams | Baja Designs OnX6 Hi-Power 20", Squadron Pro, Squadron Sport, S2 Pro, S2 Sport | Blackout emblems | Interior LEDs | Wet Okole Seat Covers | T4R.org Trail badges | N-fab nerf steps | Hollywood racks bike rack | Spytec A119c dash cams - front/rear | SwitchPro | ARB Single Compressor
Instagram: thatonefitguyq
10-12-2017, 02:32 PM
I'm running the JDMAstar lights and they are amazing
10-23-2017, 12:49 PM
For anyone considering adding lights to the cargo area, spare yourself from taking the hatch apart, fishing wires etc. These bad boys are awesome, the pics don't do it justice.
2015 TRDPRO SUPER WHITE ~ ROOF RACK DELETE ~ REAR SEAT DELETE ~ LED ANYTIME FOGS ~ DRL DISABLE ~ DOMETIC CFX-28 ~ BORLA CAT BACK ~ SPRINT BOOSTER V2 ~ aFe MOMENTUM GT INTAKE ~ OTHER JUNK N STUFF
10-23-2017, 02:25 PM
was in the same boat as the OP and decided to make my own. Nothing will beat the brightness of these hatch lights.
10-23-2017, 03:25 PM
Real Name: Bump
Real Name: Bump
i just did the same thing with siriusled extremely bright 400 lumens 3020 bulbs from amazon. The stock dc3175 put out about 120 lumens. These have 400 so its way brighter.
man that is a clean cargo area
2015 Magnetic Gray Trail Premium - Build Thread: https://www.toyota-4runner.org/5th-g...ight=mbumpus11 <<<--- click that to see what I've done
10-23-2017, 08:40 PM
So when I did a quick google search for arclightleds I found a shut down website and some baller custom NSX tail light guts for $750
1995 ECR33 GTS-T (sold)
1990 s13 coupe TONS of work
2005 4Runner Sport V8
