10-09-2014, 10:12 PM
Real Name: Peter
Real Name: Peter
HELP! Tire issue Rubbing
I just got my 285/70/17 with MK6 -12mm offsets installed. Im having major rubbing issues. I have a 2014 limited. I cut the back part of the wheel well off (the part holding the "mud flap') and I'm getting rubbing in the front and the tire hits the metal (too dark and tired to investigate more tonight). Also, these are Terra Grapplers. Any help appreciated.
*2014 Limited 4Runner 4x4*. Toytec BOSS Suspension 3/2, BFG A/T 275/70/17, Level 8 Mk6 17x9 Gunmetal Wheels, RIDE Spacer Kit with N-Fab rails, Interior LED Mod, Flowmaster Force II Cat-back Exhaust and Airaid CAI.
10-09-2014, 10:19 PM
What metal is it hitting? And you'll need to do this.
10-09-2014, 10:46 PM
How much lift did you add? Just installed same tires, no additional offset . . . No problems.
2014 TEPP (Trail Edition Premium Pro), ICON S5 2.5, Remote Resi,w/CDC (Compression Damping Control), ICON Billet UCA's, Nitto Terra Graps, 285's, FN Five Star 17x8.5, SSSlimline Hybrid Bumper, Warn Zeon Platinum 10-S, Factor 55 Pro Link, Factor 55 Hawse 1.5 inch Fairlead, Metaltech OPOR Rock Sliders, KDSS, Sunroof, TRD Shifter & Engine Bling, Carbon Fiber Trim
1994 Limited, 257k Miles, 3.0
10-10-2014, 12:53 AM
Real Name: Ben
Real Name: Ben
I'm guessing you are rubbing the front liner and body mount? Moving the liner forward is easy and then you may need a body mount chop.
2013 LE, All Pro +2 LT Front, CVJ axles, King shocks, Califab rear links, Hutchinson beadlocks, Nitto Trail Grappler 35x12.5x17, 4x4 Labs rear bumper and front bumper and sliders, tints, Bajarack, RCI skids, 4.56 gears and ARB lockers/Compressor, Rigid Lights, Rydeen 360 camera system, KK6JZH...Keeping it mild Build & Pics
10-10-2014, 07:39 AM
Real Name: Peter
Real Name: Peter
Ill take some pictures today.
10-10-2014, 10:03 AM
I just installed 285-70/17 terra grapplers installed and had to remove the front mud flaps and move the fender liners forward. I still have to trim the drivers side part of the bumper in the fender well. That's the only part I have any issues still. I have a 2.5" lift and method nv 17x8.5" wheels with 4.5 back spacing. Hope this helps
2016 MGM Sr5 Premium, 285-70r17 BFG Ko2, Bilstien 5100s set at 2.5'' up front and 1"Eibach springs in the rear, 17'' FN 6shooters
10-10-2014, 10:28 AM
Here's hoping you've got at least a couple inches of lift under your truck and upper control arms that will allow you to put some extra caster into your alignment.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
10-10-2014, 12:25 PM
I've 285/70/17 Terra Graplers. No Major rub. Take out spacers. GL
10-10-2014, 02:23 PM
Real Name: Peter
Real Name: Peter
Ok so heres an update. Im mainly rubbing the metal from the wheel well on the back side where it wraps around. Im going to attach pics. I measured from the middle of the wheel to the bottom of the wheel well and I'm at 23" now. It is rubbing rubber though and its just on regular roads. Toytec thinks they may have done the alignment wrong with the LR UCA's.
10-10-2014, 02:44 PM
Limited must have different set-up. My Trail with KDSS has no rub with those tires only slight plastic chirp while reversing and wheels at fool lock. Nothing major. Sry for all your troubles.
10-10-2014, 03:02 PM
What is your caster set at? Going to have to cut the body mount, anyway.
10-10-2014, 03:04 PM
Yep body mount chop will take care of your problems
2014 Trail Edition<-2006 Sport Edition<-1994 Limited
10-10-2014, 03:17 PM
Real Name: Gary
Real Name: Gary
You shouldn't need a BMC with the 33" tires and correct offset wheels you have. I'm with Toytec that the LR UCA's were set up wrong. Probably set them up at the -2 setting or more instead of 0 to begin with. That would push the wheel back as a starting point . They already have -2 built in at zero.
SPC logo should face outward!Let's see pics of the the LR's
2022 4Runner TRD ORP Army Green
2010 4Runner Limited -SOLDhttp://www.toyota-4runner.org/galler...m-harper7.html
. ...........Rest in Peace Seattle Mike................
2000 Black 4Runner Highlander Edition
2001 Tacoma TRD 5sp
10-10-2014, 04:01 PM
Real Name: Peter
Real Name: Peter
Here are pics.
10-10-2014, 05:44 PM
I think the only width those wheels are available in -12 offset is 9". If so, a 9" wide -12 offset wheel is pretty aggressive. You would rub a bit more than someone with a 8" 0 offset or 8" -10 offset wheel would.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
