Originally Posted by WheelJack
"I'm looking for some options here and thought I'd lay it out to see if you guys can provide some direction. As you know, the Limited comes with the skinny 20 inch wheels. ...1. Get better looking and wider 20 Inch Fuel or XD's. I like the bigger looking wheel but want a better looking stance and then there's the off road part. The question here is what modifications do I need to do?..."
Hi WheelJack,
2012 'Limited'
'Stock rims/No lift':
Below: The one the left is the stock 'Yokohama' 245/60 R20. It is still mounted on rim and at 35 PSI; the tire on the right is the New GdYr 275/55 R20, It is waiting to be mounted (No rim)... See the difference?
These are GdYr Eagle LS-2's 275/55 R20
These are the GdYr Eagle LS-2
275/55 R20. They're wide (about 11"), have a
Low profile, perform extremely well @High Speeds and on curves! Work good in snow (not as superior as a true snow tire) but good. These are
standard equipment (Same size) on 'Escalade', 'Tahoe', 'Yukon'...etc because they're built to perform
"On-road".
"I could not be more satisfied with a tire AT ANY PRICE" 'An absolute performer'! Rgds
