11-10-2014, 05:15 PM
Guest
SpiderTrax Wheel Spacers
Has anyone installed any SpiderTrax wheel spacers on a 2014/2015 TE or TRDP yet?
Any issues?
Do I need to get an alignment after?
If anyone has Photos, I would greatly appreciate!
Thanks,
Roscoe
11-10-2014, 05:30 PM
Banned
Banned
there is nothing special about a 14, 15 or TRDP over say a 2005 4runner. Install them, torque in a star pattern and enjoy. No you don't need to align.
I would think that it would be just as straight forward as installing them on the 2010-2013.
I installed them on mine. Checked to make sure none of the nuts came loose after 100 miles and 500 miles. Just finished a 1,700 mile trip to NY while towing. No issues. They come with red loctite, use it.
An alignment is recommended after the install. I didn't, as I was getting ready to install my lift anyways, and that required an alignment.
2017 Lexus GX460
2016 Toyota Tacoma - TRD Off Road - SOLD
2013 4Runner SR5 4X4 - SOLD
1999 4Runner Limited - SOLD
11-10-2014, 05:34 PM
Spyder Trax
I have not installed them on my 2015 Limited, however I have installed them on my Jeep Rubicon Limited, I have not had any problems with them, I torqued them down as specified, I took a note from other poster on the Jeep forums and use my wifes nail polish to mark bolts, I would just pull a wheel off and see if the bolts move in which they did not. I know there is concern with spacers as which there are people that freak out about them and inject fear, but they work great, off roaders have been using them for many years in extreme conditions with no problems. If anyone has a set of spacers on their limited as well if you could post pictures, I know there are some floating around on this forum but I haven't see a 2014 or 2015 with spacers.
11-10-2014, 06:22 PM
The hubs are not significantly different between the J120 ('03-'09 4Runner, '07-'09 FJ Cruiser, '05-'09 Tacoma, and '03-'09 GX470) and J150 ('10+ 4Runner, '10+ Tacoma, '10-'14 FJ Cruiser, and '10-'16 GX460) platform vehicles.
So I wouldn't expect any issues with SpiderTrax, an alignment is recommended.
11-10-2014, 08:19 PM
You will more than likely have significant rubbing after installing spacers, especially if you're running larger than stock size tires. Be prepared to do a body mount chop.
You also need to maintain them like any other aftermarket mod. I swap my own winter tires on and off, so when I put the winter tires on I check the torque on the spacers. In the spring when I take the winter tires off I take the spacers off, clean them up, put new loctite on the studs, and put them back on.
2011 Trail Edition mostly stock, never wheeled
Instagram
Untitled Offroad
http://sittingbyariver.blogspot.ca/
11-10-2014, 09:18 PM
Real Name: CJ
Real Name: CJ
Added mine a couple weeks ago. These are 8" wide wheels with 4.5" back spacing. And it will force you to do the front fender mod. I had a very minor rub on the driver front before, but it was obvious on both corners after.
2014 Trail Edition -
Build Thread
2015 Epic in my own mind trip
11-10-2014, 10:02 PM
Originally Posted by BlackWorksInc
So I would expect any issues with SpiderTrax, an alignment is recommended.
what?
2014 Trail Edition<-2006 Sport Edition<-1994 Limited
11-10-2014, 10:53 PM
Originally Posted by crackiswack
what?
LoL Good catch, my phone must have missed that I wanted "wouldn't" rather than "would."
11-10-2014, 10:55 PM
I put them on a 2005 without issue. I now run on 14 base TE and work great. As stated, some minor fender rubbing in reverse, but not going forward. I did install Bilstein 5100's raising the vehicle F/R leveling it. Also put urethane bushing on sway bar end-links seeing quicker sway bar response. All this makes for a solid ride. My TE is mostly a road queen, but does see some trail use. (All weekend scouting new hunting areas)
Also, know that years ago, ran spacers on a 72 Dodge Charger that I built with a small block motor at just over 400HP dyno'd. Lots heavy throttle launches with that car without any failures.
11-10-2014, 11:28 PM
what about the part about the alignment?
11-10-2014, 11:31 PM
I'd get an alignment done for the sole purpose of trying to correct some of the rubbing via caster adjustment.
Instagram
Untitled Offroad
11-10-2014, 11:43 PM
most people dial in the caster when they lift and/or install larger tires, but you shouldn't get rubbing with a stock tire size. Spacers should have no effect on the alignment however
11-10-2014, 11:50 PM
No need for an alignment, however when I put mine on I did have to remove the front mud flaps and trim some of the fender lining b/c of rubbing. This is with no lift and stock size General Grabber AT2 tires. I don't have any pictures right now, but if youd like some I can get them tomorrow.
11-11-2014, 01:00 AM
Real Name: CJ
Real Name: CJ
Those are what I have pictured above. Love them!
Build Thread
