I went into work today to get some stuff done on the truck. I mounted and road force balanced my new Blizzak DM-V1s, removed the step bars, set tire pressure, aligned it, and then cleaned it inside and out.
I'm looking for input on getting my alignment a little better. I got the front pretty well dialed in but the rear has no factory adjustments. Rear toe isn't bad but the camber is off quite a bit side to side. I'm new to 4Runners and solid rear axles. What options are available? Or should I ignore my inner not-quite-OCD and leave it alone?
