12-07-2014, 05:10 PM
Real Name: Marc
Real Name: Marc
Is there a factory installed trailer wiring harness in 5th gen?
There is a 7 pin connector in back but I need to tow a trailer with electric brakes. Is there a n existing connector in the dash to connect a brake controller to or do I have to wire it in through the firewall?
12-07-2014, 05:16 PM
Yes. It's tucked underneath the column. You also should've gotten the pigtail with your owners manual.
12-07-2014, 06:24 PM
Real Name: David
Real Name: David
Even easier if you order the Toyota specific harness/adapter with your brake controller. Just plugs directly into the Toyota trailer wiring receptacle, up in there to the left of the parking brake pedal. Other end plugs into the controller. I didn't use the Toyota supplied pigtail at all - just plug and play!
2015 Trail Edition, Barcelona Red / Shrockworks sliders/ Airlift 1000 / Cooper AT3's 265/70/17 / Baja long rack /
12-07-2014, 06:52 PM
Real Name: 3 guesses..........
Here's a pic...........
'12 SR5, Blizzard Pearl * Factory (style) Fog Light Switch-Fits knock-out! * 30" BD Stealth LED Light Bar, Upper Grill '12 SR5 * Reverse Light Mod-SR5 Factory Bumper * FN f(x) Pro Wheels - Custom Coating * LLumar Paint Protection/Tint, Flowmaster Cat-Back, Bilstein 6112/5160, LR UCA's, AirLift w/Load Control, 285/70/17 Nitto TG, LW's D2S 4.0 HID low beam mod, V-LED Interior/Reverse/LMZ High Beam/Turn Signals/V-6 DRL Lights (all 5000K), Kappa Dash/Doors/Hatch Speakers, CompuStar Remote Start, B&M Trans Cooler, Devil Horn Emblems, XB LED Fogs, Dongle Mod, TRD CAI, DC 270-XP Alt
12-07-2014, 07:55 PM
Thanks for this info. I have a popup trailer with electric brakes. Those things make a HUGE difference!
12-07-2014, 09:09 PM
Real Name: BobH
Real Name: BobH
Wiring
And if you need info for the other end ---
12-08-2014, 01:18 PM
Guest
Electric Brake
Where seems to be the best place to mount the controller? I purchased mine (along with the Toyota specific harness) a few weeks ago. I can't decide where it will be the least in the way. Anyone have any photos? I would greatly appreciate any advice.
12-08-2014, 02:32 PM
My 4runner actually came with the Harness in the glove box. Summit racing has a bunch of controller options.
12-08-2014, 03:16 PM
Real Name: Karl
Real Name: Karl
What brand did you buy, the Tekonsha P2 and P3 do not have to be mounted level and can mounted with Velcro just about anywhere.
2016 Barcelona Red Trail
Its 5:00 somewhere.
WARNING: T4R.ORG IS HAZARDOUS TO YOUR WEALTH
12-08-2014, 03:41 PM
Guest
I bought the P3 from E-Trailer. It never occurred to me to use Velcro, wat a great Idea! Thanks!
12-08-2014, 03:57 PM
Real Name: Marc
Real Name: Marc
Thanks for the info. Is this wiring harness standard on all 4Runners?
12-08-2014, 04:00 PM
Real Name: Marc
Real Name: Marc
I haven't bought the vehicle yet. I'm having difficulty finding a 2015 Trail in Super White in CA. No one seems to have one. I may have to get a silver one. I prefer white but silver will hide desert pinstripes just as well.
12-08-2014, 04:12 PM
Real Name: Karl
Real Name: Karl
The harness from the plug under the dash to the plugs at the rear are standard from Toyota. The connector that goes to the controller comes with the 4runner this only has a plug at one end, but the best way if you buy a Tekonsha is to get the Toyota harness with the controller that has plugs on both ends.
From Tekonsha FAQ:
The P3 must be mounted in the direction of travel and should be fairly level from side to side. Front to back the control can be mounted at any angle.
Its 5:00 somewhere.
12-08-2014, 05:28 PM
Real Name: David
Real Name: David
Finding a place for the controller where it will be easily accessible, yet not in the way, is a bit of a challenge. I chose the Hopkins InSight Flex Mount for that reason.
The main unit is mounted out of the way, and out of sight, up on the wall just above and in front of the emergency brake pedal.
The hand control is just to the left of the steering column, on the dash. Easy to reach while driving, but not in any danger of getting hit by a knee.
The info screen is on top of the steering column, just below the dash instruments. Easy to see, without really taking your eyes off the road much.
You don't even notice the modules when you are in the car. All wires passed easily through the gap for the steering column - no drilling or cutting required.
Clean install!
Now, I'll try to add the photos! (I can't seem to get it to accept multiple photos?!)
12-08-2014, 05:30 PM
Real Name: David
Real Name: David
The info screen:
