Also, the 2wd models will get better MPG than any 4wd model because there is no front diff or transfer case to turn.
Even on sr5 and trails, the front axle on the drivers side is always spinning the differential planetary gears. This is slightly more rolling resistance than just wheel bearings. Also the transfer case itself introduces a slight efficiency loss as there is simply more mass for the motor to spin (even when in 2H).
With all else being equal (same tires. ride height...) the limited will get slightly worse MPG than a part time system in 2H. A 2wd model will clearly get the best mpg, but they are still not that great.
Like mentioned before. They are bricks and the motor is not the most efficient design in production. Direct injection and a better transmission would help a bunch, but it is still a heavy brick.
And just to clarify. The sr5 has a part time locked center/transfer case. The limited has a center diff that can be locked. Neither has a rear or front locker, but they both have atrac (a brake activated system that attempts to keep both wheels on an axle spinning at the same speed in crawl conditions)
