12-21-2014, 02:50 PM
High Speed Shimmy on 2015's ??
Back when I got my 2011, myself and quite a few other forum members battled a high speed shimmy of sorts ranging from 60-70 mph. Some were able to rectify the issue with repeated tire balances or new tires. Mine was a case of new tires and one shop that can get them right.
Has the issue been rectified? Just haven't seen anything mentioning the issue in a long time.
Are there any guys with 14-15 4Runners with the shimmy?
12-21-2014, 04:05 PM
Real Name: David
Real Name: David
No shimmy here - 2015 TE
2015 Trail Edition, Barcelona Red / Shrockworks sliders/ Airlift 1000 / Cooper AT3's 265/70/17 / Baja long rack /
12-21-2014, 04:19 PM
![Misterquad's Avatar](https://www.toyota-4runner.org/customavatars/avatar100152_1.gif) |
This was a problem with the FJ Cruisers too. Even brand new trucks off the lot. Some of them went through several re-balancings and rotations to fix it. Some just had to swap tires and rims.
The tires that were the toughest for me to keep in balance were BFGs, KOs and KM2s. And I am not talking about a single set, I have had over 6 different sets. The other thing to check was roundness. One day, the Discount Tire manager explained said to me that, "I can balance an egg", but it won't make it ride smooth. I actually had to take my KM2s in to a shop and have them shaved to get them round.
I would check balancing, roundness and mounting too. The rims are hub centric. And if not completely centered properly you will get a shake too.
12-21-2014, 07:29 PM
![Randyman...'s Avatar](https://www.toyota-4runner.org/customavatars/avatar89075_1.gif) |
Roadforce Balancing and Computer Ride Matching will help tremendously IMNSHO. Had the same issues with 6-7 sets of BFG All-Terrain's on my '87 T4R 4x4 and '99 TRD Tacoma (went through 3 sets of rear wheel bearings thanks in no small part to a horrible balance!).
Once I began demanding Roadforce balancing, been smooth as silk. This not only addresses balance much better than a regular balancing machine, but matches the low-spot of the rim to the high-spot on the tire (or vice-versa) and can get you closer to a perfect circle even with non-perfect tires/wheels.
Not all shops are equipped to handle this - find one that is and stick with them IMO. I believe the Hunter GSP9700 is a fairly popular model, and is what my Discount Tire uses to my repeated satisfaction. Don't settle for less IMO - our T4R's deserve it
Randy V
2013 4Runner * SR5 * 4x4 * Leather * Convenience Package * Black-on-Black *
* BFG KO LT265/70R17/C * SR5 Wheels + SpiderTrax * 5100's @ .85" * GrillCraft Grill Mods & TOYOTA Emblem * H9 & H9011 Headlight Swap *
* Alpine W910 DVD/NAV + H800 DSP * ARC Audio * JBL * JL * Morel * DieHard Platinum 31M * Total system power = 4,048 Watts RMS ! *
12-22-2014, 10:43 AM
![marshal's Avatar](https://www.toyota-4runner.org/customavatars/avatar104049_1.gif) |
Real Name: Will
Real Name: Will
ultimately you're looking at the tires being at fault for the shimmy. and unfortunately for BFG their tire construction process leaves fault in the roundness of their tires as a sacrifice for being super light.
the most round well constructed tire you can get right now comes from Nitto and Toyo, albeit they're very heavy. they use a special method for constructing tires that leaves them almost perfectly balanced and round from the factory.
12-22-2014, 11:23 AM
I cannot describe the ride quality improvement I found when I switch from BFG KOs over to Nitto TG. But I still remember that day and the drive to work. It was beautiful.
12-22-2014, 11:50 AM
Real Name: Will
Real Name: Will
i love my 285x75/17 Terra Grapplers, they'll be worn out by summer and I'm going shopping likely for a pair of 35x12.50R17 Trail Grapplers next go round
12-22-2014, 12:00 PM
![bste3's Avatar](https://www.toyota-4runner.org/customavatars/avatar46013_1.gif) |
Real Name: Dan
Real Name: Dan
I had this problem with my 2015. I had Goodyear Wrangler A/T Adventure tires swapped out for the OEM tires immediately upon possession. I ended up taking it back to the dealer to fix some rubbing between my steering wheel and steering column and asked them to rebalance / realign while it was in the shop. It was probably the tire place's fault, but that solved the problem.
-DLG, '15 4Runner SR5-Premium
12-22-2014, 01:38 PM
![Mooney's Avatar](https://www.toyota-4runner.org/customavatars/avatar114376_1.gif) |
BFG superlight? Always ran BFG, and still run them on my Gen 2, but went with Nitto partly because it was lighter . . . . they seem round to me.
2014 TEPP (Trail Edition Premium Pro), ICON S5 2.5, Remote Resi,w/CDC (Compression Damping Control), ICON Billet UCA's, Nitto Terra Graps, 285's, FN Five Star 17x8.5, SSSlimline Hybrid Bumper, Warn Zeon Platinum 10-S, Factor 55 Pro Link, Factor 55 Hawse 1.5 inch Fairlead, Metaltech OPOR Rock Sliders, KDSS, Sunroof, TRD Shifter & Engine Bling, Carbon Fiber Trim
1994 Limited, 257k Miles, 3.0
12-22-2014, 03:09 PM
Real Name: Will
Real Name: Will
Generally, BFG in an identical comparison BFGs products will always be significantly lighter than the competition. Of course the tire is round, but the manufacturing process they use, like Goodyear and a several others leads to imperfections. The manufacturing method that nitto, and their parent toyo use for building the carcass takes more time and is more expensive but results in a higher quality tire in the end.
12-22-2014, 03:32 PM
![Cheers!'s Avatar](https://www.toyota-4runner.org/customavatars/avatar112670_1.gif) |
Is this the case for OEM stock 4runners? I've had my 2015 Limited 80+ mph and no issues (but I'm on stock Yokohama GEOLanders and the stock 20" rims).
12-22-2014, 03:38 PM
![Taco04's Avatar](https://www.toyota-4runner.org/customavatars/avatar110414_1.gif) |
A lot of BFG's tend to run small compared to their competition which is another reason they run lighter.
Current Pack of 4x4 yotas...
2022 TRD LWB 4x4 Taco
2012 DC LT Baja Taco 4x4
2014 4Runner 4x4
12-22-2014, 03:42 PM
Hmm . . . got that.
However the 285/70/17 in BFG KO is 55.5 and Nitto T. Grapp is 46. Nitto was the lightest tire I could find in that category . . . multiplied by four tires the BFG added almost an extra tires worth of weight.
12-22-2014, 08:22 PM
Real Name: Will
Real Name: Will
We're they the same load rating? The difference from a C to a D is pretty significant in weight.
Regardless, that's a rarity that BFG wasn't the lightest - and surprising to me.
Real Name: Will
Real Name: Will
