Old 01-03-2015, 01:31 PM #1
RCFJ RCFJ is offline
RCFJ is on a distinguished road
Stock strut length/Adjusting Icon CO's
Does anyone have the length of the uncompressed stock strut? I am planning on installing my Icon CO's at stock ride height for now (crazy, I know) and want to match the lengths before I install.
Thanks
RCFJ is offline   Reply With QuoteReply With Quote
Old 01-03-2015, 02:01 PM #2
Jeremy556's Avatar
Jeremy556's Avatar
Spring rate and preload are different between them. You'll have to measure your ride height before install, then adjust the coilovers to match, after installation.
Old 01-03-2015, 02:04 PM #3
Ah, bummer thats a good point. Ok I guess ill change the question, anyone installed Icon CO's to level, or stock height who much thread was showing? That should at least get me close
Old 01-03-2015, 07:44 PM #4
Jhalko's Avatar
Jhalko Jhalko is offline
Real Name: Halko
Jhalko has a spectacular aura about Jhalko has a spectacular aura about
Jhalko's Avatar
Real Name: Halko
Maybe this thread would help you...
No/Low Lift Icon Suspension?
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
Jhalko is offline   Reply With QuoteReply With Quote
Old 01-03-2015, 07:59 PM #5
ya i read it and he did pretty much what i was trying to do but didn't answer my questions exactly. Also I figured out you can't adjust the coilovers when they aren't on the truck the shock shaft just rotates. so ill just figure it out when i install it
Old 01-03-2015, 08:05 PM #6
Jhalko's Avatar
Real Name: Halko
Jhalko's Avatar
Real Name: Halko
Bummer, i just remembered that thread and was hoping it helped. Try sending a PM and see what he says?
Build link:
Old 01-03-2015, 10:13 PM #7
Jeremy556's Avatar
Jeremy556's Avatar
You can with spring compressors, but yea, it is generally easier when on vehicle. Spray the threads with oil.
Old 01-03-2015, 10:25 PM #8
Misterquad's Avatar
Misterquad Misterquad is offline
Misterquad is on a distinguished road
Misterquad's Avatar
As mentioned above, I like the idea of mounting them and then adjusting them.
Though you might be able to crank them down ahead of the installation it will be much harder.
ICONs come preset at 2.5" of lift (but varies for each truck). So to lower it closer to stock height, you will need to lessen the lift or unload the springs about 1.25" on the threads. It is roughly a 2 inches of lift per 1 inch of threads. It is a close approximation to get you started.
Misterquad is offline   Reply With QuoteReply With Quote
Adjusting caster on lifted T4R with stock UCA rjfowler 5th gen T4Rs 17 10-24-2014 11:55 AM
FS: Like New ICON Coilovers Standard Length 700lb Coils, So-Cal $1025 Shipped iDRiVaT4R For Sale: Suspension/Wheels/Tires 0 01-22-2014 06:01 PM
Strut length on '01 2WD? whipkiller 3rd gen T4Rs 4 04-13-2012 02:27 AM
Stock drive shaft length? T-O-Double-D Classic T4Rs 2 05-26-2011 06:28 PM
90-95 4-Runner stock (OEM) catalytic converter length? Sidney Classic T4Rs 1 05-24-2008 08:58 PM
