Old 01-13-2015, 07:27 PM #1
reluctantkarmi reluctantkarmi is offline
reluctantkarmi is on a distinguished road
Icon Lift question on T4R trail w/ KDSS
I got the icon stage 3 lift and had it installed, but I was told that the rear sway bar hits the suspension (?) when it bottoms out (??)
The two mounts bolted on to the KDSS that hits the rear trac bar.. when I droop. So I am totally confused, does everyone else have this problem. Or did someone mess up on the install ? Sorry if this is patently stupid a question, but I figured asking can't hurt.
Warm Regards
Update : I called ICON and while they are looking into it, I wanted to see if anyone else maybe has a work around or knows something given my lack of comprehension of the subject matter.
Icon Lift question on T4R trail w/ KDSS-16274103742_2ffa67991c_o-jpg
On a long enough timeline the survival rate for everyone drops to zero
reluctantkarmi is offline   Reply With QuoteReply With Quote
Old 01-13-2015, 07:48 PM #2
brian0128's Avatar
brian0128 brian0128 is offline
brian0128 is on a distinguished road
brian0128's Avatar
Sub'd.
2015 Trail Premium Super White
2018 TRD PRO Super White
brian0128 is offline   Reply With QuoteReply With Quote
Old 01-13-2015, 08:30 PM #3
sandcrawler's Avatar
sandcrawler sandcrawler is offline
sandcrawler has a spectacular aura about sandcrawler has a spectacular aura about
you sure it's a "Stage 3"? those look like the OEM lower links.
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
sandcrawler is offline   Reply With QuoteReply With Quote
Old 01-13-2015, 08:36 PM #4
I got metal tech lower links, so I guess its not icons links per se. The rest was the following
Std travel front coil-over shock kit with 700lb springs
Rear 2.0 Aluminum Series Shock
Overland rear 3" lift rear coil springs &
Icon tubular Upper Control Arms
not sure if that helps...
Old 01-13-2015, 09:44 PM #5
Jeremy556's Avatar
Jeremy556's Avatar
Are you sure it actually hits, or just get's really, really close? Mine looks like it is sitting on the bar at full droop, but there are no impact marks, and no nasty noises when catching a little air.
Old 01-13-2015, 10:19 PM #6
rochmpr's Avatar
rochmpr rochmpr is offline
Real Name: Krister
rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all
rochmpr's Avatar
Real Name: Krister
Yes, when I installed my lift and had everything dropped out, the panhard and sway bar were hitting, potentially limiting further travel. Will be looking into ditching the KDSS in the future. Damn, could have saved money had I known earlier.
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
rochmpr is offline   Reply With QuoteReply With Quote
Old 01-13-2015, 10:24 PM #7
@rochmpr : If I knew earlier, I would have possibly considered another lift <..not sure that would not have this problem either to be honest. > and I sure hope ICON does come out with a fix..
@Jeremy556 - Def has a loud clang when I hit a ditch at a higher speed.. not very pleasant I haven't done anything offroad yet, since I just got it 3 days ago..
Old 01-13-2015, 10:27 PM #8
rochmpr's Avatar
Real Name: Krister
rochmpr's Avatar
Real Name: Krister
If I would have known earlier, I would have saved $1700 on the KDSS. The plan was to run the lift.
Old 01-13-2015, 10:27 PM #9
Jeremy556's Avatar
Jeremy556's Avatar
Might want to remove one shock and measure extended and compressed length, to make sure you didn't get long travel shocks.
The specs are probably around somewhere, but I have a spare set of Icon rear shocks on my bench and can measure if you need.
Old 01-13-2015, 10:57 PM #10
Mooney's Avatar
Mooney Mooney is offline
Mooney is on a distinguished road
Mooney's Avatar
Nothing hitting on mine, using ICON lowers.
2014 TEPP (Trail Edition Premium Pro), ICON S5 2.5, Remote Resi,w/CDC (Compression Damping Control), ICON Billet UCA's, Nitto Terra Graps, 285's, FN Five Star 17x8.5, SSSlimline Hybrid Bumper, Warn Zeon Platinum 10-S, Factor 55 Pro Link, Factor 55 Hawse 1.5 inch Fairlead, Metaltech OPOR Rock Sliders, KDSS, Sunroof, TRD Shifter & Engine Bling, Carbon Fiber Trim
1994 Limited, 257k Miles, 3.0
Mooney is offline   Reply With QuoteReply With Quote
Old 01-13-2015, 11:17 PM #11
harkco's Avatar
harkco harkco is offline
Real Name: Kevin
harkco is on a distinguished road
harkco's Avatar
Real Name: Kevin
Nothing hitting on mine either. Have been running Stage 2 with KDSS for the last 4 or 5 months.
2014 TEP with KDSS | My Build | VLEDs | WeatherTech DigitalFit | Rocky Road Supersliders | Nitto Ridge Grappler 285/75/17 | Gobi Stealth & Ladder | Rigid SR2 Combo 40" (Rack) | Rigid SR Combos 6" (Rear) | Icon Stage 2 with Billet UCAs | ARB 2000 Awning | Custom Toolbox | TRD Pro Grill | OEM Audio Plus | Rago MSP | SCS Ray10 Matte Gray | SP-8100 | SDHQ Ditch Brackets | Baja Designs S2 Pro Spot Ditch Lights | Baja Designs Squadron Pro Amber Fogs | Rigid E Series 30" (Bumper) | CBI Aluminum Front Bumper | BMC |
harkco is offline   Reply With QuoteReply With Quote
Old 01-13-2015, 11:54 PM #12
nothing making contact on mine with KDSS, ICON rear resi shocks & 2" coils, and OEM lower links.
Old 01-14-2015, 12:44 AM #13
@jere emy556 : I'll call the shop and have them check. @Mooney @harkco @sandcrawler : Thats good to hear, maybe I just got unlucky.. I'll double triple check..!
Thank you for taking the time to reply.
Old 01-14-2015, 05:18 AM #14
E-ROCKER's Avatar
E-ROCKER E-ROCKER is offline
E-ROCKER is on a distinguished road
E-ROCKER's Avatar
When I installed my All Pro rear springs I messed with the suspension a little to see full droop on the rear kdss sway bar. I noticed when I lifted the rear end up by the bumper using a jack the panhard bar made contact with the sway bar.
I took notice because of the noise it was making.
2014 Silver TE w/KDSS - Shrockworks front bumper w/30"LED bar-CBI Rear bumper w/tire swingout-Walker Evans 2.5 Coilovers/Rear 2.5 shocks-AllPro rear links & 3.5" rear coils-Total Chaos upper A-arms-OPOR/metaltech rock sliders-RCI front & trans skids-285/70/17 BFG KM2's-17x8 ATX Mojave's-DIY 3/4 flat rack-1/2" BL-Yaesu FT 2800-AFE Intake
84' Toyota SR5 Hilux Pickup Crawler
E-ROCKER is offline   Reply With QuoteReply With Quote
Old 01-14-2015, 08:51 AM #15
st8rocks's Avatar
st8rocks st8rocks is offline
st8rocks is on a distinguished road
st8rocks's Avatar
Do you have extended travel front coils? These come with the stage 2. I was surprised the OP has stock travel front coils with a stage 3 kit.
@reluctantkarmi maybe it's because of the 3" Overland rear coils??
2014 TE-KDSS
OPOR sliders, RCI aluminum full skids+(gas tank & A-arms), Icon Stage 2 w/ 3in overland springs, Cooper ST Maxx 255/80, Undercover HWMS w/ Superwinch Talon, K9 2.2
Daily:99 rav4 - OME baby lift, 31s, 5 speed Past:91 LC - built
st8rocks is offline   Reply With QuoteReply With Quote
icon , kdss , trail
Question about KDSS on an Trail Premium... Matt2558 General Discussions 1 12-28-2014 10:13 PM
2015 Trail Premium without KDSS question Mossyoakglock 5th gen T4Rs 11 10-21-2014 10:30 AM
Loud creaking when stopped and turning the wheel, 2014 TE KDSS with ICON lift MikeDeuce 5th gen T4Rs 8 01-15-2014 02:53 AM
Kdss trail option question ejT4Rm 5th gen T4Rs 1 05-28-2012 07:52 AM
Help - Installing Icon lift on TE w/KDSS proquip 5th gen T4Rs 18 03-20-2012 06:51 PM
