02-18-2015, 06:26 PM
#31
Originally Posted by 1engineer
Should be measured to center of contact patch.
Roger. But for any Lateral CG type calculations, the "Lever's hinge point" would need to reference the outer edge of the contact patch/track width, correct? (minus whatever sidewall flex/deformities exist at said conditions).
Randy V
2013 4Runner * SR5 * 4x4 * Leather * Convenience Package * Black-on-Black *
* BFG KO LT265/70R17/C * SR5 Wheels + SpiderTrax * 5100's @ .85" * GrillCraft Grill Mods & TOYOTA Emblem * H9 & H9011 Headlight Swap *
* Alpine W910 DVD/NAV + H800 DSP * ARC Audio * JBL * JL * Morel * DieHard Platinum 31M * Total system power = 4,048 Watts RMS ! *
02-18-2015, 06:40 PM
#32
Moderator
Real Name: Greg
Moderator
Real Name: Greg
If your tire was solid that would be correct. Here's a pic:
02-18-2015, 06:57 PM
#33
So basically yes?
With our rather skinny tires (height:width), I could see this sidewall deformity approaching the center-line of the wheel in evasive maneuvers. With anything much wider (like a 285 or 295), you'd be hard pressed to get enough sidewall flex to meet the center-line of the wheel for the lever/pivot part of the calculation - but I'm an audio/broadcast guy, not a suspension engineer (I'm sure it shows ).
Back to Broadcasting
Randy V
10-07-2016, 03:51 PM
#34
Real Name: W
Real Name: W
2011 SR5 4Runner Blizzard Pearl Tan Leather
2014+ Taillights
Black TRD rims
DBA 4k rotors with red TRD pads
06-04-2017, 10:05 AM
#35
Now are eBay wheel spacers safe?
07-04-2017, 12:26 PM
#36
07-04-2017, 11:26 PM
#37
Great thread, glad it popped back up, I have been debating the look hard recently and after reading this, and watching the recent tube vid, I am back where I started at 50/50. Okay, 51/49 leaning toward doing what I want cause it will look that much better.
Thanks again T4R.org community!!!
08-30-2017, 05:30 PM
#38
Real Name: Lucas
Real Name: Lucas
Any update? Did OP get spacers or what? I just put in 285s and the strut perch is very close to inside of my tires up front. Debating spacers myself!
Sent from my VS987 using Tapatalk
'17 Barcelona Red TRD Off Road Premium
-SCS Ray 10 in brushed copper
-Falken Wildpeak AT3W 285/70/17
-Xenon Depot Xtreme HID/amber fog light kits
-Bilstein 5100's with T1/T13 springs
08-30-2017, 06:15 PM
#39
Official Vendor
Official Vendor
Originally Posted by Dexter Morgan
Easy as balls. No alignment needed. Go with Spidertrax 1.25" adapters, period. I used them on my '03 Tundra and they were great. My tips:
- Clean the hub surface with a light sandpaper scuff, then alcohol wipe down and a quick blow of compressed air on the hub and studs.
- Offer up the spacer to the hub so you can see how it is oriented and just get a feel for it.
- Securing to the hub and use of Loctite: this has been debated, but Spidertrax includes a tube of Red with each set. I used just a dab to be on the safe side. I had no issues removing with a tire iron.
- Be very certain to secure the supplied nuts to the spacer in a star pattern. And don't tighten one all the way, then start on the other. Think of doing it in a few torque increments...perhaps 40 to 60 to your final spec of 90 ft lbs (or thereabouts, I forget their exact recommendation). You want as evenly spread out torque as possible.
- Offer up the wheel to the spacer as you would normally to a hub. Then follow suit as above with the wheel with regard to tightening your wheel lugs to the adapter
- Job done, I ran them for 10,000 miles with zero issues.
Great tips above.
Originally Posted by Intruder
Spidertrax 1.25" spacers.
Yes, and these are very good quality and come anodized (not just painted) so you don't see rusting inside the wheel area. I've been selling them for over 7 years now and they're tough as rocks.
SpiderTrax wheel spacers at Burtman Industries
Both colors in stock as we speak:
The main two reasons people are by buying these is... 1) They are rubbing with larger tires and don't want to cut anything. 2) They just want a wider look on factory wheels. These are made specially for Toyota's and push the wheel/tire flush with the fenders so you don't have that sucked in look anymore. It's a nice fit, and fools the eyes and makes it looks like you went up a tire size when you didn't.
For 4Runner/SUV Accessories, please visit www.burtmanindustries.com
My 4Runner website
https://www.youtube.com/user/burtmanindustries, New YouTube channel! please subscribe and I'll make more videos!
[email protected]
DO NOT PM - text/call 717-319-2100 (24/7)
08-30-2017, 07:39 PM
#40
Originally Posted by Jason B
Great tips above.
people who buy wheel spacers thinking it will solve their rubbing issues are silly. it creates a wider arc increasing your chances of rubbing on the fender and bumper. only spot it'll help is rubbing on the frame.
I want a set of 4 1.25 for the 4runner tho....stock trail wheels on 285's with spacers is TITS. IMHO. lol
@ Jason B
when you gonna sell some volant style taillights like you do for the titan world??????
08-30-2017, 07:59 PM
#41
I think making the track width wider also affects turning radius. Need more space for u-turns! But it is worth the looks.
As for the trd pro wandering on the highway, it could be because the rim is so narrow for the size of the tire. Someone mentioned there was a difference in ride quality and stability with a wider rim. Not sure the science behind that though.
2017 TRDORP White | 275 KO2 on Stock Rims | Stock Stereo with JBL GX302/GTO638/938, Kenwood KSC-SW11 | DDM 35W HID Ultra | Shrockworks Step Sliders | FR 5100s @1.75 RR Daystar 1.5 | Victory 4x4 Rack
08-30-2017, 08:30 PM
#42
I went with them. Only thing changed on my stock TRD Pro so far in relation to "modifying" the truck (everything else is accessories). Pictures on my "build" thread of the rub after 50 miles, typically only during hard over in reverse. It cleared up for me after installing the SSO bumper, but looking close at it I can see that simply adjusting the bottom 10mm bolt to push the fenders forward would have taken care of it too.
Loving the look and very happy I got them.
2017 TRD Pro Trim, Cement - First Toyota Ever (Where have I been all my life?!)
"Life Is So Easy, Life Is So Good, All Good Things Come To Me"
http://www.toyota-4runner.org/5th-ge...ld-thread.html
08-31-2017, 12:37 PM
#43
Official Vendor
Official Vendor
@ Jason B
Oh wow, you have a Titan too? And yea, on 4th gen for example, with 285's it hits the upper control arm, etc, so the spacers fix that.
My 4Runner website
[email protected]
08-31-2017, 03:49 PM
#44
I did...had 2 different ones from 2006-2011 then 2011-2017. now in a f250, wife drives the 4runner.
thats true they help clearance there as well.
08-31-2017, 11:30 PM
#45
Another vote here for Spidertrax! I've had them on my '08 Tacoma for over 100k. I did have one front wheel bearing go out at about 85k and just replaced them both, other than that I love the improved stance. The one annoying thing is most tire shops refuse to even look at your truck with them on due to perceived liability. I'm planning to do them on my '17 4runner. The stock stance looks like it skipped leg day...
