Old 01-25-2015, 05:31 AM #1
LRT LRT is offline
LRT is on a distinguished road
LRT LRT is offline
Driver door light / dome light problem
Having an issue with my driver door light and dome light. I have a 2011 SR5. All other doors work fine. When drivers door is opened, door light does not go on and dome light also doesn't go on.
Swapped door switch from driver to passenger side and switch is good. Bulb is good.
Any clue what could be the problem?
LRT is offline   Reply With QuoteReply With Quote
Old 01-25-2015, 09:18 AM #2
philsey's Avatar
philsey philsey is offline
Real Name: Um, Phil?
philsey has a spectacular aura about philsey has a spectacular aura about
philsey's Avatar
What are the last 3 mods you've done?
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
philsey is offline   Reply With QuoteReply With Quote
Old 01-25-2015, 03:17 PM #3
LRT LRT is offline
LRT LRT is offline
Changed out all interior and exterior bulbs to LED's.
Old 01-25-2015, 03:40 PM #4
Antman's Avatar
Antman Antman is offline
Real Name: Jeff
Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all
Antman's Avatar
Real Name: Jeff
HERE FISHY FISHY FISHY!
Antman is offline   Reply With QuoteReply With Quote
Old 01-25-2015, 07:20 PM #5
philsey's Avatar
philsey's Avatar
Old 01-25-2015, 07:55 PM #6
adam2562's Avatar
adam2562 adam2562 is offline
adam2562 is on a distinguished road
adam2562's Avatar
door sensor is sticking... it tells you when it's opened or closed.. you should also not get the red light that shows a door open on the dash if it opens and the light doesn't come on..
2011 TE KDSS NAV- K&N drop-in, Toytec/Eibach, Bilstein 5100's, Diff Drop, 295 Cooper STT Pro, OPOR Sliders, 17X9 XD Addicts, Sonoran Steel Panhard Bar, SPC UCA, RCI Skids
'97 Corolla, 90 Alltrac Celica, 94 Camry, 99 Solara 5spd, 98 GS400, 93 Accord, 97 Avalon(current daily), 2010 T4R LE sold, 2011 T4R TE
adam2562 is offline   Reply With QuoteReply With Quote
Old 01-26-2015, 12:45 AM #7
LRT LRT is offline
LRT LRT is offline
Thanks. Yes, no indication on dash when drivers door opened. You mention possible bad door sensor. Is this the same as the door switch? Thanks.
Old 01-26-2015, 01:22 AM #8
adam2562's Avatar
adam2562's Avatar
yes!
Old 01-02-2020, 10:25 PM #9
coreynw coreynw is offline
coreynw is on a distinguished road
Hoping to bring this thread back up. I'm having the exact same problem, after having done the exact same mod. I swapped the interior lights out for LED, and while I was replacing the driver door puddle mirror, it seemed like there was a short and now neither the door light nor the door position switch work correctly. Really the issue is that now if I have the headlights on, and I get out of the car, it doesn't know that I've gotten out and so the headlights stay on. I've check the fuses. Any thoughts?
coreynw is offline   Reply With QuoteReply With Quote
Liftgate dome light and door sensor cstraface 3rd gen T4Rs 7 04-01-2023 05:31 PM
Dome light problem TOYO 4R SR5 3rd gen T4Rs 36 02-04-2018 04:50 PM
No driver controlled Dome light??? Are you Kidding me! JJMAC 5th gen T4Rs 83 01-19-2011 10:27 PM
Intermittant Pwr Door Locks - Dome Light murph73 4th Gen T4Rs 0 09-25-2006 08:17 PM
