Old 02-04-2015, 10:21 PM #1
Doc_Fry's Avatar
Doc_Fry Doc_Fry is offline
Real Name: Steve Fry
Doc_Fry is on a distinguished road
Doc_Fry's Avatar
Mirror puddle light addition?
Has anyone add the puddle lights to a model without them? If so what part numbers did you use and was there wiring already there for the mod? What tips,do you have for install? I searched but nothing particular came up.
Doc_Fry is offline   Reply With QuoteReply With Quote
Old 02-05-2015, 09:27 AM #2
philsey's Avatar
philsey philsey is offline
Real Name: Um, Phil?
philsey has a spectacular aura about philsey has a spectacular aura about
philsey's Avatar
No.
... was there wiring already there for the mod?
No.
It has come up before, but because there is no wiring, plus the cost of components is high, I'm pretty sure noone's ever done it.
Contrary to what many think, 4Rs are wired specifically to the oem build and not one ohm's worth more.
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
philsey is offline   Reply With QuoteReply With Quote
Old 02-05-2015, 09:40 AM #3
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light
Moderator
1engineer's Avatar
Real Name: Greg
It can be done of course but not without a lot of work. Toyota wires them up to fit a particular model with specific options and no additional wiring except port installed options.
So you would need SR5 Premium mirrors and then you would need to run wiring to them. Then you would have to tie into the correct circuit to turn the puddle light on whenever you unlock the vehicle.
There have been several that have changed the bulbs to LED's and that in itself is a PITA but to my knowledge nobody has wanted to spend several hundred dollars to get a puddle light.
1engineer is offline   Reply With QuoteReply With Quote
Old 02-05-2015, 03:58 PM #4
drsus's Avatar
drsus drsus is offline
Real Name: Nic
drsus is on a distinguished road
drsus's Avatar
Real Name: Nic
a bunch of guys over at the tacomaworld forum did it. Tacomas also don't come prewired so you have to do all that yourself on those as well. i thought about it when i had my Tacoma but only because i like the extra safety of the signal in the mirror...i ride bicycles and motorcycles to so this is a huge plus for us when we see that signal on the mirror start blinking...but in the end i didn't bother and Im not going to bother on the 4R either, it is a lot of work/time that i don't have
heres one of the better ones. obviously this mod applies almost zero to our trucks but it does give you an idea of how much work you'd have to do.
2nd Gen Taco 4Runner Heated, Turn Signal, Approach lighting! & Power Fold? YES! (WIP) - Tacoma World Forums
drsus is offline   Reply With QuoteReply With Quote
Old 02-05-2015, 03:58 PM #5
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
While this seems reasonable, I would beg to differ. I'd be curious to know ow how much overlap there is between the wiring harnesses of different trim levels, as my sr5 for example has all the under the hood wiring for the rear cargo area inverter, even though it was not available on my trim level.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
Old 02-05-2015, 05:51 PM #6
Doc_Fry's Avatar
Doc_Fry's Avatar
Interesting, adding a circuit is not difficult at all if needed. The parts could be had from a wrecked vehicle as well. I am trying to figure out a way to add some type of light. Even if it wasnt the same as stock. Perhaps even a flush mount led light?
Anyone installed the 5th gen mirror covers with the blinker and puddle lights? SilverGs 4th Gen T4Rs 123 02-09-2020 12:06 PM
2014 Limited Side Mirror Puddle Light Led Mod? motoguci 5th gen T4Rs 17 03-28-2015 05:23 PM
5th gen puddle led light help rig 5th gen T4Rs 4 09-29-2014 09:05 AM
Problem with mirror turn signal and puddle lights Crseth 5th gen T4Rs 3 01-01-2014 08:34 PM
