02-10-2015, 01:46 AM
? For those with ICON extended travel coil overs
Anyone happen to know what the measurement is from top of the mounting surface to center of lower mount on the ICON extended travel coilovers?
I just put them on my truck. I previously had an OME lift in place and it looks like I gained a whopping 1/2 inch of drop (if that) with the ICONs.
The only reason I'm even asking here is related to the fact that the part# they sent me is actually listed for the 07-09 FJ/4Runner, but when I called about what appeared to be a mix-up with the order, they assured me it was the same as the 10+ FJ/4runners. They claimed the only difference was the swaybar relocation bracket which they swapped out of the box.
I've heard the extended travels only provide an additional 1 inch of drop, so I was not expecting much, but this is actually less than that. However I am comparing OME to ICON.... Not ICON to ICON....
I know... I'm worried about a 1/2 inch?.... But I paid for that 1/2" darn it ;-)
These ICONs sure do look sweet. Some serious quality workmanship on this stuff. I just hope they go without ever needing a rebuild like the OMEs.
02-10-2015, 04:43 AM
They will settle. And they are adjustable.
02-10-2015, 10:06 AM
I think it really is closer to 1/2in than 1in in wheel travel. My upper uniball is the down travel limiting factor on mine.
02-10-2015, 10:52 AM
@ wfo9
my extended coils are sitting in garage waiting to be installed if you want me to take some measurements.
2014 TE-KDSS
OPOR sliders, RCI aluminum full skids+(gas tank & A-arms), Icon Stage 2 w/ 3in overland springs, Cooper ST Maxx 255/80, Undercover HWMS w/ Superwinch Talon, K9 2.2
Daily:99 rav4 - OME baby lift, 31s, 5 speed Past:91 LC - built
02-10-2015, 10:58 AM
Real Name: Ben
Real Name: Ben
This^ and also the extended CO really only give more if you go to the TC LT kit.
2013 LE, All Pro +2 LT Front, CVJ axles, King shocks, Califab rear links, Hutchinson beadlocks, Nitto Trail Grappler 35x12.5x17, 4x4 Labs rear bumper and front bumper and sliders, tints, Bajarack, RCI skids, 4.56 gears and ARB lockers/Compressor, Rigid Lights, Rydeen 360 camera system, KK6JZH...Keeping it mild Build & Pics
02-10-2015, 11:08 AM
Not asking about ride height... Just the fully extended length of the shock.
02-10-2015, 11:09 AM
Originally Posted by st8rocks
@ wfo9
That would be useful. I know it is hard to get it accurately, but I was curious about mounting surface to center of lower eye.
02-10-2015, 11:10 AM
I seem to have a little more travel left in mine. Not much though. It would probably stress it to add more.
02-10-2015, 11:13 AM
I think you mean LT coil overs, right?
02-10-2015, 12:19 PM
Real Name: Ben
Real Name: Ben
There are no LT CO from Icon. The extended travel gives the max travel for the front suspension only if you go to the extended axle shafts, LCA and UCA from Total Chaos. Otherwise you only gain the little bit but will be limited by UCA uniball. You aren't maxing out the ext travel icons with even a stock replacement UCA and/or LCA. This was how MetalTech explained it to me and why they were running the TC kit in addition to the icon CO. They told me they got 2.5" additional wheel travel out of that setup. Not a cost effective route by any means, but it's currently the "best" option.
02-10-2015, 02:10 PM
Oh, I see now, I assumed the LT kits included longer travel COs. I guess all the travel is just from the change in geometry/movement ratios.
Man, even a little down travel is extremely painful to get with IFS. I knew this, but I did not realize how little even the LT setups would yield. If I'm reading this right. For 2700 you could gain 2" of down travel and that does not include the axles or all the other headaches with the fenders and more up travel....
I just checked again. My ICONS measure 22.75" fully extended. My OMEs were 22.25". The thing I forgot was that I had a .25" top plate spacer on the drivers side of the OME to take the lean out. So, I did gain almost an inch with the spacer out of the equation.
The wrong part numbers had me a little concerned, but this seems about right.
02-10-2015, 02:12 PM
Real Name: Ben
Real Name: Ben
The way I calculate it, each 1" of suspension movement up front costs about $1k. Lol
02-10-2015, 05:24 PM
Real Name: Landy
Real Name: Landy
Britt I remember looking at your Runner. You have the Camburg ball joint UCA's, right? I wonder what the difference would be if you had Uniball UCA's. I just ordered my suspension so we can compare soon.
02-10-2015, 06:01 PM
I have the "ET" Icons with the Camburg BJ UCAs as well. I would assume there could be a little downtravel gained by switching to uni-ball UCAs. At full droop, the BJ cup of the UCA hits the CO. It really isn't a problem so far though. At some point, I do want to install some different UCAs just to try it.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
