01-25-2020, 05:18 PM
#346
Originally Posted by TeaMan
I put KO2 285/70R17's on a 2020 Offroad Premium. Never drove it before the new tires. It's on the Optional TRD Grey wheels that come with a slight offset. I put a 2" leveling kit in the front, nothing in the back. The front ones rubbed slightly at full lock in reverse depending on how level the vehicle was. It rubbed about 85% of the time.
I took two bolts out of the inside, moved the wheel well in about an inch to inch and a half and trimmed that much off the fender. Got some matching paint from Toyota and touched it up after painting. You'd have had to know where it was to even see it unpainted.
I don't offroad (yet) so I can't tell you what it'll do when it starts to work. I suspect it'll rub some again, but since that will be rare for me, I'm OK with it. I parked it next to a 2019 stock 4runner and it made it look really bad. I do like how it looks. I like the handling, it floats a little, but it's OK, and I like the ride. Noise is fine too.
I do have a question on gas mileage, or rather tire pressure related to gas mileage. The tires show a max pressure of 50 PSI and are inflated to 36 psi. I'm only getting about 15 MPG with it. Again, it never saw the street on the stock setup, so I don't know what it was or would have been then. My question is what are others that may be running 285's are using for tire pressure and what kind of mileage you're getting with them? I know the max pressure is for load and don't want to wear the center by over inflating. Just curious what others are doing, and what results you're seeing.
Is it the photo angle. Looks nose high
01-25-2020, 05:40 PM
#347
It's the camera angle. It measures almost identical front to back. I keep thinking the same thing and keep measuring it. Sometimes it's an 8th of an inch higher in back, sometime front, sometimes identical. The smallest spacer they make for the back is 1.25" and it would be more than I'd want. I wish I could find a 1/2" one.
Teaman.
Reason: wrong symbol
03-12-2020, 01:34 PM
#348
275 bfg ko2
Well, it is close to no lift. Has only the 1" Cornfed spacer. This is on my 19 Limited, off with the 20" for 17X9's and 275/70/17 BFG KO2s
03-13-2020, 08:23 AM
#349
Teaman.
I think Cornfed will custom make you any size you want, within reason.
07-20-2020, 04:30 PM
#350
Anyone put a set of the 275/70/17 K02 on a 2019/2020 TRD Pro with the stock Fox suspension? Looking for pics and feedback.
08-04-2020, 06:43 PM
#351
Originally Posted by Raoul_Duke
I just put on a set of AT KO2 275/70R17s yesterday. I agonized over the decision between these and the 265s, but I'm glad I went with the 275s. I haven't notice any significant drop in acceleration or power, and I actually prefer the ride of the 275s to the stock Dunlop tires. It seemed that my rig felt every little bump with the stock tires. The 275 BFGs seem to roll over bumps and potholes much easier. The one thing I have noticed is a steep MPG drop in the few miles I've driven so far. On City streets, it's around 2mpg so far. I haven't done any highway driving yet, but I'll do so and post an update.
Originally Posted by Pkniland
Originally Posted by ZeroT4R
Originally Posted by NoOneBetter
275/70R17 no lift.
Originally Posted by ShortytheFireman
Mine just went on yesterday, no lift and no rubbing:
Originally Posted by wookiecrisp
I'll post mine up finally. 275/70/17 KO2s on stock trail. No rubbing, about 1/4" from liners at full lock on level ground.
Originally Posted by paulndot
BFG KO2s 275/70/17s no rubbing - never had any. 2015 Trail w/ KDSS.
Originally Posted by SoCalRunner
I had my tires on for a few weeks now. The ride is great I believe the performance is great but the mileage is not as great as I would like it to be but I consider that a trade off for the great looks. I run my tires at 44 psi and my mileage is roughly 17 mpg. my truck is completely stock and I have experienced absolutely no Rubbing with these tires.
Originally Posted by matt77
After less than 24 hours of ownership and only 36 mi on the odometer I upgraded to the KO2. No rubbing on the street, I have not had a chance to check rubbing through full articulation.
Stock vs 275s tires
Originally Posted by <3s4PLAY
heres my 2017 4Runner with 275 K02's on stock suspension
Originally Posted by cgrigsby79
Largely based on this thread and the fact that I may be waiting a bit to get my suspension upgraded, I decided to go with the 275s instead of the 285s. Got a killer deal (thanks to the thread alerting me to the bi-annual Discount Tire ebay sale) and was able to sell my OEM tires for $300 the same day I got these installed.
Initial impressions are that the heavier tires definitely are a drag on acceleration, but they look amazing and are actually quite a bit more comfortable than the stock Dunlops, even in the E rating. I still wonder if the 285 C rating would have been a better choice, but I just didn't want to mess with potential rubbing and the possibility of a body mount chop, and the 275 Es only weight about 5 lbs. more than the 285 Cs.
Before and After Pics...
Originally Posted by alyx_kat0913
275/70/17 ko2s without lift
Instagram
@ stryker
.t4r
Sent from my SM-G892A using Tapatalk
Originally Posted by jordanrb81
BFG KO2 275/70R17 no lift
Originally Posted by ryguytheman
But I've had no rubbing, and MPG took only about a hit of .1 MPG. My commute did change around the time I threw these on, FWIW.
I've got a slimline bumper on the truck now, and it's quite a bit heavier than stock with the winch in there, so my front end is even lower. Looking at suspension options to fix that.
I think I'm going to trade in my 3rd gen Taco for a 2020 4Runner TRD Off Road Premium. Probably the first thing I am going to upgrade are the tires. You all have the exact setup I'm looking at:
- BFG 275/70/17 KO2 Tires
Stock Suspension
Stock "Trail" Wheels
Are you all still satisfied with these tires? Any rubbing at full flex? What's your MPG like? Would you buy them again?
Thanks!!!
08-04-2020, 08:05 PM
#352
I have the exact same setup. 2019 TRDOR bone stock. Put the 275 KO2's before I actually had the papers signed. No rubbing at all.
I am satisfied with them. I have always wanted a set of these. I get 17 mixed 21 on the highway.
08-05-2020, 11:32 AM
#353
Stock Suspension
Thanks!!!
I have had very little to complain about. My suspension isn't stock anymore, but the tires themselves have performed great. Never had any rubbing, even on stock setup. I have torn them up and they keep going.
Here's a picture from just last weekend. Roughly 45K miles on the tires. This is after an especially rough 2 days of wheeling on some jagged rocks. The E rating gives me some extra peace of mind on the rocks as the tread starts to wear down.
I'm tempted to try something new when these are done, but I'll probably end up coming back to these since I had such a good experience. Though I do get the steering wheel shake from time to time, not sure how much the tires play in to that.
MPG is 16-17 average, but I'm heavier than stock by a fair margin.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
08-05-2020, 12:12 PM
#354
Cool! Thanks for the feedback.
Thanks for the info. Beautiful truck! I keep vacillating between Nautical Blue and Barcelona Red as my favorite colors.
You are heavier than stock? Are you running armor/bumpers?
08-05-2020, 12:36 PM
#355
@ will van
Yes, I have a steel slimline bumper with winch up front. Sliders too, and a basket and hi-lift. Plus a Plano box full of recovery gear in the trunk. Not to mention my 260 lb self.
Build Thread
08-05-2020, 01:35 PM
#356
@ will van
Awesome. That slimline bumper and winch setup is really cool.
I want to do RCI sliders and RCI steel front/trans/t-case skids. Curious how it will impact my mileage (in addition to the tires).
Thanks again.
11-30-2020, 12:58 AM
#357
All these look great. I can't wait to see what I end up with on my new rig.
12-10-2020, 02:15 PM
#358
I just got a 2021 SR5 4runner. Im taking it back to the dealership on Saturday to put on the 275 KO2s with the TRD pro wheels. Cant wait!
12-10-2020, 03:42 PM
#359
Curious to hear how it goes. I have a 21 venture and notice that BFG doesn’t recommend the K02’s for the 4Runner. I was thinking of just going with stock sizing, 265. Cannot image I would have a problem with K02’s on a stock venture.
12-10-2020, 04:33 PM
#360
Why wouldn't they recommend them? Where did you see or hear that from?
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
