Thread Tools Rating: Thread Rating: 6 votes, 3.83 average. Display Modes
Old 05-15-2015, 04:41 PM #61
TheWraith's Avatar
TheWraith TheWraith is offline
Real Name: Justin
TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light
TheWraith's Avatar
Real Name: Justin
Here's an update with Solar Gard 30% in the sides and 75% front windshield and 45% on the sunroof.
side profile
And yes it's screaming for a GOBI rack!!!! But sadly it's not in the budget this month
Today I looked and found out my passenger side is 37.25" while driver side was 38.25"
So I cranked up the passenger side gave it a little more pre-load and raised it to 38.25" on both sides.
I have an appointment with JC Alignments on Monday to get some real caster and adjust my rear link so my rear axle is straight...
What height do you guys have you fronts with your 3" lifts and 285/70r17 tires ???
My Build Thread
My kids call it ROCKY
2014 Raptor Liner White TEP w/ some mods.
TheWraith is offline   Reply With QuoteReply With Quote
Old 05-15-2015, 04:44 PM #62
TheWraith's Avatar
Real Name: Justin
TheWraith's Avatar
Real Name: Justin
I already have a set of Metal Tech Sliders coming...
Next Mod on the List : ( which one would you go with)... leaning to the gears cuz I'm getting hooked up on labor.
Option 1 = 4.56 gears & BCM
Option 2 = Gobi Stealth Rack
Option 3 = Full Steel Skids & BCM
Option 4 = Front Bumper & BCM
My Build Thread
Old 05-24-2015, 01:23 AM #63
TheWraith's Avatar
Real Name: Justin
TheWraith's Avatar
Real Name: Justin
Our little family trip to Santiago Peak today
Wish there was sum mud but oh well... wifey was white knuckling it on the passenger side; while the kids in the back was egging me on... but sadly The boss won and we never made to the top...
Alittle bit of pin striping but luckily it was superficial and wiped right off
My Build Thread
Old 05-28-2015, 10:03 PM #64
TheWraith's Avatar
Real Name: Justin
TheWraith's Avatar
Real Name: Justin
My Metal Tech Stage 2 Sliders came in today... wasted no time installing them.
Install would have been perfect till I drop the wrench on my forehead( right above my left eye brow)
BCM and FatPats 2" Body Lift in 2 weeks
My Build Thread
Old 05-29-2015, 10:15 AM #65
Belaire23's Avatar
Belaire23 Belaire23 is offline
Belaire23 is on a distinguished road
Belaire23's Avatar
Body lift!?!? Can't wait to see this!
Also what overland rear springs were they? The 2" or 3"?
Keep up the awesome work
2015 Trail Edition Magnetic Gray
Magnaflow 12256, exhaust cutout behind y pipe, plastidipped emblems and valences, nfab nurf bars, hidden light mount in grille, engine silencer delete mod, 285/70r17 Nitto Ridge Grapplers, spider traxx wheel spacers, toytec Boss lift with superflex rear coils and FJ trim spacers in rear, high caster JBA UCAs
Belaire23 is offline   Reply With QuoteReply With Quote
Old 05-29-2015, 10:33 AM #66
wfo9's Avatar
wfo9 wfo9 is offline
wfo9 has a spectacular aura about wfo9 has a spectacular aura about
wfo9's Avatar
Why the body lift? Just curious.
I would go with option 1....
Since you will have the front clamshell out already... might as well do an ARB in it at the same time. Just make sure the installer knows what they are doing. Many of us here have just done cores with East Coast Gear Supply It's pretty easy to swap out the clamshell and 3rd member yourself.
wfo9 is offline   Reply With QuoteReply With Quote
Old 05-29-2015, 10:47 AM #67
TheWraith's Avatar
Real Name: Justin
TheWraith's Avatar
Real Name: Justin
I'm using 3" Overland springs... she has a definite rake..
My Build Thread
Old 05-29-2015, 10:54 AM #68
TheWraith's Avatar
Real Name: Justin
TheWraith's Avatar
Real Name: Justin
Why body lift ??? I want 35x12.5 or even just 33x12.5 without touching / modding the firewall...
I was going to leave it open diff in the front... I don't plan to do crazy rock crawling to require a front locker. If I do plan on doing a front locker; I will end up just swarping out the front calmshe'll & 3rd member with an East Coast Gear Supply one. But as for now I'll just leave it open...
My Build Thread
Old 05-29-2015, 11:11 AM #69
mc813's Avatar
mc813 mc813 is offline
mc813 is on a distinguished road
mc813's Avatar
@TheWraith what HID kit did you use for the headlights? Was it plug and play?
2019 TRD OR | Front Runner rack | Shrockworks sliders
Gone
2015 Trail
2000 SR5
mc813 is offline   Reply With QuoteReply With Quote
Old 05-29-2015, 11:24 AM #70
TheWraith's Avatar
Real Name: Justin
TheWraith's Avatar
Real Name: Justin
I went with Retro Solutions 55watts Slim line 5000k HID kit w/ their relay harness. Their 35watt slim line ballast should be plug and play. But the 55watts requires a harness.
My Build Thread
Old 05-29-2015, 11:43 AM #71
king noob's Avatar
king noob king noob is offline
Real Name: ryan
king noob is on a distinguished road
king noob's Avatar
Real Name: ryan
wow, you're not wasting any time are you? the truck looks awesome, tasteful mods thus far.
king noob is offline   Reply With QuoteReply With Quote
Old 05-31-2015, 09:08 PM #72
Belaire23's Avatar
Belaire23's Avatar
No matter what you do would still like to see it on 35s for sure. They also make a 6" drop bracket lift kit for your suspension if you wanted to go that route. It's just an FJ kit that can be fitted on our rigs.
Old 05-31-2015, 10:16 PM #73
TheWraith's Avatar
Real Name: Justin
TheWraith's Avatar
Real Name: Justin
I know I have pondered that set up. Spoke with Fabtech and the have a drop brake coming out for the 4runner as well. So I was told by their tech support.
But since I have kdss ... I think 3"suspension and 2" body is enough. For me till I rip out my kdss completely. But that's down the road...
My Build Thread
Old 05-31-2015, 11:37 PM #74
Belaire23's Avatar
Belaire23's Avatar
Here's a guy that went with the 6" FJ lift and had pulled off his KDSS too rollin on 35s. It's a great look.
ma_mu_ Build Thread & Offroading Pics
I'm just curious to finally see a body lift on our rigs. Would consider one too if it works out well.
Old 06-01-2015, 07:18 AM #75
TheWraith's Avatar
Real Name: Justin
TheWraith's Avatar
Real Name: Justin
Hhhmmmm I been told that drop brackets causes too much breakage on an IFS ... which is the reason why I didn't go that route. I don't know maybe I'll stick with what I have and just do a 2" BL & BCM and hopefully be enough to run 35x12.5
My Build Thread
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
wyanrard's 2003 SR5 V6 build thread/picture thread wyanrard 4th Gen T4Rs 56 02-04-2017 01:03 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
