09-19-2020, 04:27 AM
#481
Originally Posted by eevanskiteboards
That's intense. I was exploring winrock a few months ago and even those green/easy trails were crazy. I felt as if I went further into the trails I would have broke something as well.
Sent from my Pixel 3a using Tapatalk
I was on what they were calling a hard blue and wondered off trail by mistake. Let's just say my winch got one heck of a work out and those that helped me said the trail I was on was no doubt a double black diamond.
09-19-2020, 04:30 AM
#482
Originally Posted by TheWraith
I was told to remember how many turns it took to take the old ones off and do the new ones going in. Should get me close. Which it did. Still needed alignment afterwards. The steering wheel was a little off ...
this is exactly what we did but with the driver side one still bent a little it was impossible to get it that close, but it was in the dark and we had taken off the broken piece hours before so we did best we could just to get off the trail. It was funny as when driving off the trail the steering seemed fine, but when back on the road discovered this.
09-19-2020, 09:57 AM
#483
Real Name: Justin
Real Name: Justin
Originally Posted by EddieV4runnin
Did you bend the inner or outer rods??
Inner tie rod gave up the ghost. Hopefully that rock won't be there when I go again next year
My Build Thread
My kids call it ROCKY
2014 Raptor Liner White TEP w/ some mods.
09-19-2020, 10:02 AM
#484
Real Name: Justin
Real Name: Justin
Lesson learned for me. I'm planning on switching out both tie rods to moog ones. As keeping the ones on there now for trail back up.
My Build Thread
09-21-2020, 08:21 AM
#485
Agreed, I now travel with 2 inner and 1 outer tie rods for back up. they are small and easy insurance to carry.
09-21-2020, 05:30 PM
#486
Where are you guys sourcing your time rods from? rockauto?
I don't mind my moogs rusting and looking dirty, gives it personality. I've donated one on trail fixes at the offroad park.
Rock on Fellas
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
09-21-2020, 06:57 PM
#487
I get my inners from RockAuto. My spare outer I get from Toyota. i've purchased from Sparks in Mrytle Beach, Toyota Dallas, and this time McGeorge in Richmond, VA. Prices are all over the place between dealerships and my local one is always most expensive.
09-21-2020, 08:07 PM
#488
Real Name: Justin
Real Name: Justin
Amazon $75 bucks a pop... unless you know some where cheaper
My Build Thread
09-22-2020, 09:18 AM
#489
Last night Rock Auto was $57 each for the Moog inners. When I was broken on the trail we paid about $100 from a local auto parts store in TN. My outer was $39. I will also carry one extra boot and clamps. When I broke the passenger side three weeks ago it bent about 90 degrees before breaking and the boot was still fine, but they are cheap and light to carry on trail. Going back out next week to Windrock and will be over prepared this time.
Reason: corrected text
09-23-2020, 08:50 PM
#490
Real Name: Justin
Real Name: Justin
I still need to replace my clamp. I still only have a very expensive zip tie (ty-rap brand) on there.
I can get those clamps at like auto zone can't I???
My Build Thread
09-24-2020, 07:34 AM
#491
I don't see why not. When we replaced mine we reused the stock ones without any issue. you could even use a hose clamp if you couldn't find anything else just like the zip tie.
11-07-2020, 12:13 AM
#492
Real Name: Zach
Real Name: Zach
Any chance you have info, pics, or description of the wiring used for the front locker?
Awesome build. Jealous of what you guys have on the west coast. I am learning and tackling more and more where I'm at.
2017 ORP, 3" lift, Icon UCA, 34s, NTK Fab body mount, angle grinder bumper cuts, RSG sliders, 4.56 gears, Front & Rear E-lockers
1985 CJ-7, 4" lift, 35s, fully locked, fun to drive offroad
11-07-2020, 10:53 AM
#493
Real Name: Justin
Real Name: Justin
All it is ... is a positive and a negative
My Build Thread
12-04-2020, 02:34 PM
#494
Real Name: Justin
Real Name: Justin
I have a bunch of updates:
installed the Demello Offroad front bumper :
I paid to have this custom stainless steel filler plate made. Demello made it for me. But they wont make it maybe if you order your bumper with one theyll make one for you ...
heres no filler plate:
versus with filler plate:
I also installed new Diode Dynamics 42" Light Bar, Diode Dynamics SS3 Pros Ditch light ( in a driving pattern) and Diode Dynamics SS3 Pros Fogs
My Build Thread
12-04-2020, 02:47 PM
#495
Real Name: Justin
Real Name: Justin
for the longest time ... Ive been battling the "KDSS gangster lean" for awhile the blackgate customs rear spacers fixed the issue. But then I broke a tie rod and had to get the rig re-aligned. And the lean came back.
I ended up getting the Treaty OffRoad front kdss spacer. And it seemed to fixed the issue...
I installed it myself and fixed the kinked kdss bar. suffice it to say... I may need to order new rubber bushing for the front.
this was the lump sided kdss bar
My Build Thread
