03-01-2015, 12:28 PM
Is "Hitch Shackle" a good idea? Also, recommendation for a tow strap.
I have seen many having something like this:
Is this a good idea?
Or a hitch hook? (which one should I get if I am to pick one)
I tried to read up/research about this..... most said "do not exceed hitch capacity".... what's the hitch capacity of our 5th gen 4Runners stock hitch? 5000lb? This is not the same as "towing capacity", right?
Any recommendation for a tow strap that I should get and put in the vehicle?
Lastly, what's the and how to find the "hitch capacity" of the stock hitch for the 2014 Highlander?
Thanks in advance!
03-01-2015, 12:44 PM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
Whoever said hitch capacity is full of it. In a straight line pull you can pull until you reach shear strength of bolts or bending strength of the hitch. Both are much greater than your truck's GVW. Either choice is fine. There is already an attachment point on the rear though that does just fine. 2X GVW on strap. There are 100 threads on this exact topic.
03-01-2015, 01:00 PM
I love the Smittybilt version... have used it a few times to yank people out of snow banks when in Oregon.
Its sticks about as far out as I would want it... these things can really hurt if you catch them on your shin. I think the hook is kind of dangerous left mounted in a receiver all the time....
Re: tow strap- Any off-road store will have them (ORW in San Diego).. they are always littered over the showroom floor somewhere!
2022 SR5 Base 4WD: TRD Pro Suspension, TRD Skid, Eaton Elocker, BFG KO2, Katzkin Tuscany Leather w/heat, Llumar IRX 35%, Radenso Radar + Escort Laser Shifters, Thinkware Dash Camera, PPF, Ceramic.
03-01-2015, 01:30 PM
Real Name: BobH
Real Name: BobH
Strap
Keep it simple, no shackle, put the end of the strap into the receiver and put the hitch pin through it.
Tow strap or yank strap? A yank strap will stretch and reduce the shock when pulling someone out. It's also called a snatch strap.
__________________________________________________ ___________________
03-01-2015, 01:34 PM
Real Name: Dave
Real Name: Dave
Never liked the hook version but use a D shackle all of the time and one lives permanently in my rear hitch. Smart to carry at least one extra to use with straps. Don't skimp on either.
When using a shackle remember to turn back a 1/4 turn after tightening so it doesn't bind.
Them Be Me Mods - 2011 Black Limited / Trail Mutt
03-01-2015, 01:46 PM
While this may work in a pinch, I would not recommend it for consistent usage. The hitch pin is not designed to take an inconsistent load from the end of a strap. Its breaking point is much higher when distributed over the load of a designed tow bar (receiver shackle or hook in this case).
03-01-2015, 01:47 PM
Great tips!
Are there any generally considered good brands? I am trying to pick something up from Amazon: Smittybilt? WARN? Rugged Ridge? CURT?
03-01-2015, 02:12 PM
I love my Factor 55 HitchLink
Product Description
Use your receiver as a recovery tow point.
•Lightweight precision CNC machined 6000 series aluminum
•Weighs only 1.9 pounds. Steel versions weigh up to 8 pounds
•Rated at 9500 pounds
•Ultimate failure at 51,000 pounds
•Fits standard 2 inch receivers
•Fits common ¾ screw pin shackles/D-Rings
•Anodized or powder coated for oxidation protection
MADE IN USA
WARNING:
Never exceed factory receiver hitch pull rating
Always use a quality steel alloy 5/8” hitch pin
Always pull in line with the hitch, do not bind or side load the shackle
Best Regards,
Saker
03-01-2015, 02:23 PM
Real Name: Dave
Real Name: Dave
Originally Posted by jicko
Great tips!
I have maybe a dozen spread throughout the truck, tractor, atvs, etc and usually buy 3/4" Smittys from Amazon. They also make decent recovery straps of all sizes and capabilities.
Here is a good start http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 Then you just buy extra D rings if needed.
Also love these
http://www.amazon.com/Master-Lock-14...WKV50S7G3CQ290
Real Name: John
Real Name: John
I would spend a little (ok a lot) extra for the Factor55 bling Hitchlink merely for its weight difference from something like the Warn. Southeast Overland in Seneca has both tow and snatch straps. Steve can tell you exactly what you should get based on what you tell him are your needs. He teaches recovery courses for the off road world as well as running his shop.
2012 T4R Trail Edition Magnetic Gray~KDSS~Cooper STT Pro 285/70R17•Pilot stubby•3M Door Guards•WeatherTechs•Console Vault•Canvasback Liner•Interior LED upgrade•BudBuilt BumpOut Sliders and full skids•ICON Extended Travel suspension•Rokmen lower links•ARB•Warn M8000•Southeast Overland rope~CBI rear bumper
03-01-2015, 02:33 PM
Real Name: Dave
Real Name: Dave
Have the Factor55 on front attached to the winch line but that and more the rear I've always thought were answers to an unasked question
03-01-2015, 02:34 PM
I would get an ARB snatch strap.
ARB Snatch Strap 17,600lb (ARB705)
This is the one I use (the 17,600lb one).
You get quite a bit of power / force from the elasticity and dynamic effect of the strap stretching and yanking. Think of it as a huge rubber band. I pulled out a lifted, fat-tired F-150 that was buried up to the hubs in the bottom of a lake with this thing (and my 4runner). It offers much more power than just a static tow strap.
Contrary to most people's tendencies, going bigger is not better for a snatch strap. You really want - per recommended instructions - the strap to be rated for somewhere between 2 and 3 times the vehicle weight you're snatching with. So, for a five or six thousand pound loaded 4runner, you wouldn't want any bigger than this.
2015 Trail Edition w/ KDSS, Super White, Toytec Ultimate Lift, Airlift Airbags, 255/80/17 Cooper ST Maxx, RCI aluminum skids and bumpout sliders, H9/9011 Headlight Mod, Rear Diff Breather Mod, Homemade Roof Rack, Katzkin leather interior
^^^ this and it won't impact departure....
03-01-2015, 02:52 PM
hmmm.... sure do like that Factor 55 more than my Smitty... better fit, doesnt stick out as far.
03-01-2015, 02:55 PM
Real Name: Dave
Real Name: Dave
About straps, the min would be one 25-30' long AND one 6-10' long to wrap around a tree. The extra D ring connects them.
And not many people may know but there is a decent amount of space in the compartment forward of the jack towards the rear seat which is perfect to storing straps.
Somebody mentioned the truck weight but keep in mind that just truck weight is fine if pulling on pavement with no incline. Pulling up hill means working against gravity. But you will most likely not need to pull yourself out of a mall parking spot and much more pulling power will be needed to get yanked out of mud, which is a much more likely possibility.
