Thought provoking thread! It led me to read about rating factors for hitch pins
https://www.extension.purdue.edu/ext...ppp/ppp-94.pdf
Hitch pin attach point - - - If the strap is pulled at an angle the load on the pin is uneven so a hitch pin should only be employed for a straight pull. Pulling at an angle can also cause chafing of the strap against the edge of the receiver.
Bow shackles' curved surface allows a wider variation in safe pull angles
Many times it is difficult to set up a recovery for a straight pull
Some hitch shackles are drilled to allow vertical and horizontal orientation for more versatility
Jim _ My Adventure Blog:
http://suntothenorth.blogspot.com
2018 TRD Off Road Premium
ARB on-board compressor - RadFlo coilovers & rear suspension - Engel freezer-fridge - All Pro LCAs - African Outback roof rack, RCI skid plates
