Originally Posted by Cam_23
New problem has came up now... Driving on the HWY it will not shift into overdrive to cruise at a lower RPM... when I slide the shifter over to the shift select option the gear 4 flashes twice then goes away and doesn't allow me to shift up or down. The only way I can get it to shift to the higher gear (5th I believe) is sliding it into neutral and then back down to drive.....
Almost sounds like it's stuck in "S-4" manual shift mode.
I know S-Mode
1) Disables ECO Indicator
2) Defaults to 4th Gear (no Overdrive unless you flip to 5th)
and
might possibly
3) Disable Cruise Control (maybe).
Curious what codes you can pull.
Also - My Tranny will hold 4th gear sometimes (no doubt due to "Learning" my 'passing slow people in the left lane' habits
- sometimes it will hold for 15-20 seconds, and I can switch to S-4 and back to "D" and it goes right back into 5th)
Good luck!
