03-29-2015, 12:11 PM
Real Name: Derrick
Real Name: Derrick
Icon Lower Control Arm Skid Plate & Secondary Shock Set Up
I read some treads about them, but Is anyone actually running this set up? I am curious how well it protects the LCA and if it adds any real true performance with the secondary shock. Pros-Cons? Pictures? Thank you in advance.
http://iconvehicledynamics.com/shop/...te-system.html
2015 SR5, Magnetic Metallic Grey, 3rd Row, Premium Entune W/Navigation, All whether Floor Mats & Cargo Tray, Shockworks Sliders, Front Matching 3M Window Tint, AVS Smoke Hood Protector, ToyTec Ultimate 3" Lift w/Eibach Front Springs, 5100 Adjustable Bilstein, Superfex 2" Rear Springs, LR UCA, 17x9 Fuel Throttle Wheels, Toyo Open Country ATll E 285/70/17 Plasti Dipped Front, Rear Emblems, TRD Pro Front Skid plate, TRD Pro Shift Knob, TRD High Flow Air filter, TRD Pro Badging, CBI Ditch Light Brackets, Riged Dually's Led's, Riged SR 6" Led's, Tuffstuff 40" Led, AOB Switches, Painless Boss Fuse Block, Gobi Stealth Rack, Hi-Lift, True Temper Axe, Bully Shovel, Cobra ST75, 4' Firestick w/Firering, Comet Antenna Mount.
Reason: Forgot Icon Link
03-29-2015, 12:32 PM
I ran the setup for over a year and upgraded to a full Total Chaos setup. I have writeups on both on www.dirtroadtrip.com - go search there. The setup worked as advertised - but using the kit to full potential is going to be hard on OEM LCAs and the stock bushings/ball joints.
If you are willing to drop $1k per side on bypasses go ahead and get a more robust setup from TC with the option to run Fox/King/ADS. Buy once cry once... Wish I had...
2010 Trail Edition | Not Stock
Scratching the itch for off-road adventure one weekend, one vacation at a time, taking our Toyota trucks well off the beaten path one day and driving them to work the next! Covering the trucks, the trips, the gear, and the lifestyle.
Real Name: Dave
Real Name: Dave
I'm using there LCA skid but haven't done the hoop and secondary bypass yet, but here's how they look, minus the hoop and bypass shock, only reason I got them was they were In stock locally and were priced fair I have zero intention of running bypass shocks as my off roading doesn't involve much hi speed activities other than driving on the highway home from the trail.
•2014 4-Runner SR5P• FOX/ICON Suspension♦WKO Bumpout Sliders♦ICON Shock Skids ♦RCI Skids Front to Back♦
♦Baja Rack♦GOBI Ladder♦LED Interior Swap♦Weather Techs♦ 17x8.5 Level 8 Wheels/BFG TA/KO's♦ALL Pro Sway Bar End Links♦Wheelers Superbumps
03-29-2015, 02:38 PM
Do you plan to do high speed off roading?
03-29-2015, 05:28 PM
Real Name: Derrick
Real Name: Derrick
Thanks for the info and the picture. I don't plan on doing much if any high speed off roading but I'm very interested in adding some degree of extra protection with the skids because Colorado tends to be very rocky and the price is reasonable. I also liked the option of adding the additional bypass shock if theirs any real benefit to it. I am very happy with my current set up, but as many of you know the build and upgrade bug gets ya!
03-29-2015, 05:31 PM
Real Name: Landy
Real Name: Landy
If you're not doing anything high speed, I wouldn't. If anything, I'd upgrade to a higher quality coilover.
03-29-2015, 06:39 PM
I wheel my truck in rocky conditions and have never hit a front lower control arm. I'm not saying it is not possible (anything is), but so far I have not encountered a need for them.
Just think about it for a minute. You are going to have much bigger problems than the front arms if you approach an obstacle in such a way that they hit . If your tires are up on the high point (like they should be), then your front control arms will always clear.
I would not add the weight. loss of clearance... for almost no benefit. bypass shocks are completely unnecessary on a trail rig.
03-29-2015, 08:21 PM
I got some for Christmas, was all happy until I realized they don't fit w kdss. Then I had to give them to my son with fj... Damn it. I wanted them because, I armored everything else, why not a arms
2010 trail, Icon shift nobs before I left the lot (from previous 2011 sr5), kappa mod, baja rack, Goodyear MT/R 285-70-17s, SCS Stealth 6 Bronze, Icon extended travel front coil overs set at 2.5, rear Icon shocks n Overland springs, Icon tubular uniiball UCAs, Metal Tech Adjustable Rear LCAs, Total Chaos LCA bracket skids, Icon rear shock lower guards, Shrockworks step sliders, advanced cup holder mod (added coozies), full Shrockworks underbelly babaaaay (skid plates), sPod, CBI rear bumper and tire carrier. ARB air compressor, ENGO winch, Shrockworks front bumper, Vision X led pods under, Engo 20 in bar, rear Rigid, and Ditch Lights. Safari Snorkel on the way.
03-29-2015, 09:33 PM
Real Name: Derrick
Real Name: Derrick
Eh, for 180.00 bucks and a little added protection and piece of mind, Ill just get the LCA skids. Like Tengu said, why not armor them too. Thanks for the advice!
03-29-2015, 09:47 PM
I just bought Joneseyyy's old set up from him. I still am waiting for my secondary shock to get built. I decided to go with Icon Omega Bypass as I already have the same shocks in the rear.
I mostly run my 4Runner in the Desert which is both trail situations but a lot of high speed desert runs. I also plan on a Baja trip later this year out to Mikes Sky Ranch.
I am very excited to get everything installed and will post everything on my build thread once completed along with feedback compared to the coil-over only set up........
03-29-2015, 10:52 PM
Couldn't agree more. If there were LCA skids for KDSS I'd already have a set.
2011 Trail Edition mostly stock, never wheeled
Instagram
Untitled Offroad
http://sittingbyariver.blogspot.ca/
03-29-2015, 11:22 PM
if you are looking for just a skid. this is not the right product to buy. At least, get aluminum for this location.
03-29-2015, 11:31 PM
Real Name: Jonathan
Real Name: Jonathan
I think RCI is working on some.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
03-29-2015, 11:37 PM
my install shop trimmed them to fit the kdss....
