Old 08-12-2020, 07:13 AM #16
SlvrRnnR's Avatar
SlvrRnnR SlvrRnnR is offline
SlvrRnnR will become famous soon enough
SlvrRnnR's Avatar
Originally Posted by 4Running22 View Post
What's a good jacking points for rotating your tires? Let's say if I start at the driver's side can I just jack it up in the center of the driver's side frame and place two jack stands and both sides? Will it damage the vehicle if I jack it in the center of the frame?
+1 would like clarification on this also. Have scoured the web and only have found one or two videos of Taco owners jacking from the center of the frame and placing 2 jack stands on one side. (to do the front to back tire rotation)
The only other info for the 4r I found was someone mentioned jack from the front center Toyota suggested point, place one jack stand (ie on the pass side) and lower jack.
Then jack from rear pumpkin (Toyota recommended) and place one jack same side under the diff axle (Toyota suggested)
Wondering if there's too much twisting doing this as your jacking the rear up with only one side of the front on a stand. I guess I could just get 4 jack stands and lift it all up evenly. Thought having one side on ground feels safer though.
SlvrRnnR is offline   Reply With QuoteReply With Quote
Old 08-12-2020, 09:02 AM #17
4Running22 4Running22 is offline
4Running22 is on a distinguished road
That was my other option. I was afraid too if that would cause too much twisting.
Or I can start from the rear by jacking up the rear pumpkin and place a jack stand under the diff axle (ex. passenger side). Then jack it up at the frame at the front passenger side and place a jack stand there. Would that cause twisting as well?
4Running22 is offline   Reply With QuoteReply With Quote
Old 08-12-2020, 04:20 PM #18
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
For a rotation, why not just put a stand at both front frame points, then use the jack under the rear axle to change each rear tire. Seems like the easiest route. Hell, maybe put the jack under ther rear pumpkin then you're done.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 08-12-2020, 04:30 PM #19
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
If I do a front to back swap, I just put the jack in the middle of the frame and lift the whole side.....swap tires and move to the other side. If I cross, I lift the front side and put a stand and use the jack on the rear axle and swap, then do the other two. I have two jacks and can just lift the whole thing at once If I want to cheat! A Harbor Freight $59 lightweight makes a great second jack and makes everything easier. I ground one of the 4 ''tabs'' on the lift point to fit in the hole in the bottom of the lower arm and it locks in and lifts one front wheel securely and can;t fall off.
83Mule is offline   Reply With QuoteReply With Quote
Old 08-13-2020, 02:26 AM #20
I thought about doing that as well, lifting from the center of the frame to do a front to back swap. I'm assuming that wouldn't damage the frame.
Old 08-13-2020, 06:04 PM #21
83Mule's Avatar
83Mule's Avatar
No problem.....that's why Body on Frame is the way to go! Toyota boxed it and gave it strength!
Old 08-13-2020, 07:52 PM #22
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Jack it up here on this bracket that’s welded to the frame. Use stands!
jacking points-7da7744f-3894-4229-bf93-68857bd0dcdd-jpg
1000MPH is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 06:56 PM #23
83Mule's Avatar
83Mule's Avatar
Jack it up and find the spot that lifts front and rear evenly and I marked it with a spot of Day-Glo orange paint......now I just roll the jack right to it and lift.
Jacking Point Obadiah Maintenance/Detailing 19 11-18-2017 01:07 PM
Jacking a lifted truck JPWendtinc 4th Gen T4Rs 16 10-14-2011 10:24 PM
Tire jacking points Only4Gold General Discussions 5 09-28-2011 10:13 PM
Proper jacking/stands location...... skinnadoor Classic T4Rs 4 07-10-2007 10:19 AM
Jacking point(s) Uneek Maintenance/Detailing 3 08-31-2006 07:35 PM
